Toymods » Tech & Conversions » 1jz - what is this thing?
Chris Davey
sunny coast, qld
1jz - what is this thing? Wed, 09 June 2004 02:19 Go to next message
Does anybody know what the thing in the top picture is? Is the little knob thing at the top supposed to go in and out or not?
http://www.picturetrail.com/gallery/view
It just seems that this thing seems to be making a very similar noise to the noise that my car was making when it taps on the little pulley. I don't know if that pulley would move with the timing belt on though.
It was located on the front left of the engine near where the Power steering pump would usually be.
thanks!
Chris
[Updated on: Wed, 09 June 2004 02:24]
Re: 1jz - what is this thing? Wed, 09 June 2004 04:31 Go to previous messageGo to next message
Link doesn't work... it asks me for a username.
STR8 2.8
Re: 1jz - what is this thing? Wed, 09 June 2004 04:33 Go to previous messageGo to next message
http://www.picturetrail.com/gallery/view?p=999& ;%20;%20;gid=4454885&uid=2274801&members=1
[Updated on: Wed, 09 June 2004 04:34]
Re: 1jz - what is this thing? Wed, 09 June 2004 04:38 Go to previous messageGo to next message
It's the timing belt tensioner.
Chris Davey
sunny coast, qld
Re: 1jz - what is this thing? Wed, 09 June 2004 22:35 Go to previous messageGo to next message
so how exactly does it work? Is the knob supposed to move in and out?
How can I test if it is working properly? I think this may be the cause of my tapping noise.
Chris
wastegate
Gold Coast
Re: 1jz - what is this thing? Wed, 09 June 2004 23:36 Go to previous messageGo to next message
It's the thingy that puts tension on the tensioner. Very Happy
Yes that knob thing goes in, like a toite like a toiger spring. You should he able to push it in with ALOT of pressure.
There are some specs and stuff to check it out but my manual is at home. perhaps checking out the 2jz manual on mkiv.com as they use the same thing too.
Chris Davey
sunny coast, qld
Re: 1jz - what is this thing? Wed, 09 June 2004 23:45 Go to previous messageGo to next message
thanks again mate!
will do!
deesonet
Toowoomba
Re: 1jz - what is this thing? Thu, 10 June 2004 10:14 Go to previous messageGo to next message
Yes as Norbie said it is the tensioner.
You can compress it in a vice. The small hole is where you can put an allen key through while you are installing it. Then when ready you pull out the allen key and you have instant tension.
The distance that it protrudes is important to get the right tension. You will need to check out the manual to see how far.
Similar setup on the 1UZ V8 motor. To fit it I simply used longer bolts until it was compressed enough to fit the shorter bolts. Then you change one bolt at a time and continue to tighten it up.
Mr DOHC
Re: 1jz - what is this thing? Thu, 10 June 2004 12:29 Go to previous messageGo to next message
if u can push it in with your hand then its basically fucked, u SHOULD have to use a vice,
if that is fucked then that could be your problem
deesonet
Toowoomba
Re: 1jz - what is this thing? Fri, 11 June 2004 11:15 Go to previous messageGo to next message
Specs for V8 version is for at least 100kg of pressure to push it in.
Not sure of 1JZ version but I would expect it to be similar.
Chris Davey
sunny coast, qld
Re: 1jz - what is this thing? Fri, 11 June 2004 23:46 Go to previous message
thanks everyone. I will test it when I get a chance.
Previous Topic:IRS for 86?
Next Topic:correct adhesive for gear shifter. . .
Current Time: Sat Oct 10 00:24:12 UTC 2026
Total time taken to generate the page: 0.005281925201416 seconds
