Toymods » Tech & Conversions » sx tacho
crzysx
sx tacho Thu, 03 June 2004 09:30 Go to next message
Does anyone know how to get the standard seca sx dash tacho to work with an AFM 4agze computer. The problem i am having is that there is a signal from the computer but the sx tacho isnt picking it up... Would anyone have any ideas on how to redtify this problem. i htink the tacho does not want to correspond to the signal from the ecu...
Re: sx tacho Thu, 03 June 2004 12:00 Go to previous messageGo to next message
Do a search, I've posted about this before. Basically, all you need is 3 diodes to connect the - side of both coils together, or if you've got a GZE with a dizzy, the - side of the coil can be connected straight to the tacho wire.
crzysx
Re: sx tacho Thu, 03 June 2004 12:37 Go to previous message
yer how will that work when the standard tacho runs off the ecu. what items will i need so that the tacho runs off the ecu and works. i tried searching and it only had sixworks selling the tacho booster item. has it been covered with a diagram before at all.
Previous Topic:GAB CoilOver Suspension units
Next Topic:Genuine Valve Stem Seals - $187.44 - should i go aftermarket?
Current Time: Sat Nov 21 04:07:24 UTC 2026
Total time taken to generate the page: 0.024423837661743 seconds
