Toymods » Tech & Conversions » Whats the deal with 1GZFE
icon5.gif  Whats the deal with 1GZFE Mon, 02 September 2002 07:24 Go to next message
Ok guys, I need the low-down on the 1GZFE.
Basically, I've got it down to this:
5l Quad-Cam 48 valve V12 with "206kW".
I'd be guessing it'd be constructed along similar engineering scrutiny that made the 1UZFE as good as it is.
Anyone know what its "real" power output is? Any other stats, ie. injector sizes? Any ideas on the dimensions on the thing? This isn't for me, someone I know is interested in finding one for a kick arse project!
BTW, does anyone know which importers actually import them?
Thanks,
Nathan
biased99
Re: Whats the deal with 1GZFE Mon, 02 September 2002 13:12 Go to previous messageGo to next message
As with most of the "upper-end" Jap engines, the 206KW figure refers to the gentlemans' agreement the Japanese manufacturers have...the actual power output would be speculation and nothing more, although I'd be very suprised if it wasn't way in excess of the quoted figure. (That is, unless they've detuned it to buggery!!)
From the little I've read (and, believe me, there IS precious little to read!) they are engineered along similar lines to the 1UZ,(although they do not look alike - the 1GZ looks considerably larger!)
As for a project, I'd suggest that there would be very little here that you'd squeeze one into, although I wouldn't write it off arbitrarily.
Your biggest problems will be these:
1) You will struggle to find one. Anywhere. They only came in the '97-on Century Crown, of which there are precious few. I don't believe that there is one in Australia (but I could be wrong!)
2) You will probably be able to obtain parts (through OldMac Toyota or similar), but you will need the full model and frame numbers of the donor car - in other words, get a half-cut, if you can find one. Oh, and the parts will be VERY expensive.
It sounds like an excellent project, if your friend can make it work...
Re: Whats the deal with 1GZFE Tue, 03 September 2002 06:29 Go to previous messageGo to next message
an educated guess would be in the vicintity of 330-370bhp .... decent for a n/a, but realistically you'd be better off with a 2jz-gte
Re: Whats the deal with 1GZFE Tue, 03 September 2002 06:31 Go to previous messageGo to next message
depends what your after. Hes after an awesome NA engine. He doesn't want a 1JZ or a 2JZ.
Re: Whats the deal with 1GZFE Tue, 03 September 2002 06:38 Go to previous messageGo to next message
fair enough then
Who wants some?
icon14.gif  Re: Whats the deal with 1GZFE Sun, 14 November 2004 10:41 Go to previous messageGo to next message
Hi I'm no genius, but I was thinking of installing this engine into my supra. Alternatively, I was going to get a 1UZ stuff it in & later supercharge(or supracharge Rolling Eyes ) it.
Which would result in a better performance beast??? Razz
Jag7799
Re: Whats the deal with 1GZFE Sun, 14 November 2004 10:49 Go to previous messageGo to next message
there are a few in australia
and also some older 5f ve ones or whever its called..
FKN16V
NSW, East Coast
Re: Whats the deal with 1GZFE Sun, 14 November 2004 11:35 Go to previous messageGo to next message
According to an old Zoom mag i have
1GZ-FE
Type: 4996cc EFI DOHC 48-valve V12
Power: 206kW @ 5200rpm
Torque: 481Nm @ 4000rpm
Gearbox: Floor or column-shift RWD 4sp Auto
Source: 1997-on Toyota Century.
Thats all i know
Hope it helps a little.
Steve
stark
Re: Whats the deal with 1GZFE Sun, 14 November 2004 13:39 Go to previous messageGo to next message
From what ive seen... The 1GZFE is not based on the 1UZ at all..
Its a 60 degree engine unlike the 1uzfe which is 90 degrees...
Its bore and stroke are not similar to any of the UZ series engines either...
Muck of its percieved width is from the inlet manifolds which sort of go over the rocker covers and then go back inwards.
I do belive it is a 6 bolt mains however,,,
For similarities I would start to look at toyotas 60 degrees v6's such as the 1MZFE etc which in my opinion is a much closer match to the 1GZFE
R-jay
Re: Whats the deal with 1GZFE Sun, 14 November 2004 14:27 Go to previous messageGo to next message
knew a guy who knew a guy who had one.... hehe
anyhow, halfcut was had for 20 something odd $k's... very very pricey...
engine wise, it's spectacular with huge potential....
6 bolt mains, undersquare, vvti, v12.... you can fit one in a supra without too much trouble due to the 60 degree V....
and imagine a turbo on each side.....
Re: Whats the deal with 1GZFE Sun, 14 November 2004 23:39 Go to previous messageGo to next message
Haha, 206kW my arse Razz
Re: Whats the deal with 1GZFE Mon, 15 November 2004 00:21 Go to previous messageGo to next message
$20k for a front cut is pretty steep... I know of an engine/gearbox package which sold for $1500 in Japan. These things are very rare though, that's the only one I've ever heard of for sale.
wagonist
Toymods Club Treasurer
Re: Whats the deal with 1GZFE Mon, 15 November 2004 01:37 Go to previous messageGo to next message
These things are rare.
If your mate is not worried about brand, you'd probably be better off trying to find a BMW 5.0 V12 instead from the 850i.
A lot more of these were made (in Europe though), although parts prices would be up there too.
Soarer
Wollongong
Re: Whats the deal with 1GZFE Mon, 15 November 2004 04:27 Go to previous messageGo to next message
Apparently you can order an engine package from Toyota Japan for a measly $25k AUS.
ZZT231
melbourne.vic.au
Re: Whats the deal with 1GZFE Mon, 15 November 2004 05:20 Go to previous messageGo to next message
Norbie wrote on Mon, 15 November 2004 11:21
*Kicks Norbie* Then why the hell did you do the 2JZ conversion then? Razz
I wish someone actully got hold of the engine (not possible with me as I am a young Uni Student Sad ) as myth would be put to rest.
Cheers.
Corona RT142
Campbelltown
Re: Whats the deal with 1GZFE Mon, 15 November 2004 05:24 Go to previous messageGo to next message
lloking at the torque figures i'd be guessing at about 240-270kw. Depends on the nature of the enigne though ie rev happy high hp output or lazy engine aka old holden v8 with fat torque curve.
Re: Whats the deal with 1GZFE Mon, 15 November 2004 05:47 Go to previous messageGo to next message
The engine was built to be lazy, smooth and torquey. It is fitted in a huge luxo-barge after all.
Re: Whats the deal with 1GZFE Mon, 15 November 2004 07:09 Go to previous messageGo to next message
That said, like the late model 1UZ's, they can be both lazy and torquey and f'ing powerful all in one. Beauty of variable length inlets and infinitely variable valve timing.
JAZE
cronulla
Re: Whats the deal with 1GZFE Mon, 15 November 2004 08:20 Go to previous messageGo to next message
good luck with the wiring, the car it comes in runs countless different control ecus, the engine alone has one ecu for each bank of cylinders, then would come the auto ecu which would be infinately linked to the main ecus, you would have to have a very good half cut and then a wiring genius and heaps of cash, or order a top of the line motec and borrow one of aussies best tuners to even have a chance at getting it to run well.
This motor is not ever going to be a realistic option, it is the 'one that got away' story of the toyota modifiers world. no matter how many threads pertain to it and brag of intentions of a crazy conversions, just like an urban myth, it fades into the background untill the next time someone knows someone who knows someone who has met someone who can get one from japan, or is going to find one whatever it takes.
not meaning to be cynical, but if you or your mate can get one ill give you a full set of flares and guards for your supra, ( and dont say you dont love them, denial is futile Laughing )
good luck Cool
Bill Sherwood
Brisbane / Gold Coast
Re: Whats the deal with 1GZFE Mon, 15 November 2004 13:47 Go to previous messageGo to next message
FWIW they do have a 6-bolt bottom end. Just been reading the workshop manual I got for one. Wink
Who wants some?
Re: Whats the deal with 1GZFE Tue, 16 November 2004 04:21 Go to previous messageGo to next message
Who wants some? wrote on Sun, 14 November 2004 21:41
Can someone please answer my question Crying or Very Sad?????
Re: Whats the deal with 1GZFE Tue, 16 November 2004 04:26 Go to previous messageGo to next message
Who wants some? wrote on Tue, 16 November 2004 15:21
do you have a 1GZ in your garage?
if not, the 1UZ will be better, as it actually 'exists' and you can buy them easily Wink
Re: Whats the deal with 1GZFE Tue, 16 November 2004 04:27 Go to previous messageGo to next message
Agreed. No-one here has seen a 1GZ, much less modified one, so your question cannot be answered. Get the 1UZ.
c2888
Re: Whats the deal with 1GZFE Tue, 16 November 2004 05:08 Go to previous messageGo to next message
I'm so bored, so i searched a little.
http://jnc.narod.ru/data/tnews/century.html
http://toyota.jp/Showroom/All_toyota_lineup/Centur y/mechanism/index.html
http://toyota.jp/Showroom/All_toyota_lineup/Centur y/mechanism/index1.html
Not much of a picture, but a picture non the less
http://toyota.jp/Showroom/All_toyota_lineup/Century/mechanism/images/mecha01.jpg
http://toyota.jp/Showroom/All_toyota_lineup/Century/mechanism/images/mecha17.gif
looks like theres 400nm from 1000rpm Very Happy
dodgydan
[Updated on: Tue, 16 November 2004 05:12]
Re: Whats the deal with 1GZFE Tue, 16 November 2004 06:15 Go to previous messageGo to next message
Better pics:
http://members.optusnet.com.au/norbee/V12_1.jpg
http://members.optusnet.com.au/norbee/V12_2.jpg
That's the one that sold for $1500.
bbaacchhyy
Re: Whats the deal with 1GZFE Tue, 16 November 2004 06:17 Go to previous messageGo to next message
Holy mother of god is that some complicated inlet piping !!!!!
Strip the crap out of it, remove the plenum and make your own and it would look nice .....
Re: Whats the deal with 1GZFE Tue, 16 November 2004 06:21 Go to previous messageGo to next message
Two dual-entry plenums hanging on either side of the engine, it's not that bad! Would make it easy to set up quad throttles though.
ChuckLandwehr
Re: Whats the deal with 1GZFE Tue, 16 November 2004 07:09 Go to previous messageGo to next message
Forget the look of the intake, just look at that TORQUE Twisted Evil
I have various parts of my anatomy, that I would gladly trade for that engine.
regards Chuck.
JAZE
cronulla
Re: Whats the deal with 1GZFE Tue, 16 November 2004 09:22 Go to previous message
looks horn and comes with a front sump,
thats one sweet white unicorn
ur never going to live that down norbie Confused
but good that u got the pics at least Razz
Previous Topic:4AGZE 'sneezes' on cold start HELP
Next Topic:how low can compression be before engine wont run..
Current Time: Sat Nov 21 05:01:34 UTC 2026
Total time taken to generate the page: 0.015887022018433 seconds
