Toymods » Tech & Conversions » st185 injectors into st162
dar_sbb
st185 injectors into st162 Mon, 07 June 2004 02:07 Go to next message
By puting the turbo injectors on will there be ne difference in power?
Daz
Classique71
Colac, Victoria
Re: st185 injectors into st162 Mon, 07 June 2004 02:32 Go to previous messageGo to next message
are you planning on aftermarket ecu's cams or the such ?
if so theres not much point, though if powerpods are planned you might want to look at them down the track
PS: did you still want my red calipers ?
RWDboy
Re: st185 injectors into st162 Mon, 07 June 2004 06:51 Go to previous messageGo to next message
I'll state this again, if you want to use bigger injectors (ie more fuel and more kW), you will need to start by flowing more air. If you use bigger (turbo sized) injectors with standard amount of air flow, you will probably get a drop in performance due to worse atomisation at the lower air flow. (the air gets saturated quicker because it is colder, and there is less air mass for the fuel to atomise in etc etc)
Fuel is only half of the equation...air is usually the more important half Smile
You would have to be flowing quite a bit of air to require larger injectors than the factory ones.
TA22-3SGTE
MACKAY
Re: st185 injectors into st162 Mon, 07 June 2004 09:55 Go to previous messageGo to next message
185 injectors are side feed and 162 injectors are top feed , Not interchangeable , and you will lose power by putting bigger injectors into a standard motor as the factory set fuel mixture is already rich under full load , If you can lean out the mixtures under load you will gain power .
Trevor
RWDboy
Re: st185 injectors into st162 Mon, 07 June 2004 12:30 Go to previous messageGo to next message
I disagree - see above post Smile
If you can lean out the mixture then you would gain power with the factory injectors...it would be a waste of money *unless* you are flowing a bugger-load more air than the factory engine.
TA22-3SGTE
MACKAY
Re: st185 injectors into st162 Mon, 07 June 2004 13:53 Go to previous messageGo to next message
I fit and tune piggy back ecu's and leaning out the mixtures and adding a bit of ignition advance can give up to 20kw at the wheels increase on some cars.
Trevor
RWDboy
Re: st185 injectors into st162 Mon, 07 June 2004 15:20 Go to previous messageGo to next message
But why have bigger injectors for a leaner mixture Razz
Also - leaning out the mixture and increasing ignition advance, whilst power wise can be a good thing, it generally means the engine is going to
a) Have illegally high emissions (which I'm guessing is not the point of fitting a piggy back ECU)
b) Run a heck of alot hotter which could result in early engine internal failure.
The factory ECUs are detuned for specific reasons, it doesn't mean the ECU is bad (although in the 1st gen 3S-GE's case the ECU is bad) it just means it is tuned a certain way.
Have you done many 1st gen 3S-GEs btw? I've heard they aren't so worthwhile/easy in regards to piggybacking?
Re: st185 injectors into st162 Mon, 07 June 2004 15:31 Go to previous messageGo to next message
FWDboy wrote on Tue, 08 June 2004 01:20
heh heh Laughing
if the ECU's mapping is not changed all you will do is achieve worse fuel economy..
you need to have a reason to have larger injectors, ie greater fuel demand, as FWDboy said, from more AIR going into the motor... like a turbo perhaps Smile
stocko ECU's are not only tuned for emissions, but also to aid motor longevity Very Happy
dar_sbb
Re: st185 injectors into st162 Tue, 08 June 2004 02:10 Go to previous messageGo to next message
Thanks peepz!!
RWDboy
Re: st185 injectors into st162 Tue, 08 June 2004 02:17 Go to previous message
FWDboy wrote on Mon, 07 June 2004 22:00
I just thought I'd clarify this in case you thought that i meant a leaner mixture won't make more power.
What I mean, is that if you are able to lean out the mixture using something like a piggy back ECU, then regardless of whether you have bigger injectors or factory injectors, you will gain the same amount of power. In fact, you'll probably gain less power with the bigger injectors - again - due to the poor atomisation of such a short open cycle.
I re-read what I wrote and I could see it was easily misinterpreted.
Previous Topic:removing 2JZ cam pulleys!!
Next Topic:4age problem....wheres all the power??
Current Time: Sat Oct 17 03:02:27 UTC 2026
Total time taken to generate the page: 0.0064809322357178 seconds
