Toymods » Tech & Conversions » 3tgte? Power out put?
DVS_ONE
3tgte? Power out put? Mon, 07 June 2004 03:27 Go to next message
Hi All jus wondering what the power out put is of these engines?
Re: 3tgte? Power out put? Mon, 07 June 2004 03:49 Go to previous messageGo to next message
160hp stock.
TA22 GT
Re: 3tgte? Power out put? Mon, 07 June 2004 03:52 Go to previous messageGo to next message
Stock it has 160hp at the engine, this is usually around 85 to 90kw at the wheels in a TA22 or similar.
You can get good power from these engines and they are very strong. The CT20 is a crappy turbo and it lacks a blow off valve and intercooler in standard form.
I have 145kw at the wheels from my 3T GTE and others have similar or better. Yellorolla has around 195kw last I heard, which would be heaps of fun.
Simon
DVS_ONE
Re: 3tgte? Power out put? Mon, 07 June 2004 04:38 Go to previous messageGo to next message
what about with a to4?
3T-GTE
Re: 3tgte? Power out put? Mon, 07 June 2004 04:58 Go to previous messageGo to next message
Hi DVS_ONE,
You might find this thread interesting:
http://forums.toymods.org.au/index.php?t=msg&t h=20475&rid=3498&S=bfb0d90e3464e053a571593 5ec8d0893
or
http://forums.toymods.org.au/index.php?t=msg&t h=34602&rid=3498&S=bfb0d90e3464e053a571593 5ec8d0893
I think there are a few other similar threads you might find through the Toymods search tool.
When you say with a T04 turbo, what other modifications would be done? I would say that it would be virtually impossible to get anything more than 200rwkw out of standard 3T-GTE internals (although Jason may be able to prove me wrong).
How much horsepower would make you happy?? Note that is around 300kw at the flywheel / or around 400hp at the flywheel.. which is normally enough for many people!
This would be good for around a 12.5 sec quarter mile with around a 185km/h trap speed in a TA-22. - Would you be happy with that?
Sure putting on a bigger turbo makes it capable of more power, but anything more than 200rwkw would require spending around a grand on some forged pistons at least.
How much would you be willing to spend?
3T-GTE
YelloRolla
On your mum!
Re: 3tgte? Power out put? Mon, 07 June 2004 06:50 Go to previous messageGo to next message
I killed a standard piston with 20PSI through the CT26. I would not "NOT" assemble one of these engines for more than about 15PSI with stock pistons (we did run a bit more with the CT20 and the stockers although it is a piss weak little pump).
I reckon that 200rwkW is a very short lived engine if it is on stock pistons.
Power figure before we broke the stock unit was 220rwhp at about 5000rpm.
Std bottom end with forged pistons - who knows?
DVS_ONE
Re: 3tgte? Power out put? Mon, 07 June 2004 22:37 Go to previous messageGo to next message
YelloRolla wrote on Mon, 07 June 2004 16:50
They have potential then?
YelloRolla
On your mum!
Re: 3tgte? Power out put? Mon, 07 June 2004 22:44 Go to previous message
Potential? hell yeah!
Check out how much power that Paradise racing is making.
Horsepower is ultimately the result of torque x rpm / 5251.
I rev mine frequently to 8k or there abouts. How much power can you make by 8k? I reckon lots, but it is a "how long is a piece of string?" scenario.
Previous Topic:upgrades for solid axle t series
Next Topic:springs for ae86 setup
Current Time: Mon Oct 19 10:57:25 UTC 2026
Total time taken to generate the page: 0.032202959060669 seconds
