Toymods » Tech & Conversions » 1JZ Water Pump and pulley
1jheavan
Gold Coast
icon10.gif  1JZ Water Pump and pulley Mon, 02 September 2002 08:16 Go to next message
Does any person have a pulley from a 1jz water pump or know how to convert the pulley from the hyrdaulic/water pump to suit normal w/p.. the hydraulic pump goes to the thermo fans so i pulled it off and fittd a 2j water pump now i need a pulley solution can you help please ....
JZZ30MAN
Re: 1JZ Water Pump and pulley Tue, 17 December 2002 04:07 Go to previous messageGo to next message
I'm about to change my 1jz water pump, non hydraulic, with the same as my old one is leaking. This looks like a really difficult job. I have done a lot of reasearch and pretty much know how to do it, but would appreciate a little advice.
Re: 1JZ Water Pump and pulley Tue, 17 December 2002 04:21 Go to previous messageGo to next message
I'm about to do much the same thing on my 2JZ-GTE. I'm just buying a whole new water pump from a Lexus dealer - any Lexus with a 2JZ-GE (eg GS300) will have a conventional water pump without any of the hydraulic crap, and it will bolt right in. I'm not sure if it comes with a pulley though, will have to check.
JZZ30MAN
Re: 1JZ Water Pump and pulley Tue, 17 December 2002 04:43 Go to previous message
Norbie, Your lucky that the MKIV website has the procedure from the manual poster for the timing belt and diagrams of the pump etc. Note that there are a few extra o-rings required on 1jz and maybe 2jz between the pump and the water outlet housing (to top rad hose).
I suggest you do your research carefully and make sure you have all the bits. I'll be short the o-rings but i'll try and buy an assorted box load so I can find one that will fit. Toyota don't stock them.
Some people say to change water pump, timing belt, idler pulley, tensioner, cam seals & crank seals at same time. Also top & bottom radiator hoses & thermostat. I'm skipping the seals and the tensioner. Tensioner not available and seals not really necessary unless leaking, I hope anyway.
Previous Topic:18RGEU to 18RGRTU???
Next Topic:Springs: T18 vs AE86?
Current Time: Sat Nov 21 01:50:53 UTC 2026
Total time taken to generate the page: 0.0053000450134277 seconds
