Toymods » Tech & Conversions » twin piston rear calipers @ 18mm
ed_ma61
Lost in the K hole
icon4.gif  twin piston rear calipers @ 18mm Mon, 31 May 2004 01:45 Go to next message
anyone know of any easy-to-get toyota twin piston rear calipers that normally reside on 18mm thick rotors? dia anywhere around 260-280mm would be fine.
and the bonus $64,000 question, what is the mounting hole c-c dimension of these calipers (or any other offset info you might hve too Very Happy )
ed
ed_ma61
Lost in the K hole
Re: twin piston rear calipers @ 18mm Mon, 31 May 2004 02:11 Go to previous messageGo to next message
just scrounging through the dab catalogue:
ma70 291x18
mx73 269x18 (single piston?)
ms123 268x18 (single piston?)
ls400 291x16
sw20 263x16
jzz30 306x16
uz31 291x16
tcr1 (tarago) 291x18
78/79/80/90 series landcruiser
anyone have any ideas?
Re: twin piston rear calipers @ 18mm Mon, 31 May 2004 02:15 Go to previous messageGo to next message
Also ST205 and JZA80 rears (later ones are 2 pot rears). Both are 16mm thick. From memory the pad surface area has a radial depth of about 54-55mm.
[Updated on: Mon, 31 May 2004 02:17]
ed_ma61
Lost in the K hole
Re: twin piston rear calipers @ 18mm Mon, 31 May 2004 02:17 Go to previous messageGo to next message
yeah, theyre proabably a little big to straddle a pissy 268mm rotor though...
or perhaps... hmmm
seen any lately?
rsdeo
Burlington, On. Canada
Re: twin piston rear calipers @ 18mm Mon, 31 May 2004 03:35 Go to previous messageGo to next message
It would be nice if the bolt mounting holes are 160mm center to center.
roger
Re: twin piston rear calipers @ 18mm Mon, 31 May 2004 04:27 Go to previous messageGo to next message
Simoto twin piston calipers as found on the RT132 could be made to the right width with a spacer. Like some people do to fit vented disks. The bolt spacing is 90mm
Re: twin piston rear calipers @ 18mm Mon, 31 May 2004 04:35 Go to previous messageGo to next message
And dopn't forget the Ovlov 2 and 4 spots. They are cast iron though and the 2 spots have a pretty shitful pad surface area.
Jayem
Finland
Re: twin piston rear calipers @ 18mm Mon, 31 May 2004 12:29 Go to previous messageGo to next message
Maybe mid 90's BMW? (19mm)
bbaacchhyy
Re: twin piston rear calipers @ 18mm Mon, 31 May 2004 15:31 Go to previous message
Z32 300ZX and R32/33/34 Skylines. Rolling Eyes I know , they are not toyota.
I can check the mounting hole dims on the 300Zx ones, as that is what I am using. But if you stick with the MA61/MS123 disc, the Nissan ones will be hard to fit due to the leg length of the caliper mounts.
MA70 are single piston rears.
SW20 early are single piston and have the integral handbrake. The later ones are 22mm, but neither will fit as the body is too 'deep' and interferes with the rear shock. Been there done that Crying or Very Sad
I think the beemer rears are single piston as well.
I'll email you some pics
Michael B
Previous Topic:3t help!!! please!!!
Next Topic:sump modifications
Current Time: Sun Nov 1 21:35:12 UTC 2026
Total time taken to generate the page: 0.0068509578704834 seconds
