Toymods » Tech & Conversions » Major problem with starting - please help
Simon-AE86
Banned user
ADELAIDE - The Drift City
Major problem with starting - please help Mon, 31 May 2004 13:00 Go to next message
Ok, i dropped a 4age with loom into a stock aust spec ae86, it had the old 4ac in it, Dropped in engine loom ecu etc etc, Wired it all up and started it, noticed some issues with the starter switch and thought switch was dodgy. As in the switch would leave the starter engaged while it was running, u had to carefully move the switch back and it would run as normal, move backl too far and it would die (but switch was still in the on position)
following me so far? so the car was running and driveable, drove ti with no worries at all.
Anyway the next day the owner of the car could not get it going at all. it would start/fire but as soon as u release the pressure on the key from the starting position, it would die (even tho its in the on position)
so i told him to go get another ignition switch, did that, installed and no luck whatso ever.
Car HAS run with this wiring set up so its doubtful that ive made a wiring error. Fuses and relays all checked.
Re: Major problem with starting - please help Mon, 31 May 2004 13:50 Go to previous messageGo to next message
sounds like you've wired up power to the ECU from the Start not Ign output of the switch.
And/or the circuit-opening relay is not setup right.
suggest connecting a test lamp to + going to ECU and see if has power when at IGN or only during Starting.
Simon-AE86
Banned user
Re: Major problem with starting - please help Mon, 31 May 2004 14:02 Go to previous messageGo to next message
doesnt explain why we had it running, and perfectally before. and now it wont.
Satoshi
Re: Major problem with starting - please help Tue, 01 June 2004 05:07 Go to previous messageGo to next message
bump
Re: Major problem with starting - please help Tue, 01 June 2004 05:17 Go to previous messageGo to next message
Agree with chuckster - there is some issue with the way the ECU or fuel pump is powering up - START rather than IGN. Now that you have a good switch, it may well be highlighting the problem. I would suggest going over the power to ECU and circuit opening relay with the test lamp.
Satoshi
Re: Major problem with starting - please help Tue, 01 June 2004 11:25 Go to previous messageGo to next message
got my car started..but i have no idea what Steve did...but he's da man Very Happy
simon: what actually did steve do?
whip
Adelaide, SA.
Re: Major problem with starting - please help Wed, 02 June 2004 06:34 Go to previous messageGo to next message
im interested as well, seeing as the car seemed to run fine on sunday night...
Simon-AE86
Banned user
Re: Major problem with starting - please help Wed, 02 June 2004 09:16 Go to previous message
steve didnt do much at all Wink
there was a lack of trigger on the coil pack to tell it to remain on once the starter had been disengaged.
Previous Topic:clutch??
Next Topic:4AC(ough)
Current Time: Sat Nov 21 18:39:30 UTC 2026
Total time taken to generate the page: 0.009131908416748 seconds
