Toymods » Tech & Conversions » Sills repaired, drainage issues....
flynn21atwork
Sills repaired, drainage issues.... Tue, 01 June 2004 11:51 Go to next message
Hi guys,
In the process of rebuilding my RA23, previous owner repaired the rear section of the sills by cutting, folding the metal in and welding in some new metal.
All nice and neat, however now the inside of the drain holes are surrounded by jagged rusted (but possibly converted, and rust proofed) metal. Water could probably pool in there and not drain out properly.
What would be the best method of remedy?
I was thinking possibly plug the holes and pour some epoxy resin in, filling the corner of the sill. That way the water would run forward to one of the further drain holes. Pretty bad tho if I need to repair the sill at a later time, as it would be full of resin. i've been using POR-15 on a lot of the car, but the previous owner has already sprayed bitumen in a can into the gaps that provide access to the inside of the sills, so I don't think it would do a whole lot of good. I can't really get in to cut out the jagged metal as the hole is too small. any help is much appreciated.
Steve
flynn21atwork
Re: Sills repaired, drainage issues.... Wed, 02 June 2004 02:38 Go to previous messageGo to next message
----BUMP-----------
Cmon lads,
some1 must have some relevant experience, or know of a technique to fix this prob. I guess the guy before me really should have cut the rust out properly........ Confused
NickAE86
Brisvegas
Re: Sills repaired, drainage issues.... Wed, 02 June 2004 04:22 Go to previous messageGo to next message
hey flynn
not at all experienced at this but couldnt you just drill out the drain hole and whack some zinc spray/fish oil around it to make it rust proof?
ChuckLandwehr
Re: Sills repaired, drainage issues.... Thu, 03 June 2004 06:56 Go to previous message
Hiya Flynn, as it is the rear of the sills that have been repaired, if you have not yet removed the front seat belt mounting plates, pull em out. This gives a fair bit of access.
regards Chuck.
Previous Topic:Trumpets ??
Next Topic:I need some goop
Current Time: Sun Oct 18 21:05:19 UTC 2026
Total time taken to generate the page: 0.0044279098510742 seconds
