Toymods » Tech & Conversions » Motor Oil
tomartom
icon4.gif  Motor Oil Sun, 06 June 2004 11:10 Go to next message
Any opinions as to the different Synthetic Oils available. I use a Castrol 5/30w in a v6 camry and runs quite well, especially in winter. I think though that in the warmer months the engins sounds a little louder. Should I use a different oil in warmer months or in the current range of 5/30 ok.
regards
tony
V8_MA61
Re: Motor Oil Sun, 06 June 2004 11:11 Go to previous messageGo to next message
generally you should use thicker oil in summer, and thinner in winter for temperature allowances. having said that, i run penrite hpr40 in a brand new rebuild 7mge...and that is 25w/70.
Works great combined with some morey's!
Blake
Stenno
Re: Motor Oil Sun, 06 June 2004 22:14 Go to previous message
Tony - Run whatever the manufacturer recommends unless the motor has some km's on it. For example I run either Castrol Synth R 0W40 or 5W30 in my 2J. Most current tech engines run 10W30 (5W30).
If it's a little noisey run a slightly thicker viscosity oil, like a 15W50.
Blake - 25W70? Shocked You must have super high oil pressure as a result, that's a pretty thick viscosity oil. Doesn't Toyota recommend 10W30 for the 7M from memory?
Previous Topic:Air conditioning 18R-G
Next Topic:Park Light Staying on
Current Time: Wed Oct 14 09:38:22 UTC 2026
Total time taken to generate the page: 0.019362926483154 seconds
