Toymods » Tech & Conversions » 3SGTE pistons / 3SGE
acreese
3SGTE pistons / 3SGE Sun, 06 June 2004 07:36 Go to next message
Thanks to those that have helped me thus far with my research.
I am looking for some strong pistons for my 3SGE rebuild and was wondering if 3SGTE pistons would fit in my engine and would they assist in lowering the CR?
i have a Gen1 3sge.
Adam
TA22-3SGTE
MACKAY
Re: 3SGTE pistons / 3SGE Sun, 06 June 2004 09:24 Go to previous messageGo to next message
A set of Genuine ST 205 pistons from Toyota will cost you about $400 and give a CR of about 8.5 : 1 .
Trevor
gabe
Re: 3SGTE pistons / 3SGE Sun, 06 June 2004 09:31 Go to previous messageGo to next message
sorry to hijack here but if I was rebuilding my 3s to take higher hp (not insane power, but a definate increase), would 205 pistons be up to the task or would I be better off investing in a set of forged items.
Gabe
Re: 3SGTE pistons / 3SGE Sun, 06 June 2004 11:32 Go to previous messageGo to next message
referring to the 4A-GZE factory forged piston argument, would it also not be fair assume that the 3S-GTE pistons are also factory forged?
Anyone know for sure?
Re: 3SGTE pistons / 3SGE Sun, 06 June 2004 11:39 Go to previous messageGo to next message
gabe wrote on Sun, 06 June 2004 19:31
Gabe
I believe that Trevor is using factory forged Gen3 pistons in his engine that has produced 274kw at the wheels.
gabe
Re: 3SGTE pistons / 3SGE Sun, 06 June 2004 11:40 Go to previous messageGo to next message
I'm 99% sure they are not. But I am hoping to be pleasantly surprised........... Rolling Eyes
gabe
Re: 3SGTE pistons / 3SGE Sun, 06 June 2004 11:41 Go to previous messageGo to next message
So they are definitely forged then??
Re: 3SGTE pistons / 3SGE Sun, 06 June 2004 11:42 Go to previous messageGo to next message
Yes
gabe
Re: 3SGTE pistons / 3SGE Sun, 06 June 2004 11:44 Go to previous messageGo to next message
This is GOOD news!
Must be 185 pistons that are piss weak.......
Re: 3SGTE pistons / 3SGE Sun, 06 June 2004 11:50 Go to previous messageGo to next message
anyone got a spare ST185 piston? we can find out!
Re: 3SGTE pistons / 3SGE Sun, 06 June 2004 12:01 Go to previous messageGo to next message
gabe wrote on Sun, 06 June 2004 21:44
Thats right, the 205 pistons are the only forged ones.
spectral
Re: 3SGTE pistons / 3SGE Mon, 07 June 2004 00:20 Go to previous messageGo to next message
ST185 Pistons
http://www.amberaspley.com/gt4/pics/3SGTE/scales.jpg
TerryOBeirne
Redbank Plains,near Ipswi...
Re: 3SGTE pistons / 3SGE Mon, 07 June 2004 01:44 Go to previous messageGo to next message
I have a 205 turbo engine in bits and they are definitely not forged. they are cast with steel side straps in them. The turbo pistons are probably too low in compression for a GE . I have new GE pistons in stock but these are designed for stock or near stock engines only. We have used weisco, cosworth and arias ones in hot GE engies. they are all much the same (expensive but good). these special pistons are not designed for everyday road use as they have thin rings that dont last under everyday conditions. there are very few compromises in this game.
MR. 2
Parramatta
Re: 3SGTE pistons / 3SGE Mon, 07 June 2004 02:48 Go to previous messageGo to next message
terry would be right in saying none are forged, and none are stronger then the other, in the gte dept. the 205 and 185 are almost the same, its just the 205s are compressed to 8.0:1 and the 185 8.5:1. in all honsety if ur going to build a motor buy new aftermarket pistions, im using weisco in mine, great pistons. Also if your worried about the price tag look on ebay, cheap and easy.
just my 2c
acreese
Re: 3SGTE pistons / 3SGE Mon, 07 June 2004 14:43 Go to previous messageGo to next message
Thanks all who replied, very helpful.
With the rebuild, i am looking to add forced induction so a lower compression ratio is the go. for my purposes i believe that the ST205 pistons ought to do the job providing that they will be COMPATIBLE with a GEN 1 3SGE.
Would like to know for sure before i get hold of a set.
will also look out for some aftermarket ones on ebay.
TA22-3SGTE
MACKAY
Re: 3SGTE pistons / 3SGE Tue, 08 June 2004 09:17 Go to previous messageGo to next message
I am using 205 pistons in my gen1 3SGTE Paid $182 for the set from Toyota ( Trade Price ) I am also using a 205 metal head gasket from Toyota $98 Trade , Running 26 psi boost and making 272RWKW and have also run up to 35 psi on these pistons , I have run 40psi but the head lifts at that boost and pushes a bit of water out .
Trevor
CLG
Perth, Western Australia
Re: 3SGTE pistons / 3SGE Wed, 09 June 2004 02:03 Go to previous messageGo to next message
<cough, cough, cough>
http://forums.toymods.org.au/index.php?t=msg&t h=33841&rid=1781&S=3182fba9687b0bc735428e9 f70bc1725&pl_view=&start=0#msg_297612msg_2 97612
M.W.P.
Rocky Mountains, Canada
Re: 3SGTE pistons / 3SGE Wed, 09 June 2004 03:25 Go to previous messageGo to next message
TA22-3SGTE wrote on Tue, 08 June 2004 18:47
Wow.
Is that with a stock bottom end?
TA22-3SGTE
MACKAY
Re: 3SGTE pistons / 3SGE Wed, 09 June 2004 08:21 Go to previous message
Yes stock 165 bottom end and head , HiFlowed 165 CT26 with 7MGTE exhaust housing , 185 air to air cooler , 205 pistons , 205 head gasket , ARP head studs , 4 extra 165 injectors , custom plenum and exhaust manifold , Haltech E6A ECU , 2 Bosch VLT fuel pumps , Thats about it .
Trevor
Previous Topic:Ra40 1g engineering price....
Next Topic:Trumpets/Velocity stack Q's
Current Time: Sat Nov 21 06:46:06 UTC 2026
Total time taken to generate the page: 0.0071580410003662 seconds
