Toymods » Tech & Conversions » ke10 rear brake conversion, any info???
ke10 babe
Auckland New Zealand
icon12.gif  ke10 rear brake conversion, any info??? Sat, 12 June 2004 09:26 Go to next message
Hi all, I have 69 corolla, ke10 2 door. im wanting to a brake up-grade to the rear drums to disc brakes, Ive already sorted out whats happening to the front. but just wanting any info about this conversion, if any one has doe it before?
Im wanting to possibly keep the old corolla diff assembly & adapt different hubs/brake assembly to Disc brakes. Does anyone have any ideas, has dont it before or know of an ideal set up for my rolla.
any info is a big help Smile
[Updated on: Sat, 12 June 2004 09:28]
Re: ke10 rear brake conversion, any info??? Sat, 12 June 2004 09:55 Go to previous messageGo to next message
one possibility could be series 1 or 2 RX7 rear discs...
haven't had a good look at one yet, but they have same stud pattern, and if it's an 'over' type disc, can't be too hard?
ke10 babe
Re: ke10 rear brake conversion, any info??? Sat, 12 June 2004 10:19 Go to previous messageGo to next message
cheers for that, early rx7 was on my mind actually.
your always on these forums dude! lol
how do get a picture up with your login name? & did u get my email the other day stewart?
rotorace
Re: ke10 rear brake conversion, any info??? Sun, 13 June 2004 13:08 Go to previous messageGo to next message
hey ke10 babe, just wondering what brakes youll be fitting to the front of your beast?????????
ke10 babe
Re: ke10 rear brake conversion, any info??? Thu, 17 June 2004 07:21 Go to previous messageGo to next message
'rotorace' do you have ke10??
I was going modify some S1 Rx7 front struts & totally change the suspension & braking of the car. But after a good talk through on it all. I think we will be going with a type of corolla strut with racing spring, fully adjustable ride height & camber etc. The finer details still need to be worked out. But we will hopefully end up with a set up very much like the photos ive added. Im planning on changing the brake master cylinder also & front brakes, I want the car to handle & brake at the best It can. With all going well, a good engineer mate & an A grade mechanic boyfriend,& automotive exp myself everything should be all good!
Photos are of an rx7 with corolla strut,racing suspension,fully adjustable ride height,camber/casterwith custom modified brake rotors & Wilwood custom calipers.Looks pretty trick.
http://202.21.128.4/photoserver/5/4246205_full.jpg
http://202.21.128.4/photoserver/18/4246218_full.jpg
rotorace
Re: ke10 rear brake conversion, any info??? Fri, 18 June 2004 01:24 Go to previous messageGo to next message
I own a ke20 or two Very Happy they are some farkin huge brakes Shocked way bigger than what i was thinking (and more expensive, i bet)
that is crazy, good luck with it.
ke10 babe
Re: ke10 rear brake conversion, any info??? Fri, 18 June 2004 07:34 Go to previous message
lol, those photos were just to show the strut il be going with. Not the brakes they are far too big my lil rolla. the set up in the photo is what my boyfriend has fitted in his s1 rx7.
Previous Topic:engine cut out
Next Topic:Problem with Radiator.... :(
Current Time: Thu Oct 22 06:55:13 UTC 2026
Total time taken to generate the page: 0.0047039985656738 seconds
