Toymods » Tech & Conversions » delete me
STR8 2.8
delete me Thu, 03 June 2004 01:53 Go to next message
finally finshed the 5mge install,
it starts, idles at about 1000rpm for about 5 seconds, then revs drop to about 700, then back up to 900 or so straight away, then down to 500 then up to about 700, and so on until it dies.
help Crying or Very Sad
[Updated on: Fri, 04 June 2004 04:45]
STR8 2.8
Re: 5mge dies after startup Thu, 03 June 2004 01:57 Go to previous messageGo to next message
im thinkin vacuum leak somewhere...
AE86slut
Baulko Hillo
Re: 5mge dies after startup Thu, 03 June 2004 02:38 Go to previous messageGo to next message
Sounds like a vacuum leak, as you said. Just go over your manifold and plenum and check that all lines and nipples are connected or blocked...... Just a guess - it could very well be something else.
BlackSupra
Re: 5mge dies after startup Thu, 03 June 2004 02:58 Go to previous messageGo to next message
also check spark plugs.
STR8 2.8
Re: 5mge dies after startup Thu, 03 June 2004 03:42 Go to previous messageGo to next message
also...
when throttle is applied, it dies instantly
Re: 5mge dies after startup Thu, 03 June 2004 04:48 Go to previous messageGo to next message
Vac leak. Even more obvious.
STR8 2.8
Re: 5mge dies after startup Thu, 03 June 2004 05:55 Go to previous messageGo to next message
its fuckin weird,
the egr vacuum modulator is missing, it seems to have two charcol canisters, and there is a vacuum feed for the dizzy, oxy sensor is not hooked up.
all toyota diagrams and haynes manual diagrams show different to this.
i dont understand it, it ran before the engine was removed from the other car...
BlackSupra
Re: 5mge dies after startup Thu, 03 June 2004 05:58 Go to previous messageGo to next message
there was a spare vacuum line at the back of the engine that had no where to go, did u find a place for it yet?
STR8 2.8
Re: 5mge dies after startup Thu, 03 June 2004 06:00 Go to previous messageGo to next message
no, all hoses are off now, i am starting again.
this thing is a mess.
side note:
sounds damn cool with no exhaust Very Happy
AE86slut
Baulko Hillo
Re: 5mge dies after startup Thu, 03 June 2004 06:02 Go to previous messageGo to next message
Vacuum feed into the dizzy would be for vacuum advance, wouldn't it? Dunno about the other crap.
STR8 2.8
Re: 5mge dies after startup Thu, 03 June 2004 06:03 Go to previous messageGo to next message
AE86slut wrote on Thu, 03 June 2004 16:02
yep, but its weird because its omitted from the diagrams in the toyota & haynes manual, only 5ME diagrams show it
STR8 2.8
Re: 5mge dies after startup Thu, 03 June 2004 06:12 Go to previous messageGo to next message
dammit glen!, why didnt we mark all the hoses before they were removed/undone
BlackSupra
Re: 5mge dies after startup Thu, 03 June 2004 06:18 Go to previous messageGo to next message
Hey dont blame me for anything, you pulled the engine out and had it in your car before i even got there....and that was 2 months ago!
STR8 2.8
Re: 5mge dies after startup Thu, 03 June 2004 07:23 Go to previous messageGo to next message
haha yeah glen its all your fault Laughing
BlackSupra
Re: 5mge dies after startup Thu, 03 June 2004 07:31 Go to previous messageGo to next message
my car hasn't been off the road for the past 2 months, so i fail to care Razz
[Updated on: Thu, 03 June 2004 07:32]
STR8 2.8
Re: 5mge dies after startup Thu, 03 June 2004 09:17 Go to previous messageGo to next message
ah geez, whata bitza,
the dizzy is actually a 5me unit, hence the vacuum advance gear.
STR8 2.8
Re: 5mge dies after startup Thu, 03 June 2004 11:09 Go to previous messageGo to next message
played with the vacuum hoses for ages,
say that the vacuum hoses are not the case,
what else could it be...
Fuel pump, fuel filter, fuel lines, spark plugs, ignition system, TPS, or the microtech wiring
the car ran fine about 2 months ago, why would the fuel pump cark it now? because its been sitting for so long?
BlackSupra
Re: 5mge dies after startup Thu, 03 June 2004 12:12 Go to previous messageGo to next message
sure you got the right relay?
STR8 2.8
Re: 5mge dies after startup Thu, 03 June 2004 12:55 Go to previous messageGo to next message
i was just thinking about that..
mayb its too small or something?
it was from a starter motor circuit i had...but wouldnt a starter need more current than a fuel pump
82MKII
Re: 5mge dies after startup Thu, 03 June 2004 13:31 Go to previous messageGo to next message
How are you driving the circuit opening (fuel pump) relay?
Stock 5MGE has a microswitch in the airflow meter that controls the circuit opening relay & hance fuel pump.
Are you still using the AFM, or is the microtech using MAP?
Maybe your circuit opening relay (& hence fuel pump) is only running when you crank the car and then drops out once you go back to normal ignition position?
Regards
Peter
PS - my 5MGE dizzy has vacum advance.
STR8 2.8
Re: 5mge dies after startup Fri, 04 June 2004 02:21 Go to previous messageGo to next message
i dont really know about the wiring side of things, it was already done so we just took the loom and stuck it in my car.
glen:
here's a twist, i took out the unknown relay and it had absolutely no affect on the starting and running of the car, it still starts easily then soon dies.
i think this may be a job for mr. auto electrician
BlackSupra
Re: 5mge dies after startup Fri, 04 June 2004 02:27 Go to previous messageGo to next message
i think the wiring may be the issue, it was uber dodge
but yeah vacumn leak as well
Are you at home? I can come over for a couple of hrs if you want.
[Updated on: Fri, 04 June 2004 02:29]
STR8 2.8
Re: 5mge dies after startup Fri, 04 June 2004 02:33 Go to previous messageGo to next message
yeh dude, thatd be sweet thanks!
im really at a loss with the vacuum lines, so i have plugged most of them.
the egr and evap systems are shot anyway, they were never working, so they are cool, but there are more vacuum holes to be fixed...
BlackSupra
Re: 5mge dies after startup Fri, 04 June 2004 02:34 Go to previous message
See you at your place inside the hr.
Previous Topic:Is this bad (block face)
Next Topic:GS300 (2JZGE) to GS400/430 (1UZFE/3UZFE) Conversion
Current Time: Sat Nov 21 05:48:29 UTC 2026
Total time taken to generate the page: 0.0054240226745605 seconds
