Toymods » Tech & Conversions » crank case breather, do i need it
ta2272
crank case breather, do i need it Thu, 10 June 2004 01:09 Go to next message
i have a breathe working on the tapper cover, thought my crank case breather has been blocked of on my 2tg shoudl i install one of these, and run it to a oil cacth can which i am intalling soon.
jason
RWDboy
Re: crank case breather, do i need it Thu, 10 June 2004 01:32 Go to previous messageGo to next message
Yeah why not.
(short answer)
Super Jamie
On Probation
North East NSW
Re: crank case breather, do i need it Tue, 15 June 2004 02:14 Go to previous messageGo to next message
does the the crankcase breather go to anywhere (such as hose or air cleaner)? does it go beneath the carb via a pcv valve? if it's the former, a breather on its own doesn't really matter, i've torn mine off and am using one of those little chrome redline filters
but if we're talking a pcv system then it's a good idea to keep it, as your oil will foul a LOT quicker without it hooked up, which isn't good for engine lubrication and longevity. if you don't like the idea of crankcase gases in your combustion chamber, you can run one of those $1 fuel filters inline to clean the air up. or you can go to the trouble of installing an oil air separator (catch can). i personally think a catch can works a lot better with engine vacuum still hooked up to it, some people beg to differ
hope this helps
RWDboy
Re: crank case breather, do i need it Tue, 15 June 2004 02:27 Go to previous messageGo to next message
That's the longer answer! I pretty much agree with everything in there.
I'll second that getting a catch can (oil/air separator if you like technical sounding terms) is a good idea.
We have a catch can set up on the Mk II Escort rally car without vacuum and it seems to work well enough. I can see how the vacuum could (and would) help. It's all up to personal preference.
indian
south east - melbourne
Re: crank case breather, do i need it Tue, 15 June 2004 02:34 Go to previous messageGo to next message
OK AS FAR AS I KNOW THE OIL CATCH CAN GOES IN THE MIDDLE OR SOMEWHERE ON THE BREATHER HOSE
whats the vaccum got to do with that
Sad Sad Sad Sad Sad Sad Sad Sad
sorry just dont know much about it and like to know
Super Jamie
On Probation
North East NSW
Re: crank case breather, do i need it Tue, 15 June 2004 02:56 Go to previous messageGo to next message
a pcv system (positive crankcase ventilation) uses manifold vacuum to suck dirty air (oil vapours, blowbym etc) out of the crankcase and puts it in the manifold where it travels into the combustion chamber and is burnt during ignition. it does slightly pollute the air fuel mixture, but not much, though that gets worse as your engine gets old and shagged out
the system uses a valve (called the pcv valve) to regulate when the dirty air can flow into the manifold. crankcase air is allowed into the manifold under high vacuum (idle, deceleration, cruise). the valve stops the flow of air under low/nil vac conditions (acceleration) so you get a good air fuel mix when required
just putting a crankcase breather on instead of the PCV valve did nothing for me in my 4K. maybe that's the way K motors are designed, they do have a baffle in the tappet cover, which i removed but it just made a big mess as oil splashed up from the rocker gear. other engines may be different, but if i ran a catch can i'd be using manifold vacuum to help suck air into it
monkeymajik
Re: crank case breather, do i need it Tue, 15 June 2004 03:00 Go to previous messageGo to next message
One little note, not all systems have a valve, 4ag* engines just have a straight through line.
M.W.P.
Rocky Mountains, Canada
Re: crank case breather, do i need it Tue, 15 June 2004 03:25 Go to previous messageGo to next message
BTW... having negitve pressure (a vaccumm) in the crankcase increases slightly engine performance (stops blow-by), helps to stop oil leaks, and increases oil life.
Set it up properly... there is a good reason why they do it from the factory.
indian
Re: crank case breather, do i need it Tue, 15 June 2004 03:38 Go to previous messageGo to next message
ok i have a 1g-gte engine series 2 what the hell is in that motor , im pretty surei didnt notive a pcv valve ,
should i just cut the hose going from the throttle body to the turbos and join the catch can there
RobST162
Re: crank case breather, do i need it Tue, 15 June 2004 03:43 Go to previous messageGo to next message
the Gen1 3SGEs also do not have a PCV valve, they just have a breather hose so basically, you have more "pollution" of your intake air the more harder you are pushing your car... so I feel that catch cans can be quite beneficial in this area..
again, depends on how worn your rings are etc
I recently installed one I have some pix on this page of my thread
[Updated on: Tue, 15 June 2004 03:44]
Super Jamie
On Probation
North East NSW
Re: crank case breather, do i need it Tue, 15 June 2004 05:12 Go to previous message
i guess a 4age and 3sge are going to be cleaner internally running motors (than my 1960s-tech 4k anyway), as they have smaller less-floaty rings and probably alot tighter clearances, so the need for a pcv valve on a standard motor wouldn't really be there
however, do some (real) mods to one of these modern motors, and i'd definately agree that an inline fuel filter or vacuum-assisted catch can would be the way to go. you'd probably even add another 50000+km to the life of the engine by running one from new, if you fancy driving your 4a into the ground
Previous Topic:20V extractors on 100KW ?
Next Topic:AE101 Expansion Plans
Current Time: Thu Nov 19 15:09:48 UTC 2026
Total time taken to generate the page: 0.0058929920196533 seconds
