Toymods » Tech & Conversions » ST165 LSD?
stumpy
perth WA
icon5.gif  ST165 LSD? Sat, 12 June 2004 03:17 Go to next message
G'day, I am wanting to know if I can get a plate type LSD for the rear diff of my ST165, or can I transplant one from another vehicle Up To Something
Jeff
Classique71
Colac, Victoria
Re: ST165 LSD? Sat, 12 June 2004 04:55 Go to previous messageGo to next message
you could try slotting in a st185 unit , they are a torsen job .. Not 100% if it fits though - i know the 205 and 185 ones are interchangable .
stumpy
perth WA
Re: ST165 LSD? Sat, 12 June 2004 09:03 Go to previous messageGo to next message
The ST165 comes out standard with a Torsen rear diff. I was told that the plate type LSD was a better option. Then again, someone could be pulling my chain Shocked
Classique71
Colac, Victoria
Re: ST165 LSD? Sat, 12 June 2004 11:16 Go to previous messageGo to next message
the torsens fine!
the only upgrade path worthy IMHO is to the TRD version , though inall honesty do you plan to put big HP thru the driveline ?
A better investment would be an st205 Gearox + front LSD if you can track one down ..
stumpy
perth WA
Re: ST165 LSD? Sat, 12 June 2004 11:44 Go to previous messageGo to next message
The car will see a bit of gravel so i want some good rear end grip Evil or Very Mad i will look out for the ST205 setup. But trying to get a hold of a TRD LSD Razz I dont like my chances.
Jeff
Classique71
Colac, Victoria
Re: ST165 LSD? Sat, 12 June 2004 11:58 Go to previous messageGo to next message
Charoen had a st205 rear i think ..
re TRD rear LSD - yeah - options are slim to fuck all chance ..
You could always ask Neal bates motorsport in canberra if they have a second hand unit .. Otherwise its new im afraid Sad
RWDboy
Re: ST165 LSD? Sat, 12 June 2004 14:50 Go to previous messageGo to next message
What kind of centre diff does the ST165 have? I know the front is an open 50/50 torqu split, and the rear is a torsen LSD, but what is the centre? Planetary gear setup open diff?
stumpy
perth WA
Re: ST165 LSD? Sat, 12 June 2004 15:23 Go to previous messageGo to next message
it is a viscous coupling center diff on the ST165 as far as I know Smile
RWDboy
Re: ST165 LSD? Sat, 12 June 2004 17:01 Go to previous messageGo to next message
I guess you'd have to take the front gearbox apart to find out?
Classique71
Colac, Victoria
Re: ST165 LSD? Sun, 13 June 2004 03:37 Go to previous messageGo to next message
re centre diff that i dont know, but i will try to clarify
stumpy
perth WA
Re: ST165 LSD? Tue, 15 June 2004 11:42 Go to previous messageGo to next message
The center diff is a viscous coupling. I am pretty sure that the first 3000 JDM ST165's had a manually locking system
JustenGT4
Re: ST165 LSD? Wed, 16 June 2004 03:19 Go to previous messageGo to next message
Sorry guys the 165 has an open rear diff.
All Aussie delivered 185's and 205's have the Torsen rear end which is identical for both models.
Either of these diffs will bolt straight into a 165 so it's an easy fix.
The torsion is the best open for a street driven car as they basically never wear out and are 'open' when not under load so tight turns etc are no probs.
I have a TRD diff currently in my red beast. Treating it very gently as i want it in good nick when i swap in the Supra diff. It's tight, skips the tyres on tight turns.
RWDboy
Re: ST165 LSD? Wed, 16 June 2004 03:34 Go to previous messageGo to next message
What about an import (my ST165 is coming from Japan) I'm guessing it's JDM, so what kind of diff(s) does it have? I know the front diff is open, but the rest?
JustenGT4
Re: ST165 LSD? Wed, 16 June 2004 03:39 Go to previous messageGo to next message
It should still be an open rear diff.
All the front diffs are open and i'm pretty sure all the centre diffs are viscous LSD. The early 165 had basically the same transmission as the RAV 4 with the electronic centre diff lock. Kinda cool but the box is nowhere near as strong as the later boxes (185 onwards).
JustenGT4
Re: ST165 LSD? Wed, 16 June 2004 03:43 Go to previous messageGo to next message
Sorry, just re-read my post and i wasn't competely clear. All the later centre difs after the difflock equipped version are viscous centres.
RWDboy
Re: ST165 LSD? Wed, 16 June 2004 03:51 Go to previous messageGo to next message
Hrm - so the idea would be to grab an ST185/ST205 torsen rear diff and then it's all good? Except for going stupid and getting the ST205 gearbox with the LSD in the front as well...
JustenGT4
Re: ST165 LSD? Wed, 16 June 2004 04:00 Go to previous messageGo to next message
Depends on the year 165. post 87 ditch the diff lock i think.
A torsen diff from a 205 (just newer) would be a good improvement.
I'm yet to confirm what 205's if any had a front LSD. If you see how they mesh with the centre diff there's bugger all room there to do anything fancy.
I have 2 205 boxes but none in bits to check
RWDboy
Re: ST165 LSD? Wed, 16 June 2004 04:12 Go to previous messageGo to next message
So grab a 87 or later centre diff if the car has the manual locking thing Smile
JustenGT4
Re: ST165 LSD? Wed, 16 June 2004 04:24 Go to previous messageGo to next message
Not really, you're better of getting a whole later model gearbox as by the time you pay to fit a center viscous diff you're gonna be up for similar dollars anyway and the later boxes are much stronger anyway. Basically the later the stronger. Not much to pick between the 205 and ST185 GrpA boxes other than ratios and rumour has it a larger rear viscous coupling.
I'd just run what the car comes with until it breaks and then bin the 165 box and upgrade. If it never breaks then you've had good luck and saved some dollars. With any powerup though i think you're gonna break it Smile
good excuse to go with the full 205 driveline into a 165....that would be a nice combo
RWDboy
Re: ST165 LSD? Wed, 16 June 2004 04:48 Go to previous messageGo to next message
I've never heard of people having trouble (in motorsport circles at least) with the standard gearbox in GT4s?
JustenGT4
Re: ST165 LSD? Wed, 16 June 2004 05:04 Go to previous messageGo to next message
Syncros mainly, which is why the 185 Grp A and 205 boxes ended up with the upgraded gear.
165 boxes, while not fragile like a WRX box, will break though. A big hp 165 car in the US used to eat boxes on a regular basis. Last i heard he was trying a later model box but faded off the lists i'm on so don't know how he went.
I've seen one rally ST 185 GrpA box go in the PRC Class. Bate's Grp N uses an aftermarket straight cut gear set.
My current 190kw at the wheels has chewed out a twin plate clutch but the 205 box is still hanging in there (touch wood). She'll bag up all 4 off the line no probs.
Pfitzner do a nice straight cut competition close ratio gearset and they are currently on 'run out' sale for around 5K Smile
RWDboy
Re: ST165 LSD? Wed, 16 June 2004 13:22 Go to previous messageGo to next message
Your gear box may still be alive because of the clutch lunching itself Smile Sometimes it pays to have a 'weakness' somewhere, preferably the cheapest to replace component.
stumpy
perth WA
Re: ST165 LSD? Thu, 17 June 2004 10:06 Go to previous messageGo to next message
After doing a google search for st165 I found an article which had the stats and description of the drive line. It states that the st165 came with a viscous center diff and a torsen rear. It was from a rallysport writeup.(google st165, second heading). I suppose the only way I will truly know is when the car arrives Cool
stumpy
perth WA
Re: ST165 LSD? Thu, 17 June 2004 10:09 Go to previous messageGo to next message
Sorry, that is a RALLYCARS.COM writeup Razz
RWDboy
Re: ST165 LSD? Thu, 17 June 2004 12:29 Go to previous messageGo to next message
Yeah that's what I'm waiting for - it's a 1988, so it has the viscous coupling for sure. I doubt it will have an LSD in the rear though.
stumpy
perth WA
Re: ST165 LSD? Thu, 17 June 2004 13:50 Go to previous messageGo to next message
Well according to the document, it comes from the factory with the torsen rear end Very Happy
JustenGT4
Re: ST165 LSD? Fri, 18 June 2004 02:54 Go to previous messageGo to next message
I'd be interested to hear if it does have a torsion rear diff when it turns up. US delivered 165 never had a trosion rear and all the kiwi jap imports that have been opened up are single spinners as well. If the article states that all had the torsion then it's clearly suss...still if you end up with a torsion rear diff it's all good Smile
wagonist
Toymods Club Treasurer
Re: ST165 LSD? Fri, 18 June 2004 05:35 Go to previous messageGo to next message
Sorry to hijack, but were all of the ST185 LSD's the torsen type?
JustenGT4
Re: ST165 LSD? Fri, 18 June 2004 05:40 Go to previous message
If you're talking about factory then Yup. TRD, Quaife and possibly KAAZ do clutch pack style centres.
Previous Topic:t50 no gear when cold, Oil recommendations?
Next Topic:Air filter Qs
Current Time: Tue Oct 20 23:48:09 UTC 2026
Total time taken to generate the page: 0.042540073394775 seconds
