Toymods » Tech & Conversions » ae86 Clutch Line Heat and Exhaust (pics)
monkeymajik
ae86 Clutch Line Heat and Exhaust (pics) Wed, 09 June 2004 11:59 Go to next message
After changing the slave/master cylinders I've noticed that the clutch line right near the slave cyl, runs really close the the bottom of my extractors. Now I'd imagine it would get quite hot, are there any problems with it setup the way it is?
http://users.bigpond.net.au/monkeymajik/car/clutchDistance.jpg
http://users.bigpond.net.au/monkeymajik/car/clutchClose.jpg
http://users.bigpond.net.au/monkeymajik/car/clutchRealClose.jpg
[Updated on: Wed, 09 June 2004 12:01]
AE86slut
Baulko Hillo
Re: ae86 Clutch Line Heat and Exhaust (pics) Wed, 09 June 2004 12:04 Go to previous messageGo to next message
Dude, I'm facing exactly the same problem. I'm going to try to get a braided one made up tomorrow with an extra bit of length in it so it will run over the top of the extractors along the firewall. I'm going to try to get one with a banjo on the slave end as well, so it runs straight up.
I'll let you know how I go with it.
monkeymajik
Re: ae86 Clutch Line Heat and Exhaust (pics) Wed, 09 June 2004 14:29 Go to previous messageGo to next message
I'd be very interested to see how you go, where are you going to get the hose/fittings?
[Updated on: Wed, 09 June 2004 14:30]
Henn
Rosanna, Melb
Re: ae86 Clutch Line Heat and Exhaust (pics) Thu, 10 June 2004 00:54 Go to previous messageGo to next message
Get a banjo put on the end of the line that attaches to the slave cylinder. So you can point it out of the way.
Will still be close, but I have had no trouble at all with mine like that.
Hen
Can't see from the pictures, but if you run bundy tubing all the way to the slave then put some rubber in there. Allows for engine twist.
AE86slut
Baulko Hillo
Re: ae86 Clutch Line Heat and Exhaust (pics) Thu, 10 June 2004 01:29 Go to previous messageGo to next message
Ok, went to Motorsport Connections at Seven Hills. They made one up on the spot out of braided high temp teflon line with a banjo on the slave end - $60!
Awesome considering Pirtek quoted $160-$180 and couldn't even put a banjo on the end!
Jeremy.
ae86drift
sydney.au
Re: ae86 Clutch Line Heat and Exhaust (pics) Thu, 10 June 2004 02:32 Go to previous messageGo to next message
i have an earls braided one on mine - $50
but its JDM so its on the other side of the gearbox
monkeymajik
Re: ae86 Clutch Line Heat and Exhaust (pics) Thu, 10 June 2004 02:45 Go to previous messageGo to next message
That's a complete new line?
Hmm I'll have to ring around a few places here in brisbane.
Edit: Pirtek just told me they werent allowed to do it due to legal reasons. I always thought that was a brake line thing.
Edit2: Found something. HMS Automotive have a kit available which I'm going to use.
[Updated on: Thu, 10 June 2004 03:11]
PerformanceCars
Re: ae86 Clutch Line Heat and Exhaust (pics) Thu, 10 June 2004 05:49 Go to previous messageGo to next message
Mine looks very similar to the pic above, have had it in the car doing drift days/track days/general driving and have never had my clutch fluid be a problem.
That said i still want to put some heat shielding in or move the line.
shinybluesteel
melbourne
Re: ae86 Clutch Line Heat and Exhaust (pics) Thu, 10 June 2004 06:00 Go to previous messageGo to next message
stupid question, i have looked at my slave cylinder and decided i will do the banjo thing,
the pipe adaptor that bolts into the slave isn't tapered is it? if it is i couldnt see a banjo fitting working.
RobertoX
Re: ae86 Clutch Line Heat and Exhaust (pics) Thu, 10 June 2004 07:48 Go to previous messageGo to next message
Hey, I got one from anthony Kellam on these forums for something like $20... it runs over the top of the headers accross the firewall... (oh yeah and despite what people have said about him I recieved mine within a few days of emailing)
Flogbag
Sydney (Campbelltown...!)
Re: ae86 Clutch Line Heat and Exhaust (pics) Thu, 10 June 2004 08:07 Go to previous messageGo to next message
hey monkeymajik
your line doesnt seem to have a rubber section wouldnt this cause the metal pipe to stretch when the engine is under load and twisting
i am just putting a longer brake hose line in mine with a banjo fitting and then i went round and found a banjo nut that fitted
all for $10
monkeymajik
Re: ae86 Clutch Line Heat and Exhaust (pics) Thu, 10 June 2004 08:16 Go to previous messageGo to next message
No it doesnt have a rubber section, it was like that when I got the car a few months ago. There is ample length of line and it does stretch and move.
I'm replacing the whole line shortly anyway Smile
allencr
tallahassee FL usOFa
Re: ae86 Clutch Line Heat and Exhaust (pics) Thu, 10 June 2004 14:24 Go to previous messageGo to next message
i wouldn't trust that steel line to continue to "flex" for much longer, unless you've got solid motor mounts. it sure didn't come from the factory that way.
it looks you can probably swap the bleeder & inlet around if there are clearance/routing problems, at least on most slaves.
Youngy
Eskilstuna, Sweden
Re: ae86 Clutch Line Heat and Exhaust (pics) Fri, 11 June 2004 01:43 Go to previous messageGo to next message
If your worried about heat soak you could always use that heat shielding sheaths that you slip over the line. Quick and easy to fit too.
monkeymajik
Re: ae86 Clutch Line Heat and Exhaust (pics) Sat, 12 June 2004 01:24 Go to previous messageGo to next message
RobertoX wrote on Thu, 10 June 2004 17:48
Going to drag this up again, but does anyone have a pic of this kit installed?
Re: ae86 Clutch Line Heat and Exhaust (pics) Sat, 12 June 2004 07:02 Go to previous messageGo to next message
i used the "clutch re-alignment kit" from anothoney kellam, it runs the hose over the top of the extractors and uses a banjo bolt on the slave cylinder and tha factory AE71 lines
chrizer
Re: ae86 Clutch Line Heat and Exhaust (pics) Sat, 12 June 2004 07:07 Go to previous messageGo to next message
Hey WHITZL,
how close are your extractors to the clutch fork??
Satoshi
Re: ae86 Clutch Line Heat and Exhaust (pics) Sat, 12 June 2004 08:11 Go to previous messageGo to next message
since this topic is up..this is mine..
the clutch line is TOUCHING the extractors..what should i do about it besides getting braided lines
http://www.njsr.org/pics/albums/userpics/10462/normal_P1010042.JPG
shinybluesteel
melbourne
Re: ae86 Clutch Line Heat and Exhaust (pics) Sat, 12 June 2004 08:29 Go to previous messageGo to next message
fitst thing is zip tie/wire it the hell away form there!
Satoshi
Re: ae86 Clutch Line Heat and Exhaust (pics) Sat, 12 June 2004 08:39 Go to previous messageGo to next message
Laughing
secondly??
AE86slut
Baulko Hillo
Re: ae86 Clutch Line Heat and Exhaust (pics) Sat, 12 June 2004 09:35 Go to previous messageGo to next message
Secondly, get a braided line....
Satoshi
Re: ae86 Clutch Line Heat and Exhaust (pics) Sat, 12 June 2004 16:04 Go to previous messageGo to next message
what will happen if i dont put it out of the extractor? clutch failure?
RobertoX
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 02:24 Go to previous messageGo to next message
You dont NEED a braided line, a standard type rubber one will be fine. Just get a longer one with the banjo fitting. This directs the line at 90deg to where it normally goes so its not going straight into the exhaust.
Your clutch wont fail as such, you will just loose the ability to actuate it. The line will probably crack and leak hence you cannot push the clutch in. this isn't that fun really (but you may learn to shift without clutch pretty quick if you want to get home Razz )
Once you do get home you can change the line and the clutch will still work, so changing it in the first place will avoid this scenario...
AE86slut
Baulko Hillo
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 03:35 Go to previous messageGo to next message
RobertoX wrote on Sun, 13 June 2004 12:24
True, you don't NEED a braided line, but I just reckon if you're gonna replace it, you might as well do it properly to avoid any potential problems in the future. Just pece of mind really.
That's my $0.35
Satoshi
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 05:48 Go to previous messageGo to next message
i have no idea what banjo fitting is all about..it sounds like a egg burger to me in my country.. Laughing
anyone got a picture of how it looks like or something?
AE86slut
Baulko Hillo
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 05:57 Go to previous messageGo to next message
It's a fitting that looks kinda like a..... erm...... banjo....
Look up 'banjo fitting' or something in google. Tis easy mate.
Satoshi
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 06:08 Go to previous messageGo to next message
i hope it doesnt come out an egg buger in googles..
AE86slut
Baulko Hillo
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 06:20 Go to previous messageGo to next message
I'll put a pic of mine up if someone wants to host it.....
Satoshi
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 06:51 Go to previous messageGo to next message
i'll host it for ya..
pm on the way
Satoshi
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 07:09 Go to previous messageGo to next message
http://www.njsr.org/pics/albums/userpics/10462/clutchline.jpg
so i assume the banjo fitting is the squarish end?
AE86slut
Baulko Hillo
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 07:14 Go to previous messageGo to next message
It's the fitting towards the top of the pic..... it's actually round and has a hollow bolt the screws into it and into the hole that your normal line would screw into so you can have the line coming off at 90 degrees straight off the slave, rather than having it straight out into the path of your extractors.
AE86slut
Baulko Hillo
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 07:20 Go to previous messageGo to next message
Satoshi - Check your email. I just sent a banjo fitting pic.
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 07:55 Go to previous messageGo to next message
i still dont see the need for a braided line, can you please explain why you think its piece of mind over a rubber hose type?
ae86drift
sydney.au
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 08:04 Go to previous messageGo to next message
becoz karl, everyone knows more bling is betterer!
*duhhhh* Razz Razz Razz Razz
there is no real advantage i suppose apart from consistent pedal feel... not that ive noticed anyhow
AE86slut
Baulko Hillo
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 08:21 Go to previous messageGo to next message
THE WITZL wrote on Sun, 13 June 2004 17:55
DERRRR Witzl - Coz the Icy Hot Stuntaz told me it's better... And dey be KNOWIN' what's BLING yo! They is REAAAAALLL Yo.
Ummm...... I just think that coz the standard rubber one does not normally have a friggin exhaust rubbing it's thighs..... It's just my opinion dude. Plus as Garth mentioned, it MAY give more consistent pedal feel, although I think this relates more to brakes.
I dunno! I'll just go ask 'Freeze'....
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 08:46 Go to previous messageGo to next message
as far as i know, the hydraulic pressure of a clutch line is about 10 times LESS than that of a brake line, so a difference in pedal feel would be unmeasurable.
The heat issue really isnt a problem if you get the banjo fitting and run the line OVER the top of the exhaust, if you want assurance then wrap the bastard.
My last problem with braided lines is that there are 1000s of brands selling braided hydraulic lines, but VERY FEW of them are actually approved by the relevant authorities.
PLus.... it costs around about $15 to get a rubber hose MADE to your specs at a decent brake/clutch shop vs ~$50 for a braided one.
AE86slut
Baulko Hillo
Re: ae86 Clutch Line Heat and Exhaust (pics) Sun, 13 June 2004 09:37 Go to previous message
Oh well, each to their own eh? I chose to get a braided line. What other ppl do is up to them.
Very Happy
Previous Topic:POR15 - any experience with this product
Next Topic:Cars pulls one way when wheels spin?
Current Time: Wed Oct 28 03:53:33 UTC 2026
Total time taken to generate the page: 0.0079259872436523 seconds
