Toymods » Tech & Conversions » Trumpets/Velocity stack Q's
SPEEDCORE
GoldCoast/Brisbane
Trumpets/Velocity stack Q's Wed, 09 June 2004 05:57 Go to next message
Hi guys, tried doing a search but did not come up with much.....
With velocity stacks/trumpets how is the power effected by going longer or shorter than standard??
I would assume that if it is, than it is more the torque shifts along the rpm band, lower or higher depending right??
Speedy.
ed_ma61
Lost in the K hole
Re: Trumpets/Velocity stack Q's Wed, 09 June 2004 06:00 Go to previous messageGo to next message
long = more total torque, with low peak
short = less total torque, but peak higher in rpm band
shades of grey inbetween
the whole shebang has to be tuned quite specifically to each specific engine though: cam timing, rod stroke ratio, piston velocity, port volume, port velocity, runner dia etc etc
SPEEDCORE
GoldCoast/Brisbane
Re: Trumpets/Velocity stack Q's Wed, 09 June 2004 06:07 Go to previous messageGo to next message
Yeah I was thining that to have any "significant" gains or shifts in power.... it would need to be properly tuned and such.....
I gather it would be useless then just bolting them onto the throttles? For arguments sake on a Blacktop 20V.
ed_ma61
Lost in the K hole
Re: Trumpets/Velocity stack Q's Wed, 09 June 2004 08:20 Go to previous message
no, they will provide improved flow to the throttles, thus increasing peak flow numbers and peak HP, compaed to not having them fitted.
however, that improvent will be marginal at best unless tuned as mentioned above.
ed
Previous Topic:3SGTE pistons / 3SGE
Next Topic:7mge starter motors
Current Time: Sat Nov 21 09:26:17 UTC 2026
Total time taken to generate the page: 0.0044090747833252 seconds
