Toymods » Tech & Conversions » How to put AE101 dials into AE82 dash
How to put AE101 dials into AE82 dash Wed, 09 June 2004 13:40 Go to next message
This is just a quick pictoral guide to how i managed to make singlecam's AE101 GTZ dials from the front cut work in his AE82 dash.
Its what i like to call a plastic cut'n'shut.
Basically, i took apart the two different instrument clusters, and investigated the way each mounted and operated. Tim wanted pretty mcuh all the dials, but i decided that it would be far easier to just give him the speedo and tacho (especially since he wasnt paying me! Razz) and keep the AE82 fuel and temp guages and warning lights etc.
The AE101 also uses an oil "idiot light" rather than a guage, so there was no hassles there.
NB: there is a lot of fucking around with electronics invloved in this mod, so unless you are pretty capable electronically and understand how most auto electrics work, then DONT undertake this conversion!
This is the shell mounting for the AE82 dash, with everything removed.
http://www.rollamods.com/witzl/Tim%20gze/dash/dash1.jpg
Here you can see the AE101 shell thingy, and in front you can see how i have cut off the end pieces from the AE82 shell. These cut off bits are the parts that house the temp, fuel and warning lights.
http://www.rollamods.com/witzl/Tim%20gze/dash/dash2.jpg
Here's what i did to both shells...
http://www.rollamods.com/witzl/Tim%20gze/dash/dash4.jpg
And whats going to happen, thanks to a little friend called araldite!
http://www.rollamods.com/witzl/Tim%20gze/dash/dash5.jpg
http://www.rollamods.com/witzl/Tim%20gze/dash/dash6.jpg
Add some instruments to test fit....
http://www.rollamods.com/witzl/Tim%20gze/dash/dash7.jpg
Do some mods to the cover faces courtesy of a hacksaw and file....
http://www.rollamods.com/witzl/Tim%20gze/dash/dash8.jpg
Here it is mounted and operational in Tim's car.... yes the car IS RUNNING!
http://www.rollamods.com/witzl/Tim%20gze/dash/dash9.jpg
And this is why you dont want to do this....
http://www.rollamods.com/witzl/Tim%20gze/dash/dash10.jpg
Re: How to put AE101 dials into AE82 dash Wed, 09 June 2004 14:03 Go to previous messageGo to next message
Now that's some dodgy shennanigans I'd be proud of. Well done! Laughing
NuGeN
Re: How to put AE101 dials into AE82 dash Thu, 10 June 2004 13:56 Go to previous messageGo to next message
I was thinking of doing something similiar when I was rewiring a different cluster into my ae92 corolla.
I was thinking of getting a oil pressure gauge from someone's ae101 20v cluster and adding it to my cluster, but I found out that the oil pressure sender was like 100 something bucks and there are oil pressure gauges come cheaper nowadays.
So is the speedo still accurate? Did toyota keep the same ratio's between models? (Mine was both stamped with 637rpm->1km)
Grega
melbourne.victoria.austra...
Re: How to put AE101 dials into AE82 dash Thu, 10 June 2004 20:10 Go to previous messageGo to next message
thats some impressive work there karl. nice one.
Re: How to put AE101 dials into AE82 dash Fri, 11 June 2004 08:00 Go to previous messageGo to next message
erm.... considering that we put the 4A-GZE engine, gearbox, driveshafts and hubs then all the speedo will be correct, dont you think?
Apparently the oil light doesnt work now... but thats got nothing to do with me Razz
BlackSupra
Re: How to put AE101 dials into AE82 dash Fri, 11 June 2004 09:52 Go to previous messageGo to next message
maximum dodge!
i like it Very Happy
I would like you to put a JZA80 dash in my MA61....for a carton of beer of course Laughing
Satoshi
Re: How to put AE101 dials into AE82 dash Fri, 11 June 2004 10:11 Go to previous messageGo to next message
56k killllarrrr!
but not me Very Happy
well done...what did u do to cover the face black? spray??
Re: How to put AE101 dials into AE82 dash Sat, 12 June 2004 05:59 Go to previous messageGo to next message
glen... i would have to have a look at the two and compare - but i would need the ENTIRE JZA80 cluster, not just dials.
As for covering the face, i just used the factory face cover from the AE101, and hacked it up a bit...
TRD-ST162
Re: How to put AE101 dials into AE82 dash Sat, 12 June 2004 09:18 Go to previous messageGo to next message
96,*** kms on the clock???
Bloody hell thats low arse kms for a ae82 twincam.... Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy
Wow that looks heaps better... I love the racy look of the ae82 twincam ones still the best, i reckon the dash looks really sporty on the twincams
NOICE WORK!!!!
midnight
Re: How to put AE101 dials into AE82 dash Sat, 12 June 2004 11:42 Go to previous message
great job untill you mounted that cut up plastic surround bit..
fix that and it would be perfect.
Very Happy
Previous Topic:Stiff suspension = loose eveything
Next Topic:1JZ injector flow rate?
Current Time: Thu Oct 22 06:56:59 UTC 2026
Total time taken to generate the page: 0.006227970123291 seconds
