Toymods » Tech & Conversions » Cressida to 1uz-fe swap
ranoo
Cressida to 1uz-fe swap Mon, 02 September 2002 02:57 Go to next message
In regards to converting an MX83 cressida to 1UZ-FE power, can anyone confirm that the best donor car would be the uzs131 toyota crown? I have heard that the exhaust manifolds on these cars are more compact and therefore more suited to this kind of swap.
Any info much appreciated.
biased99
Re: Cressida to 1uz-fe swap Mon, 02 September 2002 12:58 Go to previous messageGo to next message
Hmmm...Where to start?
Yes, the Crown engine comes with "smaller" (read very restrictive) manifolds. It also mounts differently in OEM config (a tilt, if I remember correctly), runs a remote oil-filter (handy in an '83 application - trust me, I know)!
It also runs a clutch fan and, I'm told, puts out less power than, say, a UZZxx Soarer engine, primarily, due to the exhaust manifolds.
Oh, and it also uses two separate ECUs, 1 for the engine, 1 for the transmission. (As distinct from the Soarer, for example, which uses one ECU for both)
Being a Toyota engine, I'd imagine there are a number of other variations also...someone who is more familiar with the Crown engine will probably expand on this.
BTW. My project is using the Soarer engine and, yes, the exhaust manifolds have had to be "re-jigged" slightly to make the whole thing fit, particularly around the steering input-shaft...
mx83toy
Re: Cressida to 1uz-fe swap Mon, 02 September 2002 13:25 Go to previous messageGo to next message
man i imagine its a cool and different conversion an looks exelent like v8cressida's but from a conversion point of veiw i'd say realy consider the J it's a piss easy conversion which can be done over a weekend with the correct equipment...we lifted the chasers body straight off the engine/crossmember/ suspention/steering (we left everything in one peice even left tyres on for better manuvourability Smile) lifted the cressida up really high and slid everything under and bolted everything straight up....it was just to dam easy to consider anything else unless you really really have your heart set on the the v8 up 2 you man and good luck with what you choose the cressida does rise to the occasion and feels great with some grunt under the hood
my 2 c
ranoo
Re: Cressida to 1uz-fe swap Tue, 03 September 2002 14:19 Go to previous messageGo to next message
Thanks for the input guys.
I have still got my heart set on the 1uz swap, as i cant justify the apparent fuel consumption of the 1j as the car will be a daily driver and am trying to keep the conversion and the future running costs to a bare minimum (not to mention simplicity of engine setup,and possible insurance hassles).
As yet I haven't done that much research on the 1uz variants because i cant find that much info on them in regards to the specs of the sump,manifold,wiring, and dimensions.
I just don't want to get burnt by buying the wrong style of motor.
Also, Biased I was under the impression that soarers didn't come in a front sump config? How do you intend to 'rejigg' your exhaust manifolds, as they are cast iron arent they? I thought that cast iron could not be bent, welded etc.(not having seen the manifolds in the flesh before, i would be very interested for you to tell me how you plan to do this).
Sorry for asking so many questions, but i really need to find out as much as i can from some people in the know before i go out and buy one of these engine/trans combos.
RH
[Updated on: Tue, 03 September 2002 14:20]
Re: Cressida to 1uz-fe swap Tue, 03 September 2002 14:33 Go to previous messageGo to next message
They are expensive, but how do you think these would fit in a Cressida?
http://www.carbontech.com.au/IMAGES/PHOTOS/MOTOR4.JPG
And I meant specifically the extractors.
ranoo
Re: Cressida to 1uz-fe swap Tue, 03 September 2002 14:44 Go to previous messageGo to next message
Maybe turn the cressida a wiiidebody?
mx83toy
Re: Cressida to 1uz-fe swap Tue, 03 September 2002 17:26 Go to previous messageGo to next message
i've seen pics of a jzx81 (jap mx83) with pumped gurds and it looked cool just costs alot to do
ae102_3sgte
Canada
Re: Cressida to 1uz-fe swap Wed, 04 September 2002 02:11 Go to previous messageGo to next message
1UZ that I have seen have tubular steel manifolds.
Stainless, I guess, Cut and weld.
biased99
Re: Cressida to 1uz-fe swap Wed, 04 September 2002 02:53 Go to previous messageGo to next message
Soarer engines do, indeed, come in front sump application. Also, the manifolds are tubular steel and, thus, are "cuttable" and weldable.
Some other points of note re: Soarer engine (Having owned a Soarer and now, the engine from one, I can comment...
They run a hydraulic fan, so often you will get the engine with a remote reservoir for the fluid.
The manifolds are tubular but are "configured" differently each side...mine had to be cut and re-shaped on RHS to clear steering input shaft, and lengthened at the flange LHS (to match up).
They normally have "V8 Quad-Cam 32" on the lead covers, whereas the Crown engines I've seen have "Toyota" there and the reference to the V8 etc on the plenum "id" plate. The Crowns also run a clutch fan...
So, in short, for what you are doing, a Soarer engine will be fine. Make sure that you ask for an engine from a UZZ30 or 31 Soarer (NOT UZZ32, as it runs a separate pump/ancillary belt arrangement for the 4WS setup, something you wont need in an MX83 Smile )
Hope this helps.
Re: Cressida to 1uz-fe swap Wed, 04 September 2002 03:08 Go to previous messageGo to next message
I was always told the Soarer 1UZFE's were mid-sump, because I was going to be needing a front-sump when I want to put the 1UZ in the Supra...
Are you 100% totally sure?
biased99
Re: Cressida to 1uz-fe swap Wed, 04 September 2002 03:32 Go to previous messageGo to next message
Unless another of the 1UZs came with the hydraulic fan (Unlikely, as the Crown definitely came with a clutch fan and the Celsior came with a thermo), and, unless another of the 1UZs came with an "angled straight down" oil filter (Crown used a remote filter and the Celsior came with one which angled towards the front of the engine), then yes, I'm sure I got a Soarer engine and it is definitely front sump...It's gone pretty much straight onto the existing cross-member.
If anyone has (quantifiable) info to the contrary, I'm all ears.
Re: Cressida to 1uz-fe swap Wed, 04 September 2002 04:06 Go to previous messageGo to next message
Well what do you know, if a Soarer has a front sump, then that makes it so much easier to find. I know someone who has one for sale for $2200 Smile
biased99
Re: Cressida to 1uz-fe swap Wed, 04 September 2002 04:10 Go to previous messageGo to next message
Firstly, get them to actually check...That's what I did with the bloke who sold me mine!
Secondly, $2200 for what? Engine? Engine/Gearbox?
Depending on what actually comes with the deal, it may pay to shop around...I got my engine and transmission for $1500, delivered from Brisbane.
Re: Cressida to 1uz-fe swap Wed, 04 September 2002 04:12 Go to previous messageGo to next message
Its a complete Soarer front cut. And here in Perth already, where freight is usually a bitch.
I could sell off things I don't need, like the auto and panels if they are okay...
[Updated on: Wed, 04 September 2002 04:13]
ranoo
Re: Cressida to 1uz-fe swap Wed, 04 September 2002 11:49 Go to previous message
Well that makes things alot simpler if i can get a soarer motor, and mod the manifolds to suit.
Biased99, you say that the mounts nearly lined up close but which mounts are these? are they the 7m or 1uz ones?
Me thinks I'll have to go off to a import wrecker and take notes on the variations of these motors.
Also out of interest, and seeing that the crowns and the soarers have different manifolds, can the same be said for the celsior/ ls400 ie, the manifolds are the same as the soarer or are they different again?
Previous Topic:G Series Diff
Next Topic:7MGE Dizzy
Current Time: Wed Nov 18 13:12:53 UTC 2026
Total time taken to generate the page: 0.0062329769134521 seconds
