Toymods » Tech & Conversions » Best way to remove spray over on glass.
bathurst-91
icon13.gif  Best way to remove spray over on glass. Mon, 07 June 2004 07:56 Go to next message
Yeh so theres a very thin layer of sprayed over paint allover my driveside window.. (just noticeble) So I tried acrylic remover along with a razor blade, and after some furious scrubbing I realized I scratched the crap outta my glass due to a dodgy razor (CRAP!!!!) Just about snapped at that point.
So any recommendations on the spray removeal and scratch removal would be cool
Re: Best way to remove spray over on glass. Mon, 07 June 2004 07:58 Go to previous messageGo to next message
3M adhesive cleaner. This shit removes anything.
[Updated on: Mon, 07 June 2004 07:58]
Cressida Chick
central coast, NSW
Re: Best way to remove spray over on glass. Mon, 07 June 2004 07:59 Go to previous messageGo to next message
a razer blade that is designed for glass
Skein
Re: Best way to remove spray over on glass. Mon, 07 June 2004 08:05 Go to previous messageGo to next message
I had a similar problem last week, I just used a liberal amount of thinners on a soft rag and gently polished it off the glass and surrounding plastic.
Just be careful not to let it run onto the bodywork!
ae86drift
sydney.au
Re: Best way to remove spray over on glass. Mon, 07 June 2004 09:53 Go to previous messageGo to next message
Cool1 wrote on Mon, 07 June 2004 17:58
word nigga
celicaboy_2000
Lismore, NSW
Re: Best way to remove spray over on glass. Mon, 07 June 2004 10:01 Go to previous messageGo to next message
Razor Blade
4ageeza
Adelaide, drift capital
Re: Best way to remove spray over on glass. Mon, 07 June 2004 10:05 Go to previous messageGo to next message
Acetone can also work well with a bit of elbow grease.
If ever using turps, always be careful not to get it onto plastic of any kind, especially clear, as it eats it away!
IRA11Y
Club Member
Re: Best way to remove spray over on glass. Mon, 07 June 2004 10:45 Go to previous messageGo to next message
ive found a scotchbrite pad thats a little damp works well, and if you get some stuborn stuff add a little turps.
Grega
melbourne.victoria.austra...
Re: Best way to remove spray over on glass. Mon, 07 June 2004 19:13 Go to previous messageGo to next message
thinner.
Soarer
Wollongong
Re: Best way to remove spray over on glass. Tue, 08 June 2004 01:12 Go to previous messageGo to next message
Look up "clay bar overspray" on Google. Removes overspray from paint, glass, whatever.
bubbles
Banned user
Liverpool NSW
Re: Best way to remove spray over on glass. Tue, 08 June 2004 01:45 Go to previous messageGo to next message
a lot of panel beating shops use razor blades, if its the outside window, its safe, just use a bit of window cleaner with it, it helps
shinybluesteel
melbourne
Re: Best way to remove spray over on glass. Tue, 08 June 2004 03:37 Go to previous messageGo to next message
masking ta...
oh, right.
nice clean razor blade, id file/grind down the corners of it too, make sure it is smooth, or use the 3m stuff.
Mr DOHC
Re: Best way to remove spray over on glass. Tue, 08 June 2004 07:06 Go to previous messageGo to next message
use meguairs over spary clay part number C2000.
we use it at work and its the shiznits, removes industrial fallout, water marks and tree sap, its a bit exxy at $50 for 2 bars bu it will last forever, we have 3 fulltime detailers and it takes them 2 months to go thru 2 bars.
or 3M tint glue remover, now thats potent shit,
after this, go to bunnings and pick up some very fine steel wool {comes in a roll} rip off a piece and spray glass cleaner all over the glass and scrub the glass lightly, it wont remove the cleaner but it loosens everything else, then rub it off as per usual and then repeat but dont use the steel wool the 2nd time
Mr DOHC
Re: Best way to remove spray over on glass. Tue, 08 June 2004 07:08 Go to previous messageGo to next message
dont use the steel wool on your tint tho, it'll fuck it, use the steel wool inside and out on the windscreen and all the other windows on the outside only
ChuckLandwehr
Re: Best way to remove spray over on glass. Tue, 08 June 2004 10:54 Go to previous messageGo to next message
Do not use Scotchbrite Sad it actually scratches glass Embarassed The best bet is steelwool, DRY! Laughing , then just blow the residue off.
regards Chuck.
Little Miss
Re: Best way to remove spray over on glass. Tue, 08 June 2004 12:31 Go to previous messageGo to next message
Use 3M overspray clay - 200g block costs about $33.00, lasts forever.
using steel wool in glass???? glass does scratch, have a look under lights.
Rolling Eyes
sandman
Re: Best way to remove spray over on glass. Tue, 08 June 2004 12:53 Go to previous messageGo to next message
I have used toothpaste on a watch face before to remove scratches (With a soft cloth)...not sure how it would work on car windows, but might be worth a try to remove those nasty scratches. Maybe test on some glass in your house first?
fade-e
Re: Best way to remove spray over on glass. Fri, 11 June 2004 07:24 Go to previous message
i used a razor blade but now my front windscreen is completely stuffed, scratches everywhere Sad now i gotta go get it buffed and polished
Previous Topic:SC14 in a AE92, yes i have searched!!!
Next Topic:2t Start up issues ... help!
Current Time: Fri Oct 16 15:32:05 UTC 2026
Total time taken to generate the page: 0.052063941955566 seconds
