Toymods » Tech & Conversions » Wheel stud pattern amoungst soarers/supras?
V8_MA61
icon14.gif  Wheel stud pattern amoungst soarers/supras? Mon, 31 May 2004 08:51 Go to next message
I'd Just like to know about the 5 stud pattern used on the ma70 supras..is it the same on a jzz30/uzz30 soarers and mz221 soarers? And also jzx91 chasers and mx83 cressidas.
i've heard there are various 5 stud patterns around.
Thanks guys
Blake
[Updated on: Mon, 31 May 2004 08:52]
ed_ma61
Lost in the K hole
Re: Wheel stud pattern amoungst soarers/supras? Mon, 31 May 2004 09:48 Go to previous messageGo to next message
theyre ALL 5 x 114.3mm (4.5")
there 'may' be different offsets, but typically theyre all around the 36mm mark, nothing drmatically different
V8_MA61
Re: Wheel stud pattern amoungst soarers/supras? Mon, 31 May 2004 10:56 Go to previous messageGo to next message
in other words they should all fit the same wheels?
ed_ma61
Lost in the K hole
Re: Wheel stud pattern amoungst soarers/supras? Mon, 31 May 2004 10:57 Go to previous messageGo to next message
yup
V8_MA61
Re: Wheel stud pattern amoungst soarers/supras? Mon, 31 May 2004 11:02 Go to previous messageGo to next message
sweet thanks mate! Cool
Soarer
Wollongong
Re: Wheel stud pattern amoungst soarers/supras? Tue, 01 June 2004 00:23 Go to previous messageGo to next message
ed_ma61 wrote on Mon, 31 May 2004 19:48
The xZZ3x Soarers and JZA80 Supras use +50mm offset. Unsure about earlier models though.
[Updated on: Tue, 01 June 2004 00:24]
ed_ma61
Lost in the K hole
Re: Wheel stud pattern amoungst soarers/supras? Tue, 01 June 2004 00:59 Go to previous messageGo to next message
that much? bejeebuz
V8_MA61
Re: Wheel stud pattern amoungst soarers/supras? Tue, 01 June 2004 14:23 Go to previous messageGo to next message
does this pose a problem for me? going onto an ma61...
ed_ma61
Lost in the K hole
Re: Wheel stud pattern amoungst soarers/supras? Tue, 01 June 2004 14:40 Go to previous messageGo to next message
dude, have you read a single post about ma61 offsets?
+50mm offset is totally unusable on an ma61
V8_MA61
Re: Wheel stud pattern amoungst soarers/supras? Wed, 02 June 2004 13:10 Go to previous messageGo to next message
fuck..no i generally havent read much about offsets...
Whats the biggest offset i can use then? 36mm or a little play?
[Updated on: Wed, 02 June 2004 13:13]
bbaacchhyy
Re: Wheel stud pattern amoungst soarers/supras? Wed, 02 June 2004 14:14 Go to previous messageGo to next message
Depends on what front struts you are using.
With RA60 struts and MS65 front hubs fitted, a 16 x 8" rim with +25 offset has about 10mm clearance to the strut tube (greater negative camber is offset by the hub being further outboard).
With MA61 struts and MS65 front hubs fitted, a 16 x 8" rim with +25 offset has about 10mm clearance to the strut tube.
With Norbs fitting MX83 stuts, I think +35 on a 8" rim is OK as well.
The offset is not the whole story, it is the rim width as well.
The best way to look at it regardless of rim width is to work out the maximum "backspacing" that can be tolerated, and then you can work out the appropriate offset given a rim width from there.
Michael B
Re: Wheel stud pattern amoungst soarers/supras? Wed, 02 June 2004 23:30 Go to previous messageGo to next message
Stock offset is +8mm, so you can forget about using 36mm rims if you're using the stock struts. As Michael mentioned MX83 struts will allow you to run much higher offset rims on the front; 35mm rims seemed to work OK but I didn't try fitting them on the back so I don't know what will happen there.
50mm rims definitely won't fit on the front even with MX83 struts; the 35mm rim I tried was only a few mm from the strut.
V8_MA61
Re: Wheel stud pattern amoungst soarers/supras? Thu, 03 June 2004 08:39 Go to previous message
thanks all, thats is all i need to know Smile
Previous Topic:G-reddy E-manage
Next Topic:MA61 Gear Ratios
Current Time: Thu Oct 15 22:54:53 UTC 2026
Total time taken to generate the page: 0.084240913391113 seconds
