Toymods » Tech & Conversions » 1ggze speedo input?
1UZ FTE
1ggze speedo input? Fri, 11 June 2004 01:39 Go to next message
Does a 1ggze which was origninaly an auto and has been converted to a manual require the speed input signal from the back of the speedo to stop the computer going into limp home mode ?
Does it maybe use this signal to switch the supercharger on off points ?
jamie
ChuckLandwehr
Re: 1ggze speedo input? Sat, 12 June 2004 06:38 Go to previous messageGo to next message
Hi Jamie, seeing as no one has yet replied, let me share my experience with you. Sorry it is not direct 1GG-ZE! Both 1G conversions I have done did not go into limp mode, without signal from Auto. One was a 1GG-FE, and the other was a 1GG-TE. The other conversion with a 1JZ-GTE, also had no limp home problems when connected to a manual box.
From my understanding of the Toyota SC, they are switched by engine speed, on at RPM greater than 1800, and vacuum/boost air valves, and TPS ie. over run with boost still available would be a bitch!. Hope this helps in some way.
regards Chuck.
1UZ FTE
Re: 1ggze speedo input? Mon, 14 June 2004 22:25 Go to previous messageGo to next message
Thanks Chuck
I will let the boys know to give it a go without this connected,..
much appreciated for your reply
Jamie
ddeane
PNG
Re: 1ggze speedo input? Mon, 14 June 2004 23:32 Go to previous message
Jamie
Like Charles I have not done a auto conversion, but have done a manual (1ggteu). Also like Charles I do not believe that the speed sensor has any effect on the auto. I do have a engine manual for a 1ggzeu and there is no mention in the diagnostic codes that indicates any concern. The translation of these codes are in the Tech Docs section on this site.
From what I can determine the speed sensor has three effects (note the signal is obtained from a sensor actuall connected to the speedo). One, once you exceed 3,000rpm for a given period of time - I think it is 30 seconds - the engine check light will come on and store a diagnostic code to this effect. Second, the computer seems to use the speed to determine if the vehicle is still mobile 'cos when it does not get a speed reading when you take you foot off the throttle it gives the faintest beep, - possibly read idle up - to stop the engine stalling. This is not a real problem and is still hard to detect, but now I have told you will annoy the hell out of you. AND three, speed cut @ 180kph.
I have used a cruise control sender connected to the tailshaft to provide the signal to the computer. This solves all of the problems including the spped cut as the signal is only 25% of that of the factory setup and u would have to be doing 720 kph.
Hope all of that helps.
Craig
Previous Topic:GZE KNOCK SENSOR
Next Topic:Dodgy tacho and instruments
Current Time: Thu Nov 19 14:40:48 UTC 2026
Total time taken to generate the page: 0.027215003967285 seconds
