Toymods » Tech & Conversions » I need some goop
I need some goop Wed, 02 June 2004 09:05 Go to next message
I want to buy some general purpose goop that I can use for things like sumps, water pumps, thermostat housings and the like. It wont be for anything high temp or anything though, just what I listed above. Also I want a cartage type that I can put in a corking gun.
Anyone got any ideas? Thanks
people100
Rocklea qld
Re: I need some goop Wed, 02 June 2004 11:25 Go to previous messageGo to next message
The best thing i have ever found is aviation sealant. Its not for a gun but we use it at work on everything that oil or water touches and have never had a leak
Re: I need some goop Wed, 02 June 2004 11:26 Go to previous messageGo to next message
Whats it come in?
people100
Rocklea qld
also unlike selastics this stuff does not break of and clog up radiators or oil galleries
people100
Rocklea qld
Re: I need some goop Wed, 02 June 2004 11:31 Go to previous messageGo to next message
its just in a small container and when u remove the lid it has a brush on the inside..And its also good because if you spill it on your engine you can rub it off with a liuttle bit of thinners
Re: I need some goop Wed, 02 June 2004 11:35 Go to previous messageGo to next message
Damm that sounds too time consuming for me Confused
gabe
Re: I need some goop Wed, 02 June 2004 11:37 Go to previous messageGo to next message
you have probably already thought of this but whats wrong with loktite? aside from it not being in a corking gun?
Re: I need some goop Wed, 02 June 2004 11:38 Go to previous messageGo to next message
gabe wrote on Wed, 02 June 2004 21:37
Thats the only problem Very Happy
Jayem
Finland
Re: I need some goop Wed, 02 June 2004 12:01 Go to previous messageGo to next message
Würth GlueMass has done the trick in my gasket applications. This stuff is equivalent for SikaFlex. Goop comes in normal silicone tube and costs here 3-4¤. I dont know for sure if the GlueMass is the sale name there but I can check the product number.
EvilJack
Sutho/Hills NSW
Re: I need some goop Wed, 02 June 2004 12:16 Go to previous messageGo to next message
I find marine sealant from repco works quite well, its just a tube of goo basicly and it has worked well for me on the cooling system.
feral4mr2
Bundaberg, Qld.
Re: I need some goop Wed, 02 June 2004 12:35 Go to previous messageGo to next message
loctite/permatex blue maxx/ultra blue comes in a cartridge as well as the tooth paste tubes.
the avitation cement/sealant people100 mentioned is great on paper gaskets, but as far as i know isnt sensor safe like all the loctite/permatex silicone sealants.
Re: I need some goop Wed, 02 June 2004 12:55 Go to previous messageGo to next message
ask ed - he had some type of goo stuff that came in a gun cartridge.
of course, the cartridge was blocked from disuse, but new it would be great Razz
Re: I need some goop Wed, 02 June 2004 12:56 Go to previous messageGo to next message
draven wrote on Wed, 02 June 2004 22:55
Laughing Ok hopefully he will see this thread.
bbaacchhyy
Re: I need some goop Wed, 02 June 2004 14:21 Go to previous messageGo to next message
Loctite 515 , and it doesn't come in a catridge.
How much of the stuff are you planning to use ?
I have a tube of 515 that I have had for over 10 years.
The only other sealants that you need are 569 (oil fittings), 567 (water fittings), and then some hi temp silastic, and of course some anti-sieze copper stuff like Rocol or C5-A, and your set
Michael B
Re: I need some goop Wed, 02 June 2004 14:42 Go to previous messageGo to next message
I have a few sumps and water pumps, and some water housings. I was thinking something like the Loctite Copper Maxx or the Grey Maxx.
These seem to do just about everything. I only want to have to use one type if possible.
bbaacchhyy
Re: I need some goop Wed, 02 June 2004 14:52 Go to previous messageGo to next message
Not one sealer will do a good/best job at everything.
If you want to minimise the numbers, use 515 and 569 only then. The huge advantage of these is that they have no problems with water, oil or fuel.
MB
Re: I need some goop Wed, 02 June 2004 22:55 Go to previous messageGo to next message
Yeah Loctite is bad with their false advertising Confused
bbaacchhyy
Re: I need some goop Wed, 02 June 2004 23:31 Go to previous messageGo to next message
Cool1 wrote on Thu, 03 June 2004 08:55
keh ?
gold28
Madrid - Spain
Re: I need some goop Thu, 03 June 2004 00:23 Go to previous messageGo to next message
I don't know how much of an issue it is for you but a general rule for aviation is if it smells like vinegar, you don't use it on an aircraft. Roughly translated, it means that silastic based sealants (smells like vinegar) are corrosive to some alloys. I haven't thought about what alloys you would be wanting to use it on, just thought I would add my 2c worth.
feral4mr2
Bundaberg, Qld.
Re: I need some goop Thu, 03 June 2004 03:08 Go to previous message
while that is true with most general purpose silastics can be corrosive if they are not natural cure ones, the loctite/permatex RTV silicones are not the corrosive types.
http://www.easyautopart.com/Permatex_Ultra_Blue_RT V_Silicone_Gasket_Maker_3_oz.html
i do have the cartidges of Blue RTV at work if you are intested Shane.
Previous Topic:Sills repaired, drainage issues....
Next Topic:20v CV Joint Boots/Grease
Current Time: Wed Oct 21 10:54:28 UTC 2026
Total time taken to generate the page: 0.0088119506835938 seconds
