Toymods » Tech & Conversions » 2tg cams
Dominic
Perth,western australia
2tg cams Sun, 13 June 2004 09:44 Go to next message
hi,
i have a set of 2tg cams and im trying to figure out if they are standard or something more sporty.
i searched the arhives and checked out my t series manual but i dont know what the specs i have mean so i cant match it up at all!!
heres what ive got:
running clearance: in .008" ex .008"
lift @lobe in .410" ex .410"
advertised timing
ex opens 75deg closes 43deg
in opens 45deg closes 73deg
setting specs
inlet valve lift @TDC on teh over lap .168" ex .147"
can any one help me out with this??
any insite woudl be great.
cheers,
Dom
YelloRolla
On your mum!
Re: 2tg cams Sun, 13 June 2004 10:43 Go to previous messageGo to next message
That seems a bit hot for standard cams - but they may well be something out of Toyota - maybe toyman75 will be able to assist beyond that.
TA22-3SGTE
MACKAY
Re: 2tg cams Sun, 13 June 2004 10:49 Go to previous messageGo to next message
They are fair size cams ,It works out to 298 degrees duration with .410" lift , You will need to lift your compression ratio up to around 10.5 to 11 : 1 for these to work properly , A 2TG/3T hybrid with these cams , high compresion , a set of extractors , exhaust and tuned right will push a TA22 into the mid 14 sec mark , So a 2TG with this setup should do low 15's .
Trevor
[Updated on: Sun, 13 June 2004 14:56]
Dominic
Re: 2tg cams Sun, 13 June 2004 15:04 Go to previous messageGo to next message
i got these cams off a mate.
he got them with an 18rg he bought.(extra,they were'nt in it).
we thought they 18rg cams and i was going to compare them to a spare set of 2tg cams that i have.
we wanted to see if 18rg cams would fit in a 2tg.
i then discovered the grind tag giving all the details of them.
i have a 2tgeu with K&N air filter and extractors.
standard ecu and everything else,
whats the best way to raise the compression as was suggested??
cheers,
Dom
thetoyman75
Club President
Re: 2tg cams Mon, 14 June 2004 12:26 Go to previous messageGo to next message
Dom,
So you ended up with those ! They actually sound like a pretty tuff set of cams. They are way bigger than any stock 2TG grind.
Compare the cam lift to these stats:
Cam Shaft:
Lobe Height In 45.87 ~ 45.97 (Up to April 1973)
Lobe Height In 46.37 ~ 46.47 (April 1973 Onwards)
Lobe Height Ex 45.87 ~ 45.97 (Up to April 1973)
Lobe Height Ex 46.37 ~ 46.47 (April 1973 Onwards)
Cam Lift:
In 9.82 (Up to April 1973)
In 10.27 (April 1973 Onwards)
Ex 9.82 (Up to April 1973)
Ex 10.27 (April 1973 Onwards)
The "Up to April 1973" is the 88220 head.
The "April 1973 Onwards" is the 88222 head.
These figures are of course for the GT TA22 Celica 2TG's. I am yet to confirm it but the 88222 cams are supposed to be the "biggest" of any 2TG. But like I said I am yet to confirm this.
Your cams have 10.414mm lift.
thetoyman75
Club President
Re: 2tg cams Mon, 14 June 2004 12:38 Go to previous messageGo to next message
Dom,
Mate if you are going to change compression by replacing the pistons then it would be the perfect time to fit the 3T crank. The increased displacement will go a long way to making that cam more drivable. Increased displacement will add torque to help carry the addd lift and duration. I wouldn't go anymore than 10.5:1 compression if you intend to keep using pump fuel (98 Octane)
In Tina's it was only 9.8:1 but it dealt with bigger cams than you have there. (Camtech L1 Cosworth Race grind) admittedly it had next to nothing below 4500 RPM.
Dominic
Re: 2tg cams Mon, 14 June 2004 15:00 Go to previous messageGo to next message
cheers mate.
i have a 1ggze that im going to drop in at some point once i have built to tewh hilt and done a fair bit of body work.
id say 6months to a year before i take my celica of teh road to do this(got to get a hilux and a bigger shed first!!)
so im trying to make this as cheap as possible.but im figuring that its gonna cost me teh same to get a 3t re ringed(and pistons flycut)as it is do it to the 2tg block.i have a 3t block already.
the rings on my 2tg arent that great and she blows a bit o smoke.
would i need to fly cut the 2tg pistons to run this cams if i were to stick with the 2tg block/pistons?
woudl it be better to put the 3t crank into teh 2t block?and stick with 2tg pistons etc?i wouldnt be boring out at all.
cheers.
Dom
YelloRolla
On your mum!
Re: 2tg cams Tue, 15 June 2004 09:14 Go to previous messageGo to next message
Rod, the difference between the stock 10.27mm cams and these ones is 6 thou - nothing really in terms of lift.
The 298 degrees of duration seems like it is pretty big. I wonder if any one know for sure what the duration of the standard cams are "seat to seat", and also the factory overlap.
TA22-3SGTE
MACKAY
Re: 2tg cams Tue, 15 June 2004 13:44 Go to previous messageGo to next message
Standard 2TG cams Before april 1973:- IN opens 20 BTDC Closes 48 ABDC 248 degrees duration ,Exhaust Opens 52 BBDC Closes 16 ATDC .
After April 73 :- Intake Opens 16 BTDC Closes 60 ABDC 256 Degrees Duration , Exhaust Opens 60 BBDC Closes 16 ATDC .
Trevor
YelloRolla
On your mum!
Re: 2tg cams Tue, 15 June 2004 22:43 Go to previous messageGo to next message
Thanks for that Trevor. I knew 296 degrees of duration is getting pretty big, but I thought that the factory 2TG cams would have had more duration - like has been said, these ones are considerably bigger.
thetoyman75
Club President
icon7.gif  Re: 2tg cams Wed, 16 June 2004 00:58 Go to previous message
Sorry Guys,
I should have specified that the Duration was the major difference. I just didn't have the stock duration figures handy so couldn't make a comparison.
Thanks fo rthose Figures Trev, I have never had a chance to stop and work that out or reference it.
Previous Topic:Exact 3T capacity?
Next Topic:TA22 rear disc brakes
Current Time: Tue Oct 20 15:55:23 UTC 2026
Total time taken to generate the page: 0.0057270526885986 seconds
