Toymods » Tech & Conversions » o2 sensor on 1jz
Chris Davey
sunny coast, qld
o2 sensor on 1jz Fri, 28 May 2004 23:10 Go to next message
I did a search but no results.
What exactly are the effects of disconnecting the 02 sensor? Particuarly on a 1jz? It is a 4 wire one.
Chris
Re: o2 sensor on 1jz Sat, 29 May 2004 00:54 Go to previous messageGo to next message
the only thing O2 sensors do is to adjust the mixture at light throttle... ie cruising around, which is maybe 80% of driving...
it will either allow engine to run cooler than it would (if lean) or with better economy (if rich)
and will help emissions..
ps, 4 wire just means it's heated.
why you want to disconnect it?
Skip
Re: o2 sensor on 1jz Sat, 29 May 2004 01:01 Go to previous messageGo to next message
Are you sure it's 4 wire? Mine is only 3 (soarer 1JZ)
Chris Davey
sunny coast, qld
Re: o2 sensor on 1jz Sat, 29 May 2004 01:53 Go to previous messageGo to next message
somebody said if you disconnect it will run richer under high load so if it is boosted up then that would be a good thing?
ed_ma61
Lost in the K hole
Re: o2 sensor on 1jz Sat, 29 May 2004 02:27 Go to previous messageGo to next message
yeah, itll run richer everywhere but at WOT and make the people's eyes water behind you at the lights... it will do SFA to top end high boost WOT driving.
no matter what anyone says, there is no way of 'fudging' sensors with stock ecus to make them any better than the way they are tuned stock. sure you can try, but it aint going to happen
BlackSupra
Re: o2 sensor on 1jz Sat, 29 May 2004 02:31 Go to previous messageGo to next message
ed_ma61 wrote on Sat, 29 May 2004 12:27
hmmmmm now who could have done that.........
ed_ma61
Lost in the K hole
Re: o2 sensor on 1jz Sat, 29 May 2004 02:35 Go to previous message
**shrugs**
Rolling Eyes
Previous Topic:AE82 Twin Cam Handling article
Next Topic:4AGZE timing belt tensioner issues
Current Time: Sun Oct 25 04:38:00 UTC 2026
Total time taken to generate the page: 0.0048232078552246 seconds
