Toymods » Tech & Conversions » chemiweld!!
SoarerFury
icon5.gif  chemiweld!! Sat, 29 May 2004 02:29 Go to next message
does chemiweld work?
coz ive been told i should use it, till i get enough $$$ up to fix the HG!
give it a go??
Re: chemiweld!! Sat, 29 May 2004 02:30 Go to previous messageGo to next message
sometimes it doesn't work at all - sometimes it works too well and puts large blockages in the water channels.... and sometimes it does work properly.
If you want to be keeping your engine for any extended period of time, I wouldn't recommend it
SoarerFury
Re: chemiweld!! Sat, 29 May 2004 03:38 Go to previous messageGo to next message
ive been told it does work, had a mate put it in a 308 after he blew his HG, went for a like a year
Re: chemiweld!! Sat, 29 May 2004 03:42 Go to previous messageGo to next message
a whole year?!?
WOW </sarcasm>
no offence man Smile Just a year isn't exactly a long time for an engine to run, and I've seen the aftereffects of chemiweld on water channels in an engine - it blocked the water channels enough to cook the engine
SoarerFury
Re: chemiweld!! Sat, 29 May 2004 03:50 Go to previous messageGo to next message
mannnn... its just gonna have to do me till i get some money up!! Confused
its just gonna seal the hole/or whatever in the gasket
Fattony
Re: chemiweld!! Sat, 29 May 2004 03:54 Go to previous messageGo to next message
I wouldnt be to optimistic of such a solution to fixing a HG problem with chemiweld. It is more than most likely only ever ment to have been a temporary solution to your problem and never a long term fix, its what we call here in the trade a band-aid solution. Yet and there is also the possiblilty of the compound blocking water channels in your head, and that will cause you more than a HG problem. I would just fix the cause of the problem first otherwise it would be likely that using s/*t like that could cost you more money in the long run.
SoarerFury
Re: chemiweld!! Sat, 29 May 2004 04:03 Go to previous messageGo to next message
nah it is gonna be a temporary fix, like 2 weeks at most
Re: chemiweld!! Sat, 29 May 2004 04:09 Go to previous messageGo to next message
if it's only 2 weeks, then run without a radiator cap or just a loosely attached so it does't hold pressure, don't run hard, keep the water up to it and avoid long or peak-hour drives.
if it wants to run hot, remove the thermostat to remove flow resitrictions
note: all this does is preventing water being forced into combustion chamber or oil system. If the gasket well-and-truely rooted and leaking badly, then stop driving.
Why pollute the cooling system with junk that you're going to remove several weeks later?
if you can't do that, then get the bus/train/feet for 2 weeks Wink
SoarerFury
Re: chemiweld!! Sat, 29 May 2004 04:16 Go to previous messageGo to next message
it runs really good actually, it just has slighty gone, but i just replaced the oil and wacked some water in the cooling system..
mmmmm that milky oil looks good enough to drink Razz mmmm caramel milkshake
doesn't run hot either Smile
Re: chemiweld!! Sat, 29 May 2004 04:22 Go to previous messageGo to next message
well - how much risk you willing to bear?
i'd advise against the chemiweld - it'll leave crap thru-out the radiator, coolant lines, internal heater, head/block, turbos (you have?) etc... they were only really designed for water+ coolant?
but... like i said ... you choice/risk - personally, i'd get the bus/walk rather than spend extra dollars rectifying the problems caused by using crud in the coolant.
Re: chemiweld!! Sat, 29 May 2004 05:33 Go to previous messageGo to next message
i think everyone should have a bottle of chemiweld in their car.. just in case..
i have used it on a number of occasions (other ppls cars to get them home), but if it is a performance motor then i would be tempted to just trailer the car...
it forms blockages wherever it gets exposed to air... if you form steam pockets in side the motor, apparently it can form blobs of shit that block passages..
if you are hours from home, are going to pull the motor out to fix it and get the block and head properly cleaned, i'd use it, but it will coat shit, and it can cause blockages..
that said, it usually works
my 2c.
SoarerFury
Re: chemiweld!! Sat, 29 May 2004 05:47 Go to previous messageGo to next message
yeah.. it turns hard when it comes in contact with air
well its only letting air through the "tiny" hole in the gasket.. so it should do much more.
i had a mechanic recommend, he's used it drift skyline
so it must be good!
Re: chemiweld!! Sat, 29 May 2004 06:01 Go to previous messageGo to next message
i'd recommend anything that reduced my workload by 90% but still let me charge for it Wink
.. and even better .. is knowing that down the track i'd be able to charge a stinker of a bill due to the excess work i'd caused... Wink
Re: chemiweld!! Sat, 29 May 2004 06:49 Go to previous messageGo to next message
If it was used in a Dorifto Skyline, it MUST be good. Who could argue with that?
feral4mr2
Bundaberg, Qld.
Re: chemiweld!! Sat, 29 May 2004 07:04 Go to previous messageGo to next message
i sell heaps of the stuff at work, i always tell the customer it is a band-aid fix and may or may not work at all.
but shit, you arent going to know unless you try it. Wink
ed_ma61
Lost in the K hole
Re: chemiweld!! Sat, 29 May 2004 09:07 Go to previous messageGo to next message
id only ever use it on an engine/rad that i planned to just throw out once i got around to doing the 'proper fix'
theres no way i would contemplate filling an engine/rad/heater up with this crap, then a few weeks/months later attempt to disassemble and rebuild it...
Allan
Re: chemiweld!! Sat, 29 May 2004 10:00 Go to previous messageGo to next message
i poured two bottles into my MA45 didnt do shit good or bad... flushed it out no sign of it and heater core / radiator or block
Allan
people100
Rocklea qld
Re: chemiweld!! Sat, 29 May 2004 11:13 Go to previous messageGo to next message
if done properly and by the instructions chemi weld does work good but is only a bandaid...To avoid bloackages flush the engine after a week or so of use to get rid of the excess to stop blockages and remember that instructions are on the bottle for a reason. READ THEM. and have the car at operating temp before putting it in if possible.
HighRolla
Re: chemiweld!! Sat, 29 May 2004 13:51 Go to previous messageGo to next message
That's a great idea to get you home as Stewart was saying..never thought of that Shocked . I've always wondered what I'd do if I blew a head gasket while on a holiday Confused , take a risk with a local mechanic? Sad . If you could put that stuff in to get you home, it could save you being at the mercy of some monkey with a spanner (i.e dodgy mechanic). I may be a monkey also, but I take more time because it's my own car and want the job done right.
Does it fix a large majority of HG problems temporarily?. Our parents SV11 camry blew a headgasket about 5 years ago and the car would hardly make it down the street. From running fine to almost tow job in a metter of minutes Mad .
toynado
Re: chemiweld!! Sat, 29 May 2004 17:59 Go to previous messageGo to next message
retorque the head gasket
or rent a wreck
or a real car
Jag7799
Re: chemiweld!! Sun, 30 May 2004 00:13 Go to previous messageGo to next message
so many people fear busted head gaskets lol!...
I wouldnt drive it.. quick fixes ALWAYS screw you over.. why not catch the bus for 2 weeks?.. i know its a bitch.. but still.. better than finding a new engine
HighRolla
Re: chemiweld!! Sun, 30 May 2004 00:25 Go to previous messageGo to next message
what and get the car towed, toynad?
If I blew a headgasket within about 50km from home I'd get it towed, but what about on holidays? Jag you seem pretty tough on the whole matter Cool ..have you got a super dooper HG installed or you fancy yourself with a socket set 1000km from home Confused
Sorry, deviated a little from original qn Embarassed
Jag7799
Re: chemiweld!! Sun, 30 May 2004 00:27 Go to previous messageGo to next message
not at all.. im just saying its not worth risking perm engine damage and im lucky enough to never have had blown head gasket
DLuded
Re: chemiweld!! Wed, 02 June 2004 05:47 Go to previous messageGo to next message
i was told that if done correctly by someone who knows what they are doing, and flushes the system in about a week after adding chemiweld, what it works pretty good. if the person using it doesnt know what they are doing they can screw up the motor
allencr
tallahassee FL usOFa
Re: chemiweld!! Wed, 02 June 2004 12:56 Go to previous message
this type stuff is for an emergency, or used car weasels trying to unload a beater.
Previous Topic:Info on 7.5 inch LSD's
Next Topic:Window Scratches from rollers (early model celicas)
Current Time: Fri Nov 20 13:14:24 UTC 2026
Total time taken to generate the page: 0.019575834274292 seconds
