Toymods » Tech & Conversions » In tank fuel pump question.
Lambolica
Northwestern Sydney
In tank fuel pump question. Tue, 08 June 2004 00:13 Go to next message
I'm wanting to clean up the engine bay in my RA28 project and the main source of the current mess is the fuel pump and surge tank being mounted in there.
I'd like to go for an in tank pump setup and would be looking at pulling the pump out of an RA65 and modifying it to suit the RA28 fuel tank.
This is to run an 18R-GEU and I'd like to have a fuel pump that can supply fuel up to 120rwkw (for the sake of argument)
Would the RA65 setup be able to supply enough fuel or should I be looking at a better setup from the word go.
Also what other factory toyota injectors fit in the 18r-geu rail that have a higher flow rate?
Re: In tank fuel pump question. Tue, 08 June 2004 00:21 Go to previous messageGo to next message
1. Yes, an RA65 pump will flow more than enough for your needs.
2. Practically any top-feed Toyota injector will fit in your fuel rail. The largest one I know of is the 440cc injector from the 7M-GTE but I doubt you want anything that big! 7M-GE injectors might be a good upgrade though.
Lambolica
Northwestern Sydney
Re: In tank fuel pump question. Tue, 08 June 2004 00:29 Go to previous messageGo to next message
Oh goodie... That's encouraging. Smile
Hmmm yet another trip to pick-n-pay heaps.
Thanks Norbie Short and sweet.
Allan
Re: In tank fuel pump question. Tue, 08 June 2004 00:35 Go to previous messageGo to next message
a whole tank may fit if your lucky as it's baffled
Allan
Re: In tank fuel pump question. Tue, 08 June 2004 00:49 Go to previous messageGo to next message
Mate can you keep me updated how you go. I'd love to change over to an intank setup and get rid of the surge tank/prime pump etc.
I was thinking of having my tank cut open and baffles welded in. Then fit a Bosch internal pump.
[Updated on: Tue, 08 June 2004 00:52]
Re: In tank fuel pump question. Tue, 08 June 2004 01:07 Go to previous messageGo to next message
I'd definitely look at modifying an RA65 tank to fit... if that's possible it would be a much neater solution!
Lambolica
Northwestern Sydney
Re: In tank fuel pump question. Tue, 08 June 2004 01:10 Go to previous messageGo to next message
Will do Joel Smile
Cheers Guys
Simon.
ra23celica
Re: In tank fuel pump question. Tue, 08 June 2004 03:29 Go to previous messageGo to next message
Agree with Norbie and the others above, modifying an existing efi tank to fit is much better than trying to fit an in-tank pump to a RA28.
On this subject, does anyone know of an EFI Toyota that has its tank upright behind the rear seat ? Something suitable for a TA22 or RA23 EFI engine conversion ?
Mitch.
(Just thinking out loud).
Re: In tank fuel pump question. Tue, 08 June 2004 03:59 Go to previous messageGo to next message
Hmm i've got a RA65 tank at home might have to see if it will fit Smile
I brought it originally to get the baffles out of but might prove to be more useful in 1 piece.
Mitch - the Crowns, umm what model... MS12x? with the 5ME engine had an upright tank in the boot.
ra23celica
Re: In tank fuel pump question. Tue, 08 June 2004 05:50 Go to previous messageGo to next message
Thanks Joel.
I will start looking out for Crown's at the wreckers. My guess is that the early EFI Crowns had an external pump while the later ones ran a swimmer pump ?
Mitch.
[Updated on: Tue, 08 June 2004 05:50]
Re: In tank fuel pump question. Tue, 08 June 2004 06:02 Go to previous messageGo to next message
Ahh mate I may have given you a bumsteer here.
The MS112 I was thinking of has the pump under the car.
But yeah maybe later models moved to a swimmer design.
Sorry!
Joel
Johnny
Sydney, OZ
Re: In tank fuel pump question. Tue, 08 June 2004 11:10 Go to previous messageGo to next message
Well may be a different way of doing things, but it does works. We made an extra baffle out of a aluminium tube 60 dia, tig welded an end on it, 3mm thick, only need to be 50-60 tall and fitted it in through the existing pickup hole. It had four 1/2" holes drilled into each corner and this was cabled tied to the F/P, a big bosch motorsport one at that. At first I thought yeah right Confused but a few guys that had the same surge problems with standard EFI tanks, we ran the same, and suggested it, so we gave it a go.... and it works, I've also done it to the G/F's AE82 20V conversion too using a non EFI tank, and again, no surge or problems....Don't know the hole size for an TA22, but worth a look.
IRA11Y
Club Member
Re: In tank fuel pump question. Tue, 08 June 2004 11:32 Go to previous messageGo to next message
hey Johnny , on the AE82 , i take it you used a standard efi pump.. did you keep the filter on the pump.. im trying to figure out how you fitted it over that?.
Re: In tank fuel pump question. Tue, 08 June 2004 23:51 Go to previous messageGo to next message
The RA28 tank I dont think has a removable plate for the pickup. It has a hole for the fuel sender but thats about it.
Johnny - What you suggested sounds like a good idea. Maybe a hole can be cut in the RA28 tank to fit the pipe/pump in.
ra23celica
Re: In tank fuel pump question. Wed, 09 June 2004 00:00 Go to previous messageGo to next message
Joel,
The '28 should have a removeable plate for the pick-up. I don't know this for sure. My RA23 has one in the top of the tank which I was thinking of using to create a mount for an in-tank fuel pump which includes a baffle plate / tube surrounding the pick-up with holes drilled to allow fuel into the thing.
Mitch.
Johnny
Sydney, OZ
Re: In tank fuel pump question. Wed, 09 June 2004 01:43 Go to previous messageGo to next message
No I used a VL turbo external, cut off the pickup and sliver soldered a new larger pickup in, still worked. The rally car uses an internal with the same idea. If you want to use an internal, you may have to bend the filter to fit...
IRA11Y
Club Member
Re: In tank fuel pump question. Wed, 09 June 2004 08:12 Go to previous messageGo to next message
ahh that explains it Smile i though i was stupid for a minute Very Happy
Re: In tank fuel pump question. Mon, 18 October 2004 02:49 Go to previous message
Digging up a bit of an old thread.. but...
The RA65 tank seems no way to fit this. I spent some time with it this weekend. It sits somewhere around 5cm lower than the factory ra28 tank and this is after attacking it with a sledge hammer to get it in the somewhat correct shape. Just totally the wrong shape for the car.
Its a pain that the ra28 tank doesn't have a removable plate where the pickup lines go in like ae86/t18/etc tanks have.
Previous Topic:RA23 retractable seatbelts
Next Topic:ITBs & Port X-Sectional Areas + Lengths : Your Thoughts....
Current Time: Sat Nov 21 18:07:09 UTC 2026
Total time taken to generate the page: 0.0065548419952393 seconds
