Toymods » Tech & Conversions » GA70 MA70 JZA70 same brakes?
jackel
GA70 MA70 JZA70 same brakes? Sun, 06 June 2004 18:47 Go to next message
I wanted to know if the three supra models below have the same brake setup and what they are, cause my friend says they are all the same but i doubt it???
GA70 MA70 JZA70
He has a 1G and is getting a 1JZ.
Stenno
Re: GA70 MA70 JZA70 same brakes? Sun, 06 June 2004 22:00 Go to previous messageGo to next message
MA70 & JZA70 run the same brakes.
some GA70's are identical to the JZ/MA70 setup but some run smaller brakes (The povo model GA70's had 15 steel rims from the factory standard and thus had the smaller brakes).
supra1978
Re: GA70 MA70 JZA70 same brakes? Sun, 06 June 2004 22:27 Go to previous messageGo to next message
Some MA70s have 15inch alloys and smaller front brakes.
Stenno
Re: GA70 MA70 JZA70 same brakes? Sun, 06 June 2004 23:42 Go to previous messageGo to next message
supra1978 wrote on Mon, 07 June 2004 08:27
Not the Australian delivered one's. Smile
supra1978
Re: GA70 MA70 JZA70 same brakes? Mon, 07 June 2004 00:17 Go to previous messageGo to next message
True. Worth a mention as there's a few imports getting about.
snail
Re: GA70 MA70 JZA70 same brakes? Mon, 07 June 2004 01:40 Go to previous messageGo to next message
All GA70 & Soarers have the smaller brakes. MA70 & JZA70 have the bigger ones. Very Happy
SupraPete
Re: GA70 MA70 JZA70 same brakes? Mon, 07 June 2004 01:48 Go to previous messageGo to next message
Some JZA70s run bigger slotted ones.
I'm running them in my MA70 fine with everything else standard (shoes, lines, etc.), with EBC Green stuff pads.
Depending on if they're Australian or Imported they'll be different again. Theres too many variants to generalise. You'll need to compare them yourself to find out if they'll fit.
snail wrote on Mon, 07 June 2004 11:40
Wrong. I have personally seen at least two GA70's with brakes identical to the MA70.
[Updated on: Mon, 07 June 2004 01:52]
snail
Re: GA70 MA70 JZA70 same brakes? Mon, 07 June 2004 04:12 Go to previous messageGo to next message
Im just talking from experience having owned GA,MZ and JZA thats all. It is common that people upgrade to the MA/JZA. As it is very cheap. Very Happy
Danish
Re: GA70 MA70 JZA70 same brakes? Mon, 07 June 2004 06:28 Go to previous messageGo to next message
I'm about to put MA70 brakes into my GZ20, but I need bigger wheels for them to fit under.
V8_MA61
Re: GA70 MA70 JZA70 same brakes? Tue, 08 June 2004 10:53 Go to previous messageGo to next message
Norbie wrote on Mon, 07 June 2004 11:48
I agree, as i own a set of ga70s and a set of ma70s. identical. Only ass end difference is GA70 is non lsd
poombah
Forrestfield, WA
Re: GA70 MA70 JZA70 same brakes? Mon, 14 June 2004 00:22 Go to previous message
well i have jza70 and their stock brakes are pretty povo in my opinion. Single spot caliper and 280mm x ~18mm rotors at front.
Previous Topic:2TG SPARE POWER?
Next Topic:MA70/MZ20 Supra/Soarer Steering Rack Boots
Current Time: Fri Oct 30 12:19:41 UTC 2026
Total time taken to generate the page: 0.0041267871856689 seconds
