Toymods » Tech & Conversions » ignition switch
Satoshi
ignition switch Sun, 30 May 2004 13:12 Go to next message
can somebody tell me whether its simple to change the ignition switch for an ae86?
my start motor still cranks even tho my engine is running after i start it up..
Re: ignition switch Sun, 30 May 2004 13:20 Go to previous messageGo to next message
My girlfriends TA22 did this the other day, Didnt have the key inserted fully Embarassed
Satoshi
Re: ignition switch Sun, 30 May 2004 13:37 Go to previous messageGo to next message
Cool1 wrote on Sun, 30 May 2004 22:50
meaning?
Rolling Eyes
Re: ignition switch Sun, 30 May 2004 13:45 Go to previous messageGo to next message
Yes, it's easy. Do a search, find the relevant page in the AE86 manual on this site Shocked
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: ignition switch Sun, 30 May 2004 13:50 Go to previous messageGo to next message
you need to replace that barrel too paul, that is also causing the problems we are experiencing.
Satoshi
Re: ignition switch Sun, 30 May 2004 16:25 Go to previous messageGo to next message
ok..i took out the ignition switch (round white colour) and started up with the flat head screwdriver..and its still giving me the continous cranking
how do i actually test whether the switch is working or not??
if its stuffed..i wont be able to feel any 'clicks' when i turn them...but i still feel the click..
advice needed before i waste my penny on a part that is still working..
Satoshi
Re: ignition switch Sun, 30 May 2004 16:29 Go to previous messageGo to next message
how do i test my key barrel as well??
william68
Re: ignition switch Wed, 02 June 2004 01:55 Go to previous message
what you can do now is to trigger the ecu and the other componenet relay with a switch so it turn on.
Currently I think your components only turn on when you are cranking it and once it back to the on position at the ignition switch the delay is not trigger so other component is off.
No power to the ecu no signal to the ignition hence no power to the coil to produce spark.
Just try this method and see if it works.
Regards
Previous Topic:Using TA22 door trims in a RA23
Next Topic:Do you know about these cheap 4AG shim-under-buckets?
Current Time: Fri Sep 11 14:30:01 UTC 2026
Total time taken to generate the page: 0.059809923171997 seconds
