Toymods » Tech & Conversions » gearbox
Satoshi
gearbox Thu, 03 June 2004 22:03 Go to next message
i encounter difficulties engagaging into 1st and 2nd gear..it does not engage smootly..many times i have to try a few times for it to get into gear..this happens 50% of the time i'm driving..
at traffic lights...it is smooth..
any reason why this happens?
takai
Re: gearbox Thu, 03 June 2004 22:28 Go to previous messageGo to next message
2 words for you
SEARCH
and
synchromesh
Cyber-punk
Brisbane, QLD
Re: gearbox Fri, 04 June 2004 09:31 Go to previous messageGo to next message
i'd say it sounds like worn synchro's
just wait till it starts popping out of gear...that becomes interesting :/
shinybluesteel
melbourne
Re: gearbox Fri, 04 June 2004 09:52 Go to previous messageGo to next message
the car i was driving for a while ran out of syncromesh, but we euthanised it before it became a big problem.
can you buy it in bottles to top up the gearbox with?
i think i saw it in autobarn next to the blinker fluid.
takai
Re: gearbox Fri, 04 June 2004 10:09 Go to previous messageGo to next message
Must be too much dorifto
http://members.optusnet.com.au/gianttomato/Sprints/driftbattle.jpg
Satoshi
Re: gearbox Fri, 04 June 2004 10:18 Go to previous messageGo to next message
it might be the cold weather before sunrise..
drove it in the evening just now its not as bad as in early morning
someone mind explaining syncromesh to me?
if yer gonna ask me to use the search button then just DONT BOTHER REPLYING...
Cyber-punk
Brisbane, QLD
Re: gearbox Fri, 04 June 2004 10:28 Go to previous messageGo to next message
synchromesh gears allow you to shift even if the input and output shafts are rotating at a different speed, thus negating the need to double clutch(which is matching the input and output shaft speeds before engaging into a gear)
from dodgy memory and trying to simplify it, the input shaft and output shaft meet before they engage, so as to match speeds
i'll try find a picture for you as i cant properly articulate myself for some reason :/
[Updated on: Fri, 04 June 2004 10:31]
Cyber-punk
Brisbane, QLD
Re: gearbox Fri, 04 June 2004 10:33 Go to previous messageGo to next message
http://static.howstuffworks.com/gif/transmission-synchronizer.gif
the little blue cone bit to the right of the blue gear fits into the collar part...thus spinning both at the same speed before the gear fully engages
or something to that effect...i think
YelloRolla
On your mum!
Re: gearbox Fri, 04 June 2004 13:34 Go to previous messageGo to next message
Synchros will work less effectively if the oil is too viscous. Double de-clutching is a good way to overcome the issue (easy with practise).
May I ask why you are so averse to being given directions to use the search function? Do you think that someone else should search and then hand the answer to you?
The answers to all things automotive have been published a million times in as many publications. Most of my knowledge (precious little that there is) has been gleaned from reading and having a go and asking people who are in the know.
Satoshi
Re: gearbox Fri, 04 June 2004 20:11 Go to previous message
i just needed to know whether my gearbox has abit of problem or because its due to the cold weather..
i'm sure using the search method is good. But just to find out opinions on what people would like to say as we all know new members register each day (or at least)...
if a forum is all about searching back the old threads...where's the fun then? do i only post up a new topic when other areas HAVE NEVER been covered before?
as u can see i post this topic at 7.33am as i'm still awake trying to finish up my assignments..too much of reading till i cant think properly...so that's why i just post up this thead without doing a FULL search...
i did found out about double clutching (never knew it existed) when i search from syncromesh ...but i dont think it cost u anything to explain what problem u think i might have with my gearbox will ya? Smile
cyberpunk: thanks for the information...i'm sure everyone learns better when they are actually teaching.. Very Happy
Previous Topic:4a-gze knock sensor
Next Topic:has anybody rebuilt a 1jz?
Current Time: Sun Nov 1 05:45:53 UTC 2026
Total time taken to generate the page: 0.0049769878387451 seconds
