Toymods » Tech & Conversions » Best Camber kits?
CamryMan
Best Camber kits? Sat, 05 June 2004 04:48 Go to next message
Anyone care to comment on their experiences of using camber kits? Turns out my car has 0.7+ camber on the front passenger side. Really can't imagine how that happened since the last time it was check a few years ago it was 0.2- .
Been think about a Kmac camber kit. Haven't called whiteline yet because it's a weekend. Any other suggestions?
Do I need to get camber kits for the rear as well if I dial up the negative camber?
[Updated on: Sat, 05 June 2004 04:50]
Fattony
Re: Best Camber kits? Sat, 05 June 2004 09:28 Go to previous messageGo to next message
Ok i would not use a k-mac camber kit, they are just shit. They fall out of alignment very easily due to the fact that they use rubber not metal, i use a noltec camber kit in my car they are worth a bit more, but atleast you can dial some negative camber out of it and it doesnt fall out when you go over a speed hump.
CamryMan
Re: Best Camber kits? Sun, 06 June 2004 01:01 Go to previous messageGo to next message
Thanks for that. I'll call them on Monday and see what they have to say.
Re: Best Camber kits? Sun, 06 June 2004 09:06 Go to previous messageGo to next message
Mate go with Noltec. I've also heard bad things about K-Mac.
I got a set of Noltec camber/caster adjusters on my RA28 and been good so far.
Also if you are a Toymods member you get a 25% discount!
So if you arn't, join up! You will save money for sure if purchasing something as expensive as camber adjusters.
omegaman
SYDNEY
Re: Best Camber kits? Thu, 10 June 2004 07:46 Go to previous messageGo to next message
Thanks guys,
I've just picked up a set for my ra28, yes, they are noltec.
I had ordered a set from kmac to be made up and ready today. But I rang them a went past and had a look, heaps better.
Theres 2 types for street & rally. The difference is steet has some rubber for a slightlier comfy ride and spring rated to 350lbs, where as rally is a solid centre, same price $450 inc gst RRP Stock no.(N44027). I got it for way less. Just by looking at them they look heaps stronger and will last you heaps longer than Kmac. Smile
Fattony
Re: Best Camber kits? Thu, 10 June 2004 07:50 Go to previous messageGo to next message
Yeah i have the rally set in my car, didnt want that rubber crap in my camber kit purely cause thats what makes the camber kits stuff up, i paid $500 for it, but that was fitted and inc wheel alignment so i think i got a half decent deal and i must say after seeing the trouble some ppl have had with k-mac (as soon as you drive it out of the susspension place after a wheel alignment) the thing feels fine for 5 mins then falls out of alignment.
omegaman
SYDNEY
Re: Best Camber kits? Thu, 10 June 2004 08:03 Go to previous messageGo to next message
When you actually look at the alternative you see how shit it kmac would be, the speed humps,hitting foot paths and just hard cornering would put heaps off strain on the kits.
To me it was a good buy.
EMP-2TG
Carlingford, Sydney
Re: Best Camber kits? Thu, 10 June 2004 12:20 Go to previous messageGo to next message
i got a kmac kit and its been fine
ive had wheel aligments with it in and they havent changed much at all. my car is fairly stiff as well... but i was prob just lucky Smile
wagonist
Toymods Club Treasurer
Re: Best Camber kits? Fri, 11 June 2004 06:04 Go to previous messageGo to next message
Have any of you guys heard anything about castor kits?
The front camber on my car is fine, Whiteline installed a camber kit into it, but I want to increase the castor for better turn in.
The only way I can think of would be a strut top adjustment, just along the car instead of across it like a camber kit.
Re: Best Camber kits? Fri, 11 June 2004 06:13 Go to previous messageGo to next message
can rotate a strut top camber kit so that the adjustment runs at any angle you want...
my home made ones have the adjustment running at 45 degrees, so i have 20mm more castor and camber at the strut top.
on commerical strut tops tho, the bolt position may be an issue.
wagonist
Re: Best Camber kits? Fri, 11 June 2004 06:18 Go to previous messageGo to next message
My strut tops have 3 bolts to fix them to the car, but they can't be turned around.
this would probably need a custom job then?
If so, where would be recommended?
Re: Best Camber kits? Fri, 11 June 2004 06:29 Go to previous messageGo to next message
Mate can't comment on your car as never worked on one.. But most cars have a radius rod that can be adjusted to pull the control arm forward and adjust the castor.
Otherwise, you can get strut tops (such as Noltec) that allow camber and castor adjustment.
Joel
wagonist
Re: Best Camber kits? Fri, 11 June 2004 06:35 Go to previous messageGo to next message
So the Noltec ones allow for both movement?
Perfect.
I'm hoping to go 4wd soon & I want to increase the camber on the front as well. The current Camber pins are on their max adjustment.
I have the same strut tops as Celicas, so hopefully these may be on the shelf.
Most modern cars like mine don't have a separate radius rod, rather the lower control arm is hinged on the car in 2 different spots.
Re: Best Camber kits? Fri, 11 June 2004 06:48 Go to previous messageGo to next message
Yeah the Noltec items I got for my RA28 are camber & castor adjustable.
Joel
omegaman
SYDNEY
Re: Best Camber kits? Fri, 11 June 2004 07:09 Go to previous messageGo to next message
Turbor28 this ones for you, or any one for that matter.
Since I've just bought the noltec kit, one thing puzzles me.
When the kit is fitted where does the actual spring cradle into at the top. Doesn't the ra28 have a cradle where the spring sits and the small hole for the shock shaft to go through and then this all fits under the tower then bolts in? Is this cradle replaced with the c/kit and if so where does the spring now cradle into. May be a silly ? but I have not checked it out yet? Anyone???
Fattony
Re: Best Camber kits? Fri, 11 June 2004 07:30 Go to previous messageGo to next message
Omegaman the notec kit forms the cradle for the top part of the spring.
Wagonist the notec kit allows for camber and castor adjustment becuase they form the sturt top, and i think you will find it you want a sharper turn in that you would want you castor closer to zero from the +ve side, but be carefull when doing this as it will effect high speed turn in ability of the car and make it a real handfull to drive at high speeds due to the fact your turn in aint as smooth and this will throw the car around more, particialy the back end, thats somethign to think about before doing harsh adjustments on castor.
omegaman
SYDNEY
Re: Best Camber kits? Fri, 11 June 2004 07:39 Go to previous messageGo to next message
Fattony, thanks it was just a ? I needed answered so I can sleep till I take it apart. As for the adjustment thanks for the advise. The speed advise I'll think about on tuesday when the double demerits points are over, just in case there watching. Thanks.
Lambolica
Northwestern Sydney
Re: Best Camber kits? Fri, 11 June 2004 07:59 Go to previous messageGo to next message
Any pictures of the kit in and out of the car???
Sounds Interesting...
Fattony
Re: Best Camber kits? Sat, 12 June 2004 02:36 Go to previous messageGo to next message
This is the best pick i got, of it at hand. Ignore the fluid sitting in the top of it, that was when my koni just decided to shit itself thankfully thats all attended to.
OK SCRAP THAT CAUSE THIS WONT LET ME PUT A FILE ATTACHMENT FOR SOME GHEY REASON.
Lambolica PM me your email so i can send you a pic of the Noltec camber kit installed if you wish.
[Updated on: Sat, 12 June 2004 02:54]
omegaman
SYDNEY
Re: Best Camber kits? Sun, 13 June 2004 06:28 Go to previous messageGo to next message
lambolica.
whats your email & I'll send you a photo top and bottom. Have not put them in the car yet, to send you more pics.
[Updated on: Sun, 13 June 2004 06:33]
Re: Best Camber kits? Sun, 13 June 2004 06:41 Go to previous messageGo to next message
wagonist wrote on Fri, 11 June 2004 16:35
Laughing
hey so does my 1969 corolla Very Happy
we don't need no stinkin' radius rods....
MUUHAHHAHAHAHHA
as for the strut top.. couldn't you just drill the holes in the strut top and rotate it so that the adjustment goes in a different direction? is what i did for mine.. but they are just home-made jobbies Wink
if you guys want pics up, i'll host them...
Cya, Stewrat
omegaman
SYDNEY
Re: Best Camber kits? Sun, 13 June 2004 06:49 Go to previous messageGo to next message
how can you host the photos.
I'm still trying to figure out how to post photos as attachements . Done it once ages ago.
Hey,old corollas, your in my local area, when I get my ra28 back on the road, wave me down if I go pass you on the road.
[Updated on: Sun, 13 June 2004 06:50]
Re: Best Camber kits? Sun, 13 June 2004 06:59 Go to previous message
email them to me, i upload them to my uni server, and then pm you the URL... then you hit the "insert image" button above.. and voila, image Very Happy
you can't actually attach photots, just put in links to them, and they need be hosted on the net somewhere
heh heh, no worries, i'm free of thesis in a few weeks....
[Updated on: Sun, 13 June 2004 07:00]
Previous Topic:MX73 conversion trbls
Next Topic:S13 coilovers unto ae86
Current Time: Wed Oct 28 08:11:56 UTC 2026
Total time taken to generate the page: 0.0067300796508789 seconds
