Toymods » Tech & Conversions » 7M-GTE and CT26 Turbo
SupremeDaisy
Eagleby, Queensland
7M-GTE and CT26 Turbo Wed, 09 June 2004 11:38 Go to next message
Just a quick question. How does one increase one of these to 12psi?
and if so should i get a copper head gasket as these old engines tend to blow quite easily.
In all respect the 7M-GTE is a torquey and powerfull engine (around 230hp stock) and i read that someone somewhere as had one of these engines up around 700hp by installing a 30psi turbo, no don't get me wrong, how does he keep it reliable with all that power, or is it complete nonsense?
Re: 7M-GTE and CT26 Turbo Wed, 09 June 2004 13:55 Go to previous messageGo to next message
12psi is a simple matter of fitting a bleed valve; a very common and painless procedure. A copper headgasket would be a good precaution, but you realise you have to completely strip the engine down to install one of those right? In any case the 7M's headgasket weakness is extremely well documented so I won't go into it any further; do a search and you'll be up to your elbows in useful information.
700hp from a 7M is certainly possible and it's been done plenty of times, but a lot of modifications are necessary to make a 7M hold together with that sort of power. You certainly won't get anywhere near that much with a stocker!
7M-Brisbane
Re: 7M-GTE and CT26 Turbo Wed, 09 June 2004 23:41 Go to previous messageGo to next message
INcreasing the boost to 12psi isn't really possible on one of these, you will find that you hit boost cut sometimes (if not all the time). About 11-11.5psi is the maximum, as sometimes it will spike and you'll think you blew it up Smile
Check the torque on the head bolts before you do anything else. Take it to a mechanic, and ask them to retorque it - I think the figure is 72 ft-lbs but please don't quote me on the exact figure.
While the car is at the mechanic, get them to do a full service including fuel filter, oil, oil filter, spark plugs, timing, etc. as well as any other routine servicing (eg timing belt if it's due).
Then, I would look at getting a full 3" exhaust system (not just a 'cat back') exhaust. This is your biggest power upgrade on a basic setup, and is probably worth about $900 give or take a little depending on how pretty you want it.
Once this is done, get a bleed valve fitted, and you are probably safe to run up around the 11psi mark as I said. I would not increase the boost without doing the exhaust first - one because the exhaust will strangel the power gain, and two because the exhaust housings on these turbos are known to crack and the restrictive exhaust dump won't be helping this.
A K&N (or similar) filter in the standard airbox should be your next modification.
7M-Brisbane
Re: 7M-GTE and CT26 Turbo Thu, 10 June 2004 00:19 Go to previous messageGo to next message
Oh, and don't even dream about running anything other than Optimax/Ultimate... standard unleaded and normal premium unleaded fuels are cr@p and will see you blowing up your engine in no time.
Jag7799
Re: 7M-GTE and CT26 Turbo Thu, 10 June 2004 00:33 Go to previous messageGo to next message
the way i am/will be running my 1jz is 3 weeks of ultimate and then 1 week of shell optimax.. optimax has more cleaners so im going to put it through once a month to keep it all good inside Smile
as a note.. john from importbitz's mz20 soarer made 198rwkw on 8 psi.. may not be on std turbo and have everything else done.. but that just shows how good the engine can be
imagine it with any sort of boost!
STR8 2.8
Re: 7M-GTE and CT26 Turbo Thu, 10 June 2004 01:53 Go to previous message
the 7M has the potential if you throw a whole wad of cash at it...
http://forums.toymods.org.au/index.php?t=msg&g oto=282815&rid=2064&S=26acc82f2f740c085ff5 4924380e60ad
[Updated on: Thu, 10 June 2004 01:53]
Previous Topic:4m efi
Next Topic:help with 4a-fe engine
Current Time: Wed Nov 18 13:13:46 UTC 2026
Total time taken to generate the page: 0.0062179565429688 seconds
