Toymods » Tech & Conversions » correct adhesive for gear shifter. . .
bayka
perth
icon12.gif  correct adhesive for gear shifter. . . Thu, 10 June 2004 05:14 Go to next message
Hey guys, i know this is fairly trivial put it is causing me PAIN!
Ive cut my gear stick far below the thread, so when i attached a apare aftermarket (non-clamp) shifter i used liquid nails, however in warmer weather the stick can turn and move around a bit.
Anyone know of an adhesive that will set like a rock without oxygen?
Smile
Re: correct adhesive for gear shifter. . . Thu, 10 June 2004 05:36 Go to previous messageGo to next message
See if a local panel shop will spare you a bit of Sika Flex Evil or Very Mad
ed_ma61
Lost in the K hole
Re: correct adhesive for gear shifter. . . Thu, 10 June 2004 06:31 Go to previous messageGo to next message
sika flex do a whole range of sealant/adhesives... i used one of their adhesives for this exact job, but it too ended up twisting...
ive got the product number of the one i used the second time around which (so far) has proved to be perfect. ill dig up the number and get back to you
bayka
perth
Re: correct adhesive for gear shifter. . . Thu, 10 June 2004 06:42 Go to previous messageGo to next message
Wiked Cheers Surprised
Lambolica
Northwestern Sydney
Re: correct adhesive for gear shifter. . . Thu, 10 June 2004 07:16 Go to previous messageGo to next message
Would help to roughen up the top section of the shaft where the knob will be as the adhesive needs somthing to bite to. Smooth metal not being one of those.
StuC
Re: correct adhesive for gear shifter. . . Thu, 10 June 2004 08:38 Go to previous messageGo to next message
or see if you can borrow or hire a tap/die set from bunnings or a mate or something, then just get the correct thread spacing n run that down ur stick.No more glue needed
ed_ma61
Lost in the K hole
Re: correct adhesive for gear shifter. . . Thu, 10 June 2004 09:13 Go to previous messageGo to next message
StuC wrote on Thu, 10 June 2004 18:38
if its a vibration damping shifter theres not enough material to tap, so adhesive is the only real option.
ed
Re: correct adhesive for gear shifter. . . Fri, 11 June 2004 11:01 Go to previous messageGo to next message
Or else do what I do, remove the rubber section, and weld a sensible sized/length piece of steel onto there, and run a thread on the end Evil or Very Mad
M.W.P.
Rocky Mountains, Canada
Re: correct adhesive for gear shifter. . . Fri, 11 June 2004 15:55 Go to previous messageGo to next message
Drill small holes into the top of the stick, and scuff up the inside of the knob with a knife.
Liquid nails is too soft... use epoxy or somthing like that.
fade-e
Re: correct adhesive for gear shifter. . . Fri, 11 June 2004 23:44 Go to previous message
or you can do a dodgy and not use the shifter... i keep mine in the glove box, when i get pulled over or anything i just pull it out, whack it on and no ones the wiser...
i do this cause i hate gear knobs, even the slim line ones... in my TA22 i got the T50, pulled out the grinder, cut it in half, filed the edge to remove sharpness and away we go
Previous Topic:1jz - what is this thing?
Next Topic:broken ke55 clutch cable end help please urgent!
Current Time: Mon Nov 23 01:40:49 UTC 2026
Total time taken to generate the page: 0.015242099761963 seconds
