Toymods » Tech & Conversions » bellhousing/clutch cost
psi3y
perth
bellhousing/clutch cost Wed, 09 June 2004 04:54 Go to next message
im doing a 7mgte into a hilux. for this i need a w** to m series bellhousing which everyone throws away for their conversions, including everything to flywheel. so clutch, press plate, slave cyl etc. i have a quote at $440 for it and i wonder if this is a good price. would be champ if some of you guys could give me an idea. cheers
bbaacchhyy
Re: bellhousing/clutch cost Wed, 09 June 2004 05:14 Go to previous messageGo to next message
It all depends on the condition of the parts, especially the flywheel, clutch & pp, and what your intentions (power wise) for the car.
As an example, I have gotten a W58 (ex MA70 7M-GE including bellhousing), pedals, clutch m/cyl, flywheel, PP & clutch plate, & pedals & shifter for $500.
I sold the MA70 clutch pedal, clutch m/cyl, brake pedal for $80 (I needed the MA61 which is slightly different), the std flywheel, clutch & pp was sold for $25, and the bellhousing (a spare one) was sold for about $65.
Unless the parts are in good nick or upgraded, $440 sounds a bit high.
Michael B
psi3y
perth
Re: bellhousing/clutch cost Wed, 09 June 2004 06:12 Go to previous messageGo to next message
so a better price would be around the $300 mark?
bbaacchhyy
Re: bellhousing/clutch cost Wed, 09 June 2004 06:16 Go to previous messageGo to next message
meh ?
As I said before, it depends. What spec stuff are you getting and what condition is it in ?
What was it last used on ?
Are you in a hurry ?
Whoo are you buying it from ?
A reasonable price varies for each person. Smile
wilbo666
Re: bellhousing/clutch cost Wed, 09 June 2004 07:01 Go to previous messageGo to next message
Also another thing to bear in mind, if you are putting it behind a 7mgte is the flywheel size. I believe that 2 different flywheel sizes came out behind M series motors connected to W5X geraboxes (not R154's), one taking a 225mm clutch palte and one a 236mm/240mm clutch plate.
The 5M-E's had the 225mm clutch plate one the 5MGE/7MGE's got a 236mm/240mm clutch plate.
With a 7mgte I'd try and get the larger flywheel if possible to make clutch and pressure plate selection easier.
Thread on it was here
That price does sound a bit steep too.
psi3y
perth
Re: bellhousing/clutch cost Wed, 09 June 2004 07:19 Go to previous message
i only joined this forum 2 days ago and i already love it. thanks for the info.
the price is now $350 and it is from behind a 5mge so it should be the larger of the two. i am in WA remember so parts can be either extremely easy/cheap to get or the opposite.
thanks again for the info
Previous Topic:WANTED: microtech wiring diagram
Next Topic:i know rice BUT......
Current Time: Thu Nov 5 03:56:04 UTC 2026
Total time taken to generate the page: 0.021236896514893 seconds
