Toymods » Tech & Conversions » TA22 Auto to Manual conversion
floppy
Ipswich
TA22 Auto to Manual conversion Wed, 02 June 2004 15:59 Go to next message
Hey everyone,
I have a couple of questions about converting a TA22 from auto to manual, i have 2 complete TA22's a 74 and a 75 one being manual and the other auto (of course you say Smile
The car that the manual box is in has way too much rust so I want to swap the boxes over.
Anyway the questions are:
1. Does the auto body have all the bolt holes etc on the interior for mounting the peddle assembly?
2. I will need to use the tailshaft from the manual box on the other car right? (ie the auto tailshaft is a different size?)
I dont have any kind of manual for my TA22's so if anyone has done this before and has anything else to add to my list of questions please feel free to do so.
Oh also anyone know of someone in Ipsiwch qld, that could do some minor rust repairs for me reasonably cheaply?
Thanks in advance guys.
Grega
melbourne.victoria.austra...
Re: TA22 Auto to Manual conversion Wed, 02 June 2004 20:25 Go to previous messageGo to next message
1. yes.
2. yes. BUT depending on the diffs in your cars (they are late so they may be T series and not the POS D series i have) the flanges may not be the same.
also...have a quick look under the auto and manual body - at where the gearbox crossmember bolts to towards the outside (there are 4 holes to choose from) - see if they are indeed the same...(i suspect they will be)
you'll need the manual shifter, the starter motor, flywheel, spigot bush, clutch master cylinder and lines, prolly other stuff as well i can't think of too...but if you have both cars you'll be ok.
roger
Re: TA22 Auto to Manual conversion Wed, 02 June 2004 23:26 Go to previous messageGo to next message
Don't throw the auto cross member and tail shaft out. I am sure some one will want it for a 3tgteu conversion as the tailshaft shaft and crossmember suits the W55 manual box used
[Updated on: Wed, 02 June 2004 23:27]
ChuckLandwehr
Re: TA22 Auto to Manual conversion Thu, 03 June 2004 06:48 Go to previous messageGo to next message
Yeah I have done this conversion. '72 TA22, its all spanner work, grab all the bits and swap em over no drama's, except the yoke on the auto diff. Change the yoke on the tailshaft, or change it on the diff. Uni joint replacement will probably be required anyway, so change the yoke on the shaft.
regards Chuck.
floppy
Ipswich
Re: TA22 Auto to Manual conversion Fri, 04 June 2004 09:14 Go to previous messageGo to next message
Thanks guys,
Sounds like it isnt too bad a job considering i have 2 cars to bet the bits i need. I eventually plan to put all the running gesr from the manual car into the auto one. Engine, Diff, shocks etc as they are better ones. I want to rebuild the motor though as its been blowing some oil back up into the webbers air filter. (it may just need some good running as it has been sitting for ages) but hard to do when both are unregistered Smile
Afte the conversion I am going to put all the bits back into the rustier car and then see if anyone wants it. But that will be a while yet Smile
Got to get the rust spots fixed soonish before i do too much more mechanically. (not that much rust just i cant weld with a mig )
Anyway thanks for the advice and when its all done I will be posting some pics of the black beast
Dave aka Floppy
ChuckLandwehr
Re: TA22 Auto to Manual conversion Sat, 05 June 2004 12:23 Go to previous message
O yeah, and don't forget to by-pass the Neutral Start wire!!!!!!
Previous Topic:engine chokes on throttle (with video)
Next Topic:Power Windows on 4th Gen Not working... DOH!!
Current Time: Tue Oct 27 03:52:15 UTC 2026
Total time taken to generate the page: 0.14273619651794 seconds
