Toymods » Tech & Conversions » 1J PULLEY oh pulley
1jheavan
Gold Coast
icon5.gif  1J PULLEY oh pulley Mon, 02 September 2002 07:08 Go to next message
Does anybody know how to convert the pulley from the hydraulic water pump to fit the normal style pump or have a pulley available ...any help would be greatly appreciated Skull - Blink
Re: 1J PULLEY oh pulley Mon, 02 September 2002 08:49 Go to previous messageGo to next message
You can buy a normal 2JZ-GE pump from a Lexus dealer, it doesn't have any of that hydraulic crap and it bolts right in. Apparently it's also possible to remove the hydraulic mechanism from your existing pump with a bit of fiddling, but I'm not sure on the details.
deesonet
Toowoomba
Re: 1J PULLEY oh pulley Mon, 02 September 2002 10:46 Go to previous messageGo to next message
Yeah, Peter (TRD Kingswood) removed his by modifying the back of the water pump. He is always on Toymods so will probably comment on this himself.
On VL1JZ's 2nd motor (1JZ ex Soarer) it doesn't have the hydraulic fan and has a conventional water pump fitted to it. There must have been some models with hydraulics and some without.
Re: 1J PULLEY oh pulley Mon, 02 September 2002 12:22 Go to previous messageGo to next message
On a related note, after re-positioning the 2JZ in my engine bay I think there's just enough room for that fricking huge hydraulic fan. I'm going to have a crack at bolting it in this weekend - should be fun! Smile
thunderbird1
Sydney Australia
Re: 1J PULLEY oh pulley Mon, 02 September 2002 14:25 Go to previous messageGo to next message
thats right.. a soarer 1jz water pump will fix all hassles straight away. Or.. just loop the fluid like i did. My pump is fine after 8-9 months of hard driving!
Luke
666supra
U.S.A
Re: 1J PULLEY oh pulley Mon, 02 September 2002 22:55 Go to previous messageGo to next message
Can we get a picture of the water pump with out the hydraulic fan pump?
Also I like to see how you loop this Smile
[Updated on: Mon, 02 September 2002 22:58]
1jheavan
Gold Coast
Re: 1J PULLEY oh pulley Mon, 02 September 2002 23:49 Go to previous message
Heres The pic u asked for to show you the water pump some would never see this part looking at the motor as it is not to readily accessible to get off (best done when engine out!!!)
You have to remove the cam belt so in true style you might as well replace the front crank seal , cam belt, water pump then be left without the pulley on the w/p ?????? i need a solution...
A pulley solution.. No pull ME solutions......
On the left of the pic at the top is some sort of solenoid then below that is the cut hose wich is the low pressure oil and below that you can see a bolt half screwed in that is the high pressure side while to the right is the w/p that goes behind the cam belt.. I would not advise looping them as there may be a pressure buildup and the innards go wild......
Previous Topic:reconditioning a W50 box? Prices???
Next Topic:Converting a 4AFC to a 4AFE, the costs??
Current Time: Wed Nov 18 21:38:12 UTC 2026
Total time taken to generate the page: 0.0053620338439941 seconds
