Toymods » Tech & Conversions » TA22
badboybubby
On Probation
icon5.gif  TA22 Fri, 04 June 2004 14:25 Go to next message
Im needin a suspension setup any suggestions? ie:shocks springs thinkin cheap heh heh anyone got stuff to sell?? Smile
schmitt
Re: TA22 Sun, 06 June 2004 23:41 Go to previous messageGo to next message
no i dont but i just thought your post looked a bit empty compared to the others. go to midas or pedders and get a qoute they are usually pretty good.
Grega
melbourne.victoria.austra...
Re: TA22 Mon, 07 June 2004 19:17 Go to previous messageGo to next message
don't go to pedders
get king springs - $130 a pair
get monroe gt gas - $90 for the rear $180 for the front
then save up and go to whiteline, and get front and rear swaybars - i think $150 each or something?
SeptemberSquallIndustries
Re: TA22 Tue, 08 June 2004 09:03 Go to previous messageGo to next message
Wait.
Are your bushes and steering gear in good condition?
First inspect and if necessary replace the following;
  • tie rod ends (inner and outer)
  • idler arm
  • pitman arm
  • front control arm bushings
  • lower ball joints
  • radius strut bushings
  • rear trailing arm bushings (upper and lower)
  • rear damper upper bushings
  • lateral rod bushings
If these are in poor condition they should be replaced first; why build a nice house on sand?
(If you're not clear what these parts are or what they do it's a good idea to learn.)
Then consider whether you're happy with stock brakes, as a front brake upgrade will almost definately require a strut change which will in turn affect your spring and damper selection.
With these factors addressed you could consider your application for the car. Grega has suggested King springs; the $130 off-the-shelf King springs will be progressive rate, probably approximately 80-170lb or similar. Are progressive rate springs what you want or do you want linear springs?
What spring rate would best suit your desired application?
What dampers will you use to adequately control this spring?
Suggestion: If you do some research and work on the car yourself you'll learn a lot and get exactly what you want when you do come to spend your money.
Things done right are rarely cheap as such; by doing some research (see 'suggestion' above) you can get value for your money, and that's just as good.
I'm refitting a suspension system for my TA22 for street/track use at the moment please feel free to PM me! If you're really "thinkin' cheap" you can borrow my angle grinder on the proviso that you don't drive around near me again. Shocked
KYB's are also available for a bit more than that ~ KYB, Monroe and Pedders are probably your only straightforward options.
I heard that Pedders dampers are made under licence by Monroe; I'm not sure whether the product is the same or not though, the Pedders/Monroe units may comprise different parts.
Re: TA22 Wed, 09 June 2004 07:51 Go to previous messageGo to next message
Oops did I kill the thread?
-NiCkeL-
Melbourne, Victoria
Re: TA22 Thu, 10 June 2004 06:31 Go to previous messageGo to next message
You pretty much covered everything... Very Happy
I have never had to replace pitman and idler arms, how hard is it to do, or would you take them to a reconditioner to do it? Every Celica that I have seen always seems to have an average steering box...
Re: TA22 Thu, 10 June 2004 09:00 Go to previous messageGo to next message
Play in the steering may be box, or idler/pitman links as you've identified.
Easy enough when you're doing them both especially. You're in Melbourne too, come round and we can do it some afternoon if you like.
Don't take them to a reconditioner; I doubt you'd even get someone to take on the job as they're not really servicable parts and cost less than $130 all up for new replacements for both??
-NiCkeL-
Melbourne, Victoria
Re: TA22 Fri, 11 June 2004 10:21 Go to previous messageGo to next message
I don't have a Celica at the moment, but thanks for the offer! I have just bought a project shell, so when I get close to completing that, I might seek your assistance!
Will you be coming to the Classic Celica Club meet on the 20th of June?
Re: TA22 Sun, 13 June 2004 06:31 Go to previous messageGo to next message
What meet is that?
-NiCkeL-
Melbourne, Victoria
Re: TA22 Sun, 13 June 2004 06:47 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=37389&start=0&rid=4921&S=030adf55ebf 36ea153743e6e7ebf8142
Re: TA22 Sun, 13 June 2004 06:49 Go to previous messageGo to next message
See what I can do; right now even the mighty ST141 Corona isn't mobile... =/
-NiCkeL-
Melbourne, Victoria
Re: TA22 Sun, 13 June 2004 06:56 Go to previous messageGo to next message
That's not good to hear...where abouts are you from in Melbourne? If you are close by, I could pick you up... Smile
Re: TA22 Sun, 13 June 2004 06:58 Go to previous messageGo to next message
I'm in Murrumbeena.
-NiCkeL-
Melbourne, Victoria
Re: TA22 Sun, 13 June 2004 07:31 Go to previous messageGo to next message
Where is that in relation to the city?
Re: TA22 Mon, 14 June 2004 08:46 Go to previous message
Middle South-East area. Close to Caulfield and Malvern.
Previous Topic:TA22 rear disc brakes
Next Topic:wierd shudder
Current Time: Sun Nov 1 00:19:58 UTC 2026
Total time taken to generate the page: 0.026352882385254 seconds
