Toymods » Tech & Conversions » Cleaning Solex Carbs
SIKTA22
Cleaning Solex Carbs Fri, 11 June 2004 02:42 Go to next message
Ive got a set of solex sidedrafts that i havnt used for about 3years, they have been sitting doing nothing and im thinking about throwing them on my 2TG, thing is over time it has accumulated dirt all over them and i noticed this morning that a little bit of dirt has made its way into where the fuel lines are attached to the carbs.. what i want to know is, is there anyway i can clean the inside without pulling apart the carb and hoping that they still work? maybe i could soak them totally in something? or spray some carby cleaner in it perhaps?
any suggestions appreciated.
cheers.
ae86slideways
warrnambool VIC
Re: Cleaning Solex Carbs Sat, 12 June 2004 11:21 Go to previous messageGo to next message
You should be safe enough to remove the top and jets and blow compressed air through the passages,then carby clean the outside.just inspect the jets and emulsion tubes for crud in them while they are out.dont forget to check and adjust the float levels before you fire the motor up.
SIKTA22
Re: Cleaning Solex Carbs Sat, 12 June 2004 12:14 Go to previous messageGo to next message
checking and adjusting the float levels im probably gonna get stuck on, im pretty sure the 2TG manual has something on that? ill have to look through it again, but i was thinking about doing the same, just wasnt 100% sure.. thanks 4 the reply Smile
NILE8U
Glenmore park, Sydney
Re: Cleaning Solex Carbs Sat, 12 June 2004 14:15 Go to previous messageGo to next message
i got a TA22 early 72 model with the 5 speed and 2TG motor in it, unblocking the carbs is not your only problem, wait till ya have to tune the bastards in! talk about a nightmare!
SIKTA22
Re: Cleaning Solex Carbs Sun, 13 June 2004 00:47 Go to previous message
yeah im going to leave the tuning for a carb expert.. Smile although my 2tg isnt totally stock so they will have to be tuned properly..
Previous Topic:solex reco gaskets
Next Topic:ke3x pic inside door needed please help!
Current Time: Sun Oct 25 13:50:31 UTC 2026
Total time taken to generate the page: 0.0064980983734131 seconds
