Toymods » Tech & Conversions » has anybody rebuilt a 1jz?
Chris Davey
sunny coast, qld
has anybody rebuilt a 1jz? Mon, 31 May 2004 03:42 Go to next message
hello all,
if worst comes to worst I may have a big problem and require a rebuild. I did a search and all I got was the 1.5jz stuff. I am not really interested in doing that as 1. 2jz blocks aren't very easy to come by and 2. they are not very cheap.
If it is a problem in the bottome end, do you think it would be better to buy new bits and rebuild it or buy second hand motor and put the 2 together to make 1 good motor, or just drop in another motor.
My motor is pretty stock except some things have been changed like no PS and the alternator has been relocated and no clutch fan.
If it is not the bottom end problem then it is most likely a head problem in which case, I would probably just get the head done and new bits put in.
what do you think?
Chris Davey
sunny coast, qld
Re: has anybody rebuilt a 1jz? Mon, 31 May 2004 10:09 Go to previous messageGo to next message
nobody? Sad
Mr DOHC
Re: has anybody rebuilt a 1jz? Mon, 31 May 2004 10:21 Go to previous messageGo to next message
have u actually found out the problem, was it in the front end or is it a big end
Chris Davey
sunny coast, qld
Re: has anybody rebuilt a 1jz? Mon, 31 May 2004 11:11 Go to previous messageGo to next message
haven't done the leak down test yet as I need a compressor. If it is the head then I will get it ported and new bits and if it is the block then I am seriously contemplating turning the car into a drag car as that is all it is good for anyhow. These damn street legal rules are just a hinderance Smile However, if that was the case it would be a very long upgrade path as I am on a tight budget. hmmm?
I shouldn't have got those twin pipes and boost controller Sad
Chris Davey
sunny coast, qld
Re: has anybody rebuilt a 1jz? Mon, 31 May 2004 11:12 Go to previous messageGo to next message
oh yeah, don't think it is the big end as it was screaching like hell and then stopped all of a sudden. Checked the oil and there are no bits of bearings in there. Thinking maybe bent rod or dead valve spring. Will find out soon I guess.
Chris Davey
sunny coast, qld
Re: has anybody rebuilt a 1jz? Thu, 03 June 2004 02:53 Go to previous messageGo to next message
OK so can I assume that nobody has ever rebuilt a 1jz-gte? I know these engines are supposed to be pretty strong but some people have had to have broken some?
Mine has a problem and I am only making about 330ish HP?
Manny
Re: has anybody rebuilt a 1jz? Thu, 03 June 2004 03:15 Go to previous messageGo to next message
I've been following these engines for some 6 years and owned 3 in the last 4 years and I've only heard of 1 single 1JZ being rebuilt in WA and fitted in VIC and the details were very sketchy.
The main reason is cost - a good bare 1JZ engine can be had for under $800 - a full rebuild gasket kit on it's own is over $500 without any parts, machining or labour - the maths dictate it's easier/cheaper to replace the engine than rebuild it ; at least until demand exceeds supply...
Chris Davey
sunny coast, qld
Re: has anybody rebuilt a 1jz? Thu, 03 June 2004 03:22 Go to previous messageGo to next message
hmm, well if that is the case then I may end up going the 1.5JZ route after all. I knew that not many people would have blown the internals but I thought that somebody may have wanted to get a "freshly" rebuilt engine rather than chancing another import engine. That was my line of thinking anyway Smile
Stenno
Re: has anybody rebuilt a 1jz? Thu, 03 June 2004 05:08 Go to previous messageGo to next message
Supraman has a bare 1JZ for $1000 I believe?
Manny has summed it up, a gasket kit is about $560 trade, plus bearings, plus rings, plus machining and other bits and bobs.
Seriously unless you know the person doing the rebuild (or are doing it yourself) it's not worth it for the cost of a bare 1JZ.
However in saying that sometimes it's better the devil you know Wink
I'm rebuilding my other 2J atm which is on hold for a while due to finances, but being able to choose your internals is always a bonus.
http://www.turbosupras.com/images/rebuild/2jz-gte/bottom_end/Eagle%20Rods/Installed%20Rods%202.jpg
[Updated on: Thu, 03 June 2004 05:11]
Mr DOHC
Re: has anybody rebuilt a 1jz? Thu, 03 June 2004 08:21 Go to previous messageGo to next message
i can hook u up with cheap parts chris, and maybe cheap labour on getting the head done
YelloRolla
On your mum!
Re: has anybody rebuilt a 1jz? Thu, 03 June 2004 08:31 Go to previous messageGo to next message
Chris - I belive that Jamie of JT Autogas in Cardiff NSW may have built his one - not entirely sure though
IRA11Y
Club Member
Re: has anybody rebuilt a 1jz? Thu, 03 June 2004 08:39 Go to previous messageGo to next message
rebuilding any engine is all pretty much the same deal, is there something specific your trying to find out??
audi man
nz
Re: has anybody rebuilt a 1jz? Thu, 03 June 2004 10:43 Go to previous messageGo to next message
Yes i have and what it cost me try and find another engine it will be a lot cheaper.
Special Ed
I wanna go Hawaiiiiii.......
Re: has anybody rebuilt a 1jz? Thu, 03 June 2004 11:43 Go to previous messageGo to next message
No, I can confirm that the JT Racing 1j has never been opened.
I can also confirm it has more HP than anyone has a right to...
it is making in excess of 500rwhp@25 psi.
Jamie is about to start a rebuild though, the usual gear, but mechanical fuel pumps, twin gt40's, 1800cc injectors and Alcohol fuel.
I dare you to doubt him, hehe Smile
Mr DOHC
Re: has anybody rebuilt a 1jz? Thu, 03 June 2004 11:49 Go to previous messageGo to next message
Special Ed wrote on Thu, 03 June 2004 21:43
ouch, the subzero skyline makes 900RWHP with stock internals
Re: has anybody rebuilt a 1jz? Thu, 03 June 2004 11:50 Go to previous messageGo to next message
I am rebuilding a 2JZGE. Longer forged rods, higher compression forged pistons, balanced, ported head, big cams, shim under bucket conversion, blah, blah, blah....But you know, it's NA and that's what you have to do to get power.
But your cheapest bet is to just buy a bare engine sans turbos and swap everything over. You should be able to find one for less than $1000.
Special Ed
Re: has anybody rebuilt a 1jz? Thu, 03 June 2004 12:06 Go to previous messageGo to next message
Mr DOHC wrote on Thu, 03 June 2004 21:49
is this the r33 gts-t ?
900rwhp from a stock internals rb25 ? you gotta be kidding !
FWIW - the JT ute has dyno charts for 460rwhp @ 19psi and optimax. Now been road tuned at 25 psi ( no traction on dyno).
Chris Davey
sunny coast, qld
Re: has anybody rebuilt a 1jz? Thu, 03 June 2004 12:56 Go to previous messageGo to next message
sorry to get everyone excited but it looks like I don't need a rebuild after all Smile
But I am sure this info. will be of great use to many people when they use the search button Smile
Mr DOHC
Re: has anybody rebuilt a 1jz? Fri, 04 June 2004 08:15 Go to previous messageGo to next message
Special Ed wrote on Thu, 03 June 2004 22:06
dear god i'm a fuck wit Confused , i meant the subzero SUPRA, JZA80, i was reading a thread on a skyline on another forum as the same time Rolling Eyes
Chris Davey
sunny coast, qld
Re: has anybody rebuilt a 1jz? Fri, 04 June 2004 20:04 Go to previous message
On www.supraforums.com.au it said that supra made 780rwhp? I thought it was 880 actually. Anyway, we know it is a lot Smile
Previous Topic:gearbox
Next Topic:whats up from america,specificaly atlanta, georgia
Current Time: Sun Nov 1 09:21:36 UTC 2026
Total time taken to generate the page: 0.0052609443664551 seconds
