Toymods » Tech & Conversions » mystery plug
monkeymajik
mystery plug Mon, 31 May 2004 05:37 Go to next message
I had to move some wiring/lines to get to the clutch master cylinder. Now that it's all back in and going, I've noticed this plug and socket arrangement in the top left corner of the bay
http://users.bigpond.net.au/monkeymajik/car/wtfPlug.jpg
I cant remember if it was connected or not before I moved everything around. The car seems to run fine with it in it's current unconnected state.
What the hell is it?
Car is an auspec ae86 with an ae92 AFM 4agze
[Updated on: Mon, 31 May 2004 06:22]
ra23celica
Re: mystery plug Mon, 31 May 2004 06:25 Go to previous messageGo to next message
I don't know the AE86 very well but that looks to be some sort of vaccum valve. Please tell us the colour and number of wires on either side of that connection and I will have a look at a wiring diagram for you.
Mitch.
monkeymajik
Re: mystery plug Mon, 31 May 2004 06:41 Go to previous messageGo to next message
From the right hand plug there is a blue wire and a pink wire.
From the left hand plug there is two blue wires.
Cheers.
ra23celica
Re: mystery plug Mon, 31 May 2004 06:43 Go to previous messageGo to next message
So these wires are solid colours only, or do they have strip's / traces ?
I take it they are not related to the silver cannister behind the
lhs plug ?
Mitch.
monkeymajik
Re: mystery plug Mon, 31 May 2004 06:49 Go to previous messageGo to next message
Solid colours, the pink and blue wires on the rhs have some red specs on them, but the specs do not look intentional.
The lhs plug wires go into the silver canister on the left.
[Updated on: Mon, 31 May 2004 06:49]
JamitGZE
Re: mystery plug Mon, 31 May 2004 08:05 Go to previous messageGo to next message
monkeymajik,
I have an AE92 AFM GZE also. I'm pretty sure the plug/socket you are referring to is for the front/rear window water solenoid (the grey thing). It is meant to sit in-line with the washer motor and the front squirters. When you switch on the rear wiper jet, it is supposed to turn on the water motor (in the little tank) while diverting the water to the rear from this point.
FYI, I had trouble getting the solenoid going (turned on the front ones and water would dribble out the back one) so I disconnected/bypassed it. It looks like yours has been bypassed also (so only the front water jets work).
JamitGZE.
Sprinter
Re: mystery plug Mon, 31 May 2004 13:57 Go to previous messageGo to next message
JamitGZE has the answer Smile
Denis
monkeymajik
Re: mystery plug Mon, 31 May 2004 14:11 Go to previous messageGo to next message
By bypassed you mean unplugged is that right? So I should leave it disconnected? (i'm sorry it's late Smile )
takai
Re: mystery plug Mon, 31 May 2004 14:22 Go to previous messageGo to next message
You unplug it and then use a joiner to join the hose from the bonnet to the hose coming from the washr bottle
ra23celica
Re: mystery plug Mon, 31 May 2004 23:36 Go to previous messageGo to next message
Yep - this has been answered above.
I trolled through the wiring diagrams last night and yes, its the rear wiper washer solenoid and it has been disconnected in this case. You can by-pass the thing or just hook it back up and see if it still works as the Toyota gods intended.
Mitch.
Re: mystery plug Tue, 01 June 2004 00:02 Go to previous messageGo to next message
Plus there's a 162% chance it doesn't work... Shocked
sik sx
Sunshine Coast
Re: mystery plug Tue, 01 June 2004 12:14 Go to previous message
sorry to use your post but i also have a mystery plug on my st162 its like down the back like a foot underneath where the air box piping goes into the manifold..its white and round i think..there is no connection or whole for this to go into Confused
Previous Topic:Automatic O/D Button on Hydraulically Controlled auto
Next Topic:18R points gap
Current Time: Sun Nov 22 14:00:26 UTC 2026
Total time taken to generate the page: 0.011703014373779 seconds
