Toymods » Tech & Conversions » engine chokes on throttle (with video)
STR8 2.8
engine chokes on throttle (with video) Fri, 04 June 2004 04:49 Go to next message
5MGE is now running, (using the shorted fuel pump check connector, as afm has been replaced with map)
when throttle is applied, engine dies/chokes and revs drop dramatically, if you apply the throttle very gently it can speed up. revving the engine constantly results in what seems like a backfire through out the intake...
i think the engine could be drowning in fuel, exhaust is spitting out liquid (could be fuel not sure), and smoke is coming from exhaust manifold (could be unrelated Rolling Eyes )
any ideas ppl?
p.s. thanks for ur help glen
[Updated on: Sat, 05 June 2004 10:35]
YelloRolla
On your mum!
Re: engine chokes on throttle Fri, 04 June 2004 06:20 Go to previous messageGo to next message
The problem that you describe is from a lean condition - not a fat condition.
Bad timing could cause similar issues (points gap too close etc etc etc)
[Updated on: Fri, 04 June 2004 06:21]
STR8 2.8
Re: engine chokes on throttle Fri, 04 June 2004 06:22 Go to previous messageGo to next message
why does it backfire or make such a noise
BlackSupra
Re: engine chokes on throttle Fri, 04 June 2004 06:36 Go to previous messageGo to next message
http://www.geocities.com/vwresource/air_inleakage
Re: engine chokes on throttle Fri, 04 June 2004 06:37 Go to previous messageGo to next message
Video love: http://users.bigpond.net.au/justcallmefrank/5mge.a vi
STR8 2.8
Re: engine chokes on throttle Fri, 04 June 2004 06:41 Go to previous messageGo to next message
hmmm, that vid doesnt really do the shitty problem justice Laughing
Re: engine chokes on throttle Fri, 04 June 2004 06:44 Go to previous messageGo to next message
Don't look at me, i'm just hosting it Wink
BlackSupra
Re: engine chokes on throttle Fri, 04 June 2004 07:10 Go to previous messageGo to next message
there is a backfire at 9.5 seconds
EDIT: update title to say there is a video a well
[Updated on: Fri, 04 June 2004 07:10]
Re: engine chokes on throttle (with video) Sat, 05 June 2004 11:22 Go to previous messageGo to next message
As Jason mentioned it could be a timing issue, but that's easy enough to check. My money is on a VAC LEAK causing it to lean out. Pay special attention to the area between the throttle body and the AFM; I had a leak there once on my 6M and it did exactly what you're describing. Took me ages to figure out what it was because the leak was in a hard to find spot!
STR8 2.8
Re: engine chokes on throttle (with video) Sat, 05 June 2004 12:46 Go to previous message
just had a thought, there is a large pipe connecting the egr system to the 6th exhaust port, it was undone, and i just tightened it breifly with fingers the other day, could this be the source of thou evil woringdoing vacuumus leakus Shocked
timing will be checked soon enuff too tho.
afm is gone tho, now using map.
thanks for your help so far guys! Very Happy
[Updated on: Sat, 05 June 2004 12:49]
Previous Topic:Why is my car going through so much oil?
Next Topic:TA22 Auto to Manual conversion
Current Time: Mon Oct 26 18:31:52 UTC 2026
Total time taken to generate the page: 0.066004991531372 seconds
