Toymods » Tech & Conversions » 1jz miss and runnin rich
naten
campbelltown
1jz miss and runnin rich Sat, 05 June 2004 23:45 Go to next message
hey guys,
my 1jzgte ma61 project is almost done, just have a few more issues i need to iron out.
the main problem at the moment is this.
car warms up perfectly no worries at all, is a dream to drive when warming up (moving it and stuff)
once the car is warm its a different matter. It does not idle at all unless slight accel is used. It misses when i do this too. It drives relatively ok, it did miss once when under boost but still made boost.
What i believe is that it is in limp mode ? the piss rich mixture is ok for it when warming up but once its warm the rich mixture just kills it.
When the wiring was done there was a map sensor fault. I havent been able to pull the codes yet (ECU mounted in air con box:))
I pulled the plugs and they were fouled badly confirming the piss rich theory.
Anyone have any similar experience/suggetions ?
god
BTW im still smiling cuz im impressed with how she goes now, and if it is in limp mode Smile
82MKII
Re: 1jz miss and runnin rich Sun, 06 June 2004 02:55 Go to previous messageGo to next message
Is the ECU from an auto or manual?
If it is from an auto and you haven't kept the original auto box, the ECU will go into limp home mode.
Regards
Peter
Re: 1jz miss and runnin rich Sun, 06 June 2004 03:01 Go to previous messageGo to next message
I'd be checking your timing, and also the wiring on your cam and crank sensors - esp the cam sensors.
standard ecu?
and yeah, even in limp mode, a 1jz-gte ma61 goes bloody fast Smile
naten
campbelltown
Re: 1jz miss and runnin rich Sun, 06 June 2004 03:22 Go to previous messageGo to next message
its a auto ecu running a manual box. I have heard of some people having issues with it but generally speaking it is okay.
is there something that has to be wired to the ecu to make it think the auto is still there ?
it is stock everything except there is no cooler.
cam sensors hey never knew they had them. one thing that may be of interest before i put the motor in the car we went over it and replaced everything. When we did the timing belt the exhaust cam had two notchs to sit in one turned more towards the inlet cam and one slightly away. The notch that was closer to the inlet seemed to be too far out so we put it on the left of it. Not sure if this would have any effect im pretty sure we did it right.
draven heard yours was on limp mode for some time, how much quicker is it ? cuz im cheerin if it is and i get it sorted
god
Re: 1jz miss and runnin rich Sun, 06 June 2004 03:25 Go to previous messageGo to next message
manual ecu didn't make a huge difference to power. Just made it a lot smoother and a *LOT* more fuel efficient (in fact, on the manual ecu it was the most efficient car I've ever owned Razz)
naten
campbelltown
Re: 1jz miss and runnin rich Sun, 06 June 2004 03:42 Go to previous messageGo to next message
draven: na i meant in terms of power and speed from when it is in limp mode to when it is not. hahah consumption doesnt bother me Smile
did u have to do anything special when you had da auto ecu on her ?
quick question the cam sensors they are located behind the cam pulleys ? gettin the timing belt off is a pain with the motor in the car
god
Re: 1jz miss and runnin rich Sun, 06 June 2004 05:42 Go to previous messageGo to next message
lol no.
on the inlet side of your engine, just above your number 1 & 6 injectors (or there abouts) there are 2 little cam sensors.
naten
campbelltown
Re: 1jz miss and runnin rich Sun, 06 June 2004 08:24 Go to previous messageGo to next message
hmmmm checked the cam sensors they look solid
i have to wait to contact the dude who did my wiring about the w wire. I have no way of knowing which wire it is coming off the ecu. But he isnt back in the country for a few weeks Sad
did a double check for any vacum leaks and as far as i can see/tell there arent any.
the thing that has me stumped is that at idle its perfect its only when the engine is up to temprature the problems rise.
will have to wait and get error codes out of the ecu i guess
Re: 1jz miss and runnin rich Sun, 06 June 2004 08:26 Go to previous messageGo to next message
is it when the engine's up to temp, or when the revs are up, or both?
naten
campbelltown
Re: 1jz miss and runnin rich Sun, 06 June 2004 08:30 Go to previous messageGo to next message
its when the engine is up to temprature.
here is what happens exactally
start the car, no worries at all. Purrs along like a well trained pussy Very Happy
once its up to operating temp the idle gets lower and lower as it starts to miss etc etc
it then wont idle unles a little bit of the accel pedal is given to her. It idles like this but still misses.
It missed once under load but i havent driven her for any great time on load. Just warm her up take it round the block kinda thing.
god
Re: 1jz miss and runnin rich Sun, 06 June 2004 09:16 Go to previous messageGo to next message
is your temp stable?
I'd be checking your water temp sensor - sounds like it may have the wrong part in there or something.
My car never missed with the auto ecu, but I did blow fire out my exhaust, which I must say is the *ultimate* way to intimidate people on the road (better even than a screamer pipe)
naten
campbelltown
Re: 1jz miss and runnin rich Sun, 06 June 2004 10:33 Go to previous messageGo to next message
ok just checked the water temp sensor 3.5k ish when cold dropped to 0.6k after a warm up so seems to be working ok
something that i didnt really notice until now is there is a hunt of around 100-200 rpm (not that bad but you can notice a change in rpm) when its warming up
did a triple check no air leaks on the intake
dam wish i could pull the codes out of her
god
[Updated on: Sun, 06 June 2004 10:46]
sideshow
Re: 1jz miss and runnin rich Sun, 06 June 2004 11:16 Go to previous messageGo to next message
hook up a check light
i have wired shit loads of 1jzs
never had any probs
whether manual ecu or auto ecu
manual box or auto box
the ecus can be wired afew diff ways
maybe they go into limp mode if not done 100% right
i have run into this afew times
especially on a 1gg
y cant u get codes out of it
just pay someone to fix it peoperly
naten
campbelltown
Re: 1jz miss and runnin rich Sun, 06 June 2004 11:30 Go to previous messageGo to next message
the wiring was done professionally by a very classy wiring guy.
and i have no doubt in the work that he has done.
the diag box does not have the W pin in it. the wire isnt running to it and i dont have pin outs for the ecu/where it was hooked up to previously as the wiring guy is overseas atm.
and it doesnt mean that the fault lie in the wiring. it could be a faulty whatever which is what im trying to narrow it down to.
wheres the fun in getting someone else to fix it Smile
sideshow
Re: 1jz miss and runnin rich Sun, 06 June 2004 11:47 Go to previous messageGo to next message
sorry for being abrupt
i see it every bloody day
i know some threads get annoying because they go one for ages trying to figure something out
people dont realise there is soo many variables
and some things u just cant find unless theyre on a dyno
i know it costs money
im lucky i fix my car myself so i dont pay for anything
i gues sif i had to pay my opinion would be different
naten
campbelltown
Re: 1jz miss and runnin rich Sun, 06 June 2004 22:19 Go to previous messageGo to next message
yea i usually do fix my cars myself but a problem like this on a 1jz is something that need some help on.
dyno time isnt going to solve this problem at all.
wasnt asking for a step by step solution just if anyone had any similar experience or suggestions to share as to what may be causing it.
god
Jag7799
Re: 1jz miss and runnin rich Sun, 06 June 2004 22:55 Go to previous messageGo to next message
82MKII wrote on Sun, 06 June 2004 12:55
Regards
Peter
my 1jz is running an r154 manual on a soarer auto ecu.. no limp mode for me
only goes into limp mode if not wired correctly
Jag7799
Re: 1jz miss and runnin rich Sun, 06 June 2004 22:59 Go to previous messageGo to next message
Regards
Peter
sprinter_86
Re: 1jz miss and runnin rich Mon, 07 June 2004 07:32 Go to previous messageGo to next message
Sorry but could someone tell me wat this conversion would cost (1jz single turbo into a ma61) to get someone to do it.
sprinter_86
Re: 1jz miss and runnin rich Mon, 07 June 2004 07:33 Go to previous messageGo to next message
Sorry but could someone tell me wat this conversion would cost (1jz single turbo into a ma61) including the engine to get someone to do it. Total price abouts.
naten
campbelltown
Re: 1jz miss and runnin rich Mon, 07 June 2004 08:26 Go to previous messageGo to next message
plently of threads of that stuff just use the search button or make another thread
god
Jag7799
Re: 1jz miss and runnin rich Mon, 07 June 2004 08:39 Go to previous messageGo to next message
sprinter_86 wrote on Mon, 07 June 2004 17:33
i jsut got one into a gz10 soarer( so exact same conversion as ma61, identical) cost me 10 000 dollars.. with stock turbo's and shitty exhaust
celicamad
newcastle
Re: 1jz miss and runnin rich Mon, 07 June 2004 12:22 Go to previous messageGo to next message
i assume you replaced the plugs!! if not 1j plugs once fouled are FUCKED throw em and start again with with ngk bkr6es gapped to 0.7mm
ive seen 1j plugs fouled so bad from perfectly running engines(factory rich) they wouldnt even idle .
naten
campbelltown
Re: 1jz miss and runnin rich Mon, 07 June 2004 13:12 Go to previous messageGo to next message
yea of course i replaced them when i went over the motor. i have done maybe 200kms tops on these ones tho. Gotta start with a clean slate and work back from ecu codes
thanks for your help guys i will let you know how i go
nathan
TUB-11Y
Newcastle, NSW
Re: 1jz miss and runnin rich Wed, 09 June 2004 06:11 Go to previous messageGo to next message
draven wrote on Sun, 06 June 2004 13:25
did u notice any other difference?? would it be worth changing from the auto to manual ecu if u dont need to ??
thanx, Luke
naten
campbelltown
Re: 1jz miss and runnin rich Sat, 12 June 2004 10:12 Go to previous messageGo to next message
ok
got a new set of plugs and gapped them. The ones i used before bkr6e have a groove on them, i didnt notice this until today. The new ones bkr6es-11 (gapped to 0.7mm) dont.
she seems a lot better now and can hold an idle when warm, the miss is all but gone and she feels a lot stronger.
Its still idling too low though. I had a thought, could it be due to a flat battery ? as in the alt has issues charging a completely flat battery at a low idle ? im assuming the ecu would make adjustments for this but im not sure.
If the idle was just that little bit higher it seems/feels like it would be sweet as but as far as i know there is no 'idle adjust screw' as such on a 1j.
god
TUB-11Y
Newcastle, NSW
Re: 1jz miss and runnin rich Mon, 21 June 2004 16:45 Go to previous messageGo to next message
TUB-11Y wrote on Wed, 09 June 2004 16:11
thanx, Luke
*bump*
could anybody answer this please?
Danish
Re: 1jz miss and runnin rich Mon, 21 June 2004 17:23 Go to previous messageGo to next message
My recent bout of missing was caused by faulty injector wiring. You have to make sure they are properly wired up, no exposed wires and all sealed up.
Chris Davey
sunny coast, qld
Re: 1jz miss and runnin rich Mon, 21 June 2004 21:54 Go to previous messageGo to next message
naten wrote on Sat, 12 June 2004 20:12
god
Yeah, they are the plugs people recommend for the 1jz.
I am certainly no expert, but I thought there was an idle screw on the 1jz, as I thought mine was idling a little low too.
wastegate
Gold Coast
Re: 1jz miss and runnin rich Mon, 21 June 2004 22:48 Go to previous messageGo to next message
Yeah you just adjust the throttle stop. It shouldn't idle LOWER than 650-750rpm though.
[Updated on: Mon, 21 June 2004 22:49]
Yeeehah
Re: 1jz miss and runnin rich Tue, 22 June 2004 02:29 Go to previous message
I'm no expert on this stuff, but maybe there's something going on with your idle valve control or stepper motor. Maybe the wiring is wrong there.
Previous Topic:AE92 1.6L Carby Cheap/Quick Mods
Next Topic:Steering Racks
Current Time: Tue Oct 27 03:12:02 UTC 2026
Total time taken to generate the page: 0.0070650577545166 seconds
