Toymods » General Car Talk » plugs to use in 2tg/3tc hyrbid
jesseT18
Castle Hill, Sydney
plugs to use in 2tg/3tc hyrbid Thu, 03 June 2004 09:48 Go to next message
what plugs are right for this engine?
3tc plugs?
2tg plugs?
3tgte plugs?
or other ones?
YelloRolla
On your mum!
Re: plugs to use in 2tg/3tc hyrbid Thu, 03 June 2004 15:23 Go to previous messageGo to next message
I would use 2TG plug (if going by the book), otherwise start with NGK BPR5EY.
jesseT18
Castle Hill, Sydney
Re: plugs to use in 2tg/3tc hyrbid Fri, 04 June 2004 09:45 Go to previous messageGo to next message
thanks, what are the 2tg plugs? as you can see by my signature, i really need a manual!
the plugs in the engine when i got it were BP6ES, that them?
[Updated on: Fri, 04 June 2004 09:46]
YelloRolla
On your mum!
Re: plugs to use in 2tg/3tc hyrbid Fri, 04 June 2004 13:54 Go to previous messageGo to next message
They will do. BP6ES is a slightly colder plug and is probably more suited to wide open and high RPM use (I use BP7ES to BP9ES for my turbo application).
The P stand for projected nose - I believe that these are necessary for the 2TG, 3TG and 18RG.
The number = the heat range (with NGK the colder the plug, the higher the number)
An "R" after the heat range number denotes that is a resistance type plug.
S = normal electrode
Y = electrode has a vee cut in it (for apparently improved flame propagation)
Play with the different plugs until you find one that suits you.
jesseT18
Castle Hill, Sydney
Re: plugs to use in 2tg/3tc hyrbid Sat, 05 June 2004 04:57 Go to previous messageGo to next message
thanks ALOT for that buddy
wil8115
Seattle area, USA
Re: plugs to use in 2tg/3tc hyrbid Sat, 19 June 2004 02:45 Go to previous message
NGK BPR6ES is what is in my Toyota T series engine manual.
you could "index" the plugs to. Aim the Eletrode opening towards the front of the engine on all 4 cyls. this will help at uppers revs as the spark is exposed to the A/F mixture better. hth.
Previous Topic:Poll: Shaker on an ma61
Next Topic:Wheels
Current Time: Fri Nov 20 15:33:39 UTC 2026
Total time taken to generate the page: 0.0053548812866211 seconds
