Toymods » Tech & Conversions » clutch??
redlineGTi
syd- green valley
clutch?? Wed, 02 June 2004 08:31 Go to next message
looking to buy replacement clutch for my corolla gti. ae93 stock 4age (100kw) . any recommended clutches out there if so how much and where ya get it from?
u might tell me to look up old topics but the thing is my comp is half fu#ked so it is near impossible to navigate the site.
thanks....
HighRolla
Re: clutch?? Wed, 02 June 2004 08:44 Go to previous messageGo to next message
just get a stock daikin. Pittwater Brake and clutch(forum sponsors should kit you out).
Should be around $120 or less I think for the stock clutch kit. I think the 100kw has a 212mm clutch disk diameter but wouldn't be sure.
redlineGTi
syd- green valley
Re: clutch?? Wed, 02 June 2004 09:26 Go to previous messageGo to next message
thanks dude....
any thing else being used out there?....
much appreciated...
HighRolla
Re: clutch?? Wed, 02 June 2004 09:56 Go to previous message
You could go a heavy duty type.. I think about $200, Daikin also. I didn't think it was wothwhile. I still give mine the occasional hell (not real stupid stuff though..if your planning on dropping it quite a bit go the HD). Just thought if i sell it or other people driving it it is better having standard clutch as car has no mods.
I got my flywheel machined, 30 bucks cash. I think pittwater brake and clutch could do that too.
I think PBR would probably be ok also..don't think there is that much between them really.
I also needed a new master cylinder as I couldn't bleed the air out of the system (had it disconnected for a couple of weeks). Your slave and MS may be ok. Check for leaks in cabin near pedal box..if shagged my be easier to fix while your playing round with everything.
See if anyone else has opinions on clutches Cool
Where in Sydney are ya?
Previous Topic:Shortening RA60 struts
Next Topic:Major problem with starting - please help
Current Time: Fri Nov 20 14:10:45 UTC 2026
Total time taken to generate the page: 0.0052270889282227 seconds
