Toymods » Tech & Conversions » Silt in sump. Is this amout of metal sediment normal?
RobST162
Silt in sump. Is this amout of metal sediment normal? Tue, 01 June 2004 12:16 Go to next message
This is the sump of the 200 000+ k AE92.
Have been in the process of taking the engine apart and stuff and was interested to see the level of silt in the sump.
I don't think this is anything super dramatic.
Am I correct?
http://goodshopping.com.au/celica/rolla/rolla-Images/5.jpg
http://goodshopping.com.au/celica/rolla/rolla-Images/4.jpg
Edit: I stirred the silt around with a little stick... that is why it looks all lumpy.
it was just sitting there quite deep (2mm?) in places, and very thin in others.
Oil in base of sump quite sedimenty. NOT watery at all.
[Updated on: Tue, 01 June 2004 13:53] by Moderator
Jayem
Finland
Re: Silt in sump. Is this amout of metal sediment normal? Tue, 01 June 2004 13:44 Go to previous messageGo to next message
Think about how much of that metal powder has departed off in every oil filter change? Where has it came from? and why that isnt in oil filter ie. how many times that silt has gone through your motor? Scary isnt it?
RobST162
Re: Silt in sump. Is this amout of metal sediment normal? Tue, 01 June 2004 22:11 Go to previous messageGo to next message
yeah totally what I was thinking..
like sandpaper.. lucky it isn't my motor... lol, but I am scared for mine now Smile
Jayem
Finland
Re: Silt in sump. Is this amout of metal sediment normal? Tue, 01 June 2004 22:21 Go to previous messageGo to next message
But then again, you dont have nothing to worry about as long as the biggest particle in oil system is smaller than smallest clearance in the motor. Smallest clearance is normally something like 0.02mm.
clubagreenie
1st street on the right
Re: Silt in sump. Is this amout of metal sediment normal? Tue, 01 June 2004 22:37 Go to previous messageGo to next message
Better than some I've sen. Imagine taking the rocker covers off a V8 and the oil sludge is shaped around the rocker gear, gouged out only by the movement of the rockers. The guy bought the car in as he was suspect after he couldn't fill it with oil. The fillerhole was pluged with the stuff. Just brought the car, from private sale, met the seller at hos "home" turns out the people there had never seen or knew of him. Crying or Very Sad
Edit: the sump was virtually the same the crank had just started to gouge sludge built up there, oil reached the p/up through a few cracks in the goop.
[Updated on: Tue, 01 June 2004 22:38]
Re: Silt in sump. Is this amout of metal sediment normal? Wed, 02 June 2004 00:45 Go to previous messageGo to next message
heh heh, my first 4K was like that... we made a grease sculpture with the stuff.... was at least an inch think inside the motor...
still ran fine for 50K km with hand hone and new rings Razz
as for the sludge, easy way to tell where it's from is to stick it in a container, use a solvent (maybe acetone) to wash out all the oil, and then get a strong magnet and try to seperate the magnetic and nonmagnetic stuff...
there are only a few sources of metal in a motor..
the first and largest surface area is the bores (by far the largest). this will give ferrous magnetic 'dust' (unless it's all alloy motor Wink )
if you wanted to get real technical, you could clean and seperate the magnetic dust, weigh it, divide the gram amount by about 7.8 which tells you the cubic cm you have, then work out from the bore area how thick a layer has been removed...
next is the soft metal of the main, big end and other bearings.. non-magnetic. it should wear before the ferrous material that should not be in contact with it.
after that... stuff like piston pins.. the pistons themselves etc etc..
it is most likely just worn material from the bores...
i've taken to running some strong rare earth magnets on my oil filters.. it actually seems to pull this crud out!, a couple more on the sump (like hard drive magnets) actually does pull it out of the oil, but as jayem said, if it's small enough, it makes little difference anyway...
CYa, Stewart
monkeymajik
Re: Silt in sump. Is this amout of metal sediment normal? Wed, 02 June 2004 01:15 Go to previous message
I like that! I might try somthing like that soon (I have a dead HDD here out of warrenty)
Slightly O/T but...I've recently accquired a series 4 rx7 oil cooler, I want to clean/flush it before I plumb it in. What is a good method to get any gunk that may be left in there, out?
Previous Topic:Do you know about these cheap 4AG shim-under-buckets?
Next Topic:Supra Rear end specs
Current Time: Thu Oct 15 19:01:22 UTC 2026
Total time taken to generate the page: 0.0050919055938721 seconds
