Classifieds » Parts Wanted » Coilover kits
Satoshi
Coilover kits Sat, 12 June 2004 13:08 Go to next message
coilover kits such as sleeves,upper hat,nuts,etc for ae86 struts..
garyskl
Re: Coilover kits Tue, 15 June 2004 15:33 Go to previous messageGo to next message
Upper seat and adjustable case at 485, what else do u need?
Satoshi
Re: Coilover kits Tue, 15 June 2004 21:29 Go to previous messageGo to next message
485 Shocked ? may i know what 'exclusive' brand is it?
Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes
wil8115
Seattle area, USA
Re: Coilover kits Wed, 16 June 2004 02:25 Go to previous messageGo to next message
485? holy green backs batman.. Shocked
I just did my RA21 celica for $150us. And they are the same kit that will fit the ae86.. Rolling Eyes
Satoshi
Re: Coilover kits Wed, 16 June 2004 05:09 Go to previous messageGo to next message
gary..next time before u post the price..i appreciate more info on your product u are about to sell...
3sglevin
Re: Coilover kits Wed, 16 June 2004 05:53 Go to previous messageGo to next message
pm sent
TerryOBeirne
Redbank Plains,near Ipswi...
Re: Coilover kits Thu, 17 June 2004 12:12 Go to previous messageGo to next message
OK, who has kits for US$150. thanks
TheGecko
Re: Coilover kits Thu, 17 June 2004 13:39 Go to previous messageGo to next message
$485 does sound high Shocked
How about these:
http://images3.fotki.com/v37/photos/1/12090/417152/09250002-vi.jpg
The sleeves (blue) with collars (gold) are from Fulcrum Suspension and cost $77 a pair - not each, a pair. I don't have a price on the hats but ring Fulcrum and ask them. For more pics of Xt131 struts shortened and made into coil-overs, see http://fookseung.fotki.com/automotive-1/ke35/front _strut_setup/.
Hope this is helpful,
Dominic
bbaacchhyy
Re: Coilover kits Fri, 18 June 2004 02:01 Go to previous messageGo to next message
TheGecko wrote on Thu, 17 June 2004 23:39
How about these:
Dominic
$77 per PAIR ??? Shocked Shocked Shocked Shocked
You're shitting me ? Do they have a web address/phone no. that you can order them through ?
At that price I'll take a set !! I have a set of springs in the shed that I will be able to use as well !!!
Michael B
EDIT :
Just spoke to Fulcrum, and to get what is pictured is $180. It is $77/pair for the threaded collars, $77/pair for the upper spring plate, and $27.50 for a pair of spanners.
Not so cheap but still pretty good.
[Updated on: Fri, 18 June 2004 03:37]
45aken
NSW.south coast.Drifting
Re: Coilover kits Fri, 18 June 2004 06:56 Go to previous messageGo to next message
what is the length of adjustment for those collars???
3sglevin
Re: Coilover kits Fri, 18 June 2004 10:21 Go to previous messageGo to next message
thats very cheap dude! I can see one small probelm though, they look like they are Alloy, do they have a way of mounting them to the legs? Most of the threaded tubes are steel, so you weld the to the leg.
Satoshi
Re: Coilover kits Fri, 18 June 2004 12:10 Go to previous messageGo to next message
i've got a reply from fulcrum..$40 each for sleeves and upper hat.. its quite cheap compared to what garyskl quoted me..
i'm still waiting for fulcrum to reply me on what the sleeves are made out off..
alloy is bad?
TheGecko
Re: Coilover kits Fri, 18 June 2004 14:46 Go to previous messageGo to next message
bbaacchhyy wrote on Fri, 18 June 2004 12:01
Yeah, like I said in my original message "The sleeves (blue) with collars (gold) cost $77 a pair - not each, a pair. I don't have a price on the hats but ring Fulcrum and ask them." $77 is for a pair of sleeves and collars. Not the hats, not the spanners, not springs, not fitting, etc, etc.
For all who have asked, yes the sleeves are anodised ali. There's plenty of meat on them (about 4mm thick in the threaded area) so I think they're up to the job. I suspect if you were adjusting them a lot the threads might start to gall but, really, once they're set up, how often do you adjust them? Total adjustment range is 85mm. Yes, they will need a support ring welded to the strut to sit on. Also, the sleeves may need a light cut up the inside (50mm dia) to fit over your strut tubes - that will depend on the diameter of your struts. A six-pack to a friendly fitter/turner should see that done - every car modifier should know at least one tame fitter/turner Smile.
The Fulcrum hats aren't particularly remarkable (particularly if they really are $77/pr) and I didn't buy any for my application (although what I'm doing is a fair way out of the ordinary anyway Smile ). The hats are cast ali, supplied completely unmachined i.e. not even drilled for the strut shaft. I would get the aforementioned friendly machinist to turn some up for me.
Fulcrum are Brisbane based and their web site is http://www.fulcrumsuspensions.com.au
Hope this info is helpful,
Dominic
garyskl
Re: Coilover kits Fri, 18 June 2004 15:38 Go to previous messageGo to next message
Sorry guys, mind is from Revolver, it is always good some people find something cheap! Smile
Satoshi
Re: Coilover kits Fri, 18 June 2004 16:13 Go to previous messageGo to next message
anyone knows how much noltec kit then? if noltec kit is around the same price as fulcrum..i'll go for noltec
wil8115
Seattle area, USA
Re: Coilover kits Sat, 19 June 2004 03:17 Go to previous messageGo to next message
I can get what you need.
it'll be $150us plus shipping from the states.
350# & 450# springs come in the kits.
collars are 4" long so you have about 3.5" for adjustment.
comes with everything needed.
For tubes that are smaller in dia then the AE86/TA22/RA21
there are rubber O-rings that slide around the tubes and the sleve fit over those.
Mine fit like a glove. I even had to clean off the tubes to get the sleves to fit.
heres some pics of them on my car
http://www.classic-celica.com/modules.php?set_albu mName=Will-s-72&id=DCP02679&op=modload& ;name=gallery&file=index&include=view_phot o.php
click back and forth there are 3 pics of the coilovers.
For an extra 1" of travel in the springs and other spring rates
the Cost is $200 + shipping.
rough guess at shipping is $45us. for approx size box and weight, surface mail 4-6 weeks.
Let me know if i can help ya.
[Updated on: Sat, 19 June 2004 03:42]
45aken
Re: Coilover kits Sat, 19 June 2004 06:07 Go to previous messageGo to next message
i think i'll just go with the T3 coilover kit. $245AUD delivered to your door, everything you need including any rate spring, hats and spannars etc. the sleve has a whomping 6inches of travel and is designed to fit AE86 struts perfectly.
wil8115
Seattle area, USA
Re: Coilover kits Sat, 19 June 2004 08:36 Go to previous messageGo to next message
6" of travel and 6" of adjustably are 2 separate things.
Stiff springs with less travel bottom more easily..
same rate springs, longer free length take more compression to bottom.
Also when you do lower it without lowering the bottom of the strut tube you lose that much more "travel"
Satoshi
Re: Coilover kits Sat, 19 June 2004 10:30 Go to previous messageGo to next message
now i'm not sure about T3 stuff..i've heard ppl say their stuff breaks.. i'm waiting for 3sglevin to quote me on Noltec kit..no more fulcrum sleeves since they are made of alloy... Sad
tell me...does the sleeves tend to rust a little over a long period of time?
wil8115
Seattle area, USA
Re: Coilover kits Sat, 19 June 2004 10:52 Go to previous messageGo to next message
Rust? these are Alumimun sleves, corrode maybe, rust no.
to be honest the only sleves i've even seen for coilovers that were steel were on an offroad racing coilover setup with 18" of travel and remote res for the shock.. they were also like $1250us for a PAIR. Shocked
[Updated on: Sat, 19 June 2004 10:54]
TheGecko
Re: Coilover kits Sat, 19 June 2004 14:58 Go to previous messageGo to next message
Satoshi wrote on Sat, 19 June 2004 20:30
What's the problem with alloy? They're anodised so they'll stay in good condition pretty much forever without corrosion/oxidation. They're thicker wall than the steel strut tubes that currently hold the car up so strength shouldn't be an issue. As wil8115 says, most aftermarket coil-over kits use alloy sleeves.
D
Satoshi
Re: Coilover kits Sat, 19 June 2004 20:21 Go to previous messageGo to next message
ops..i dont mean that alloy will rust ...i thought alloy and metal dont go together?
the rust i was talking about is from a used coilover from a guy... Smile
after post and post..still none of you can confirm the noltec kit with me?? Sad i wanna know what price u guys get...
TerryOBeirne
Re: Coilover kits Sun, 20 June 2004 07:42 Go to previous message
guys, the threaded sleeves need to be solidly secured to the strut tube, the usual method is welding. At last check, we cant weld steel to aluminium alloy, so you have big problem!!!. the fulcrum ones are meant to sit on a steel ring that gets welded to the strut body. they must be a tight fit over the strut tube, so you must choose carefully, otherwise the rattles will drive you mad. the cheap kits use O rings to take up any slack between the tube inner and the strut tube outer. a short thread is not a problem so long as you have various coil lengths. In general, for road cars, you need about 250mm long coils otherwise the coil goes slack on rebound, and rattles like crap. alterntively, you can use a "helper" spring, which is a flat steel spring , but you need an adaptor ring to buttt up to the main coil.
Previous Topic:WTB: 2x12" Sub Box (Perth)
Next Topic:TRD STICKERS
Current Time: Fri Nov 20 11:43:11 UTC 2026
Total time taken to generate the page: 0.10405015945435 seconds
