Toymods » Tech & Conversions » 1UZ firing order and wasted spark config.
Grega
melbourne.victoria.austra...
1UZ firing order and wasted spark config. Wed, 09 June 2004 22:01 Go to next message
Just doing my research it seems that the 1UZ firing order is 1 8 4 3 6 5 7 2 - in its standard config.
I want to run aftermarket ignition control, with, 4 lots of paired coils, in a wasted spark setup.
What cylinders do I pair together per coil? I'm guessing ;
1&6, 8&5, 4&7 and 3&2
Anyone?
Re: 1UZ firing order and wasted spark config. Wed, 09 June 2004 23:08 Go to previous messageGo to next message
At a quick guess without thinking about it, pair up whatever injectors are paired up.
Failing that method being correct, go with what you wrote above.
Skip
Re: 1UZ firing order and wasted spark config. Wed, 09 June 2004 23:27 Go to previous messageGo to next message
Provided the firing order is correct, yes you are right.
Grega
Re: 1UZ firing order and wasted spark config. Thu, 10 June 2004 02:09 Go to previous messageGo to next message
hmm, i wouldn't want to pair up coils the same as injectors ; the injectors from what i gather are paired as 1&7, 2&8, 4&6 and 3&5....wasted spark runs on the exhaust stroke of the opposite cylinder, so i don't think i'd want to be putting fuel there at the same time somehow.....or does batched fuel injection do this anyway?
anyone>?
Re: 1UZ firing order and wasted spark config. Thu, 10 June 2004 02:36 Go to previous messageGo to next message
Yeah, ignore my injector pairing theory, I forgot how they were connected (and yes, the pairings are as you have stated)
And you have the firing order correct.
So yeah pair up the coils as per TDC and BDC
Skip
Re: 1UZ firing order and wasted spark config. Thu, 10 June 2004 04:38 Go to previous messageGo to next message
They wont be TDC-BDC, they will be TDC-TDC.
Re: 1UZ firing order and wasted spark config. Thu, 10 June 2004 04:58 Go to previous messageGo to next message
Bah, its too early I say
Re: 1UZ firing order and wasted spark config. Thu, 10 June 2004 05:01 Go to previous messageGo to next message
Yeah, you're right Greg. Forget injectors etc., all you have to do is make sure the cylinders you pair are fired 1 revolution apart. Evil or Very Mad
Grega
um, yeah. 1 at TDC ignition, 1 at TDC exhaust...
Grega
Re: 1UZ firing order and wasted spark config. Thu, 10 June 2004 05:02 Go to previous messageGo to next message
yes shin. egg zaccery
will pull plugs and turn over by hand to confirm. only way to be 1000000000000000000000000000000000000000% (how many percent) sure.
Re: 1UZ firing order and wasted spark config. Thu, 10 June 2004 05:12 Go to previous messageGo to next message
Grega wrote on Thu, 10 June 2004 13:02
Meh, if you get it wrong, its only 2 mins of wiring to fix
sideshow
Re: 1UZ firing order and wasted spark config. Thu, 10 June 2004 06:42 Go to previous message
1 8 4 3 6 5 7 2
wouldnt it be
either
16 85 47 12 just a guess as when 1 is at comp maybe 6 is at exhaust
or
12 87 45 36
this is similar way we do the nissan 6 cly i think
Previous Topic:info on 3t engines Wanted
Next Topic:Comparision of steering arms
Current Time: Wed Nov 18 20:10:47 UTC 2026
Total time taken to generate the page: 0.0058999061584473 seconds
