Toymods » Tech & Conversions » 4ag injector removal help?
Hunty
4ag injector removal help? Fri, 04 June 2004 07:31 Go to next message
hi, is there anything special i should know about before i try to pull my injectors out to get cleaned??
Thanks guys
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: 4ag injector removal help? Fri, 04 June 2004 07:35 Go to previous messageGo to next message
take the rail off, un plug them and pull them out
not hard Wink
HighRolla
Re: 4ag injector removal help? Fri, 04 June 2004 07:41 Go to previous messageGo to next message
Disconnect battery so don't get a spark..take fuel cap off to relieve a little pressure. Check
http://www.twincam.org/forums/index.php?showtopic= 5205
RobertoX
Re: 4ag injector removal help? Fri, 04 June 2004 08:29 Go to previous messageGo to next message
need to relieve the pressure in the fuel lines first i think, dont want a petrol shower... Rolling Eyes
you will need to kill power to the fuel pump somehow... take out fuse, relay whatever... Then start engine up, it will run then die after a few seconds after fuel pressure is gone...
Hunty
Re: 4ag injector removal help? Fri, 04 June 2004 10:27 Go to previous messageGo to next message
Sweet, thanks guys
engine has been sitting around for about 10-12 months, ive just finished bolting it all into my rolla, wanted to get the injectors cleaned before i get it all wired up. So no dramas about fuel pressure. It's just i dont have a manual for the t/c only the carby. so i wasnt sure if there were any little tricks, dodgy clips or anything that i should be a ware of, looks like i'll just give it a go 2moro
Cheers!
kingmick
Banned by his request
moved to tamworth
Re: 4ag injector removal help? Fri, 04 June 2004 12:06 Go to previous message
taking them out is the easy part! make sure you vasaline the orings before you put them back in and do it gently and make sure you align injectors to the rail aswell and head bosses properly so you dont pinch the oring. dont over tighten the rail bolts as it alloy the bolts bite into.
mick
Previous Topic:Aw11 rack play
Next Topic:Good 4AG/GZE SPECS PAGE
Current Time: Sun Nov 1 20:15:14 UTC 2026
Total time taken to generate the page: 0.0039980411529541 seconds
