Toymods » General Car Talk » New carpets
icon5.gif  New carpets Sun, 13 June 2004 11:12 Go to next message
Hey guys,
I'm going to purchase new carpets for my car from Knox, http://www.knoxautocarpets.com.au/
I'm getting black, and I've decided on the normal plush pile after going over this picture: http://www.knoxautocarpets.com.au/_derived/default .htm_txt_KACTexture1.gif and looking at the prices.
What I'm not sure about is whether to buy the carpet underfelt or the sound insulation felt. Anybody who's actually bought new carpet before have an opinion? The original stuff is pretty ratshit so it needs replacing. Don't know how the sound insulating one could be worth $60 more than the normal stuff though.
Also, someone said about using a heat gun for moulding the carpets properly on the floor, is that right?
Thanks,
Nathan
ae86drift
sydney.au
Re: New carpets Sun, 13 June 2004 11:18 Go to previous messageGo to next message
i bought knox normal plush for my 86
no underlay coz i got the car stripped with a cage in it... metal metal metal
anyhows... its fucking good carpet, no need for heavy ass underlay, nice and plush. so forget your crappy sound deadening and lose the kilos Wink lord knows the celica needs weight watchers as it is
not cut to the right holes, just semi-moulded, so gotta cut slits and squares out. i also didnt need a heat gun, but if you want a PERFECT fit get a gun.
easy to install if you have originals to go by, fucking near-insane if you dont....
Re: New carpets Sun, 13 June 2004 11:24 Go to previous messageGo to next message
Awesome, I knew there was at least one around. I've fired them an e-mail, and unless they say it makes a drastic improvement I'll just grab the normal stuff.
As for saving weight, I've already done some of that with new seats and a 1G Smile I'm going to a bit of comfort and refinement...see what this is:
http://users.bigpond.net.au/justcallmefrank/floor.jpg
...it's sound deadener, and there is more of it since then and it's in every panel! Smile
Re: New carpets Sun, 13 June 2004 14:04 Go to previous messageGo to next message
I went for the non-sound deadened stuff.
It fit really nicely, except it's a little big over the trans tunnel for the back half of the carpet... so I put some insulation over the tunnel, worked a treat.
check and re-check where to cut the holes for your seat rails etc - as these make great anchor points to stretch the carpet out properly.
Keep your old carpets, to give yourself an idea of how you'll need to cut the new ones, but all in all it's a pretty simple (tho time consuming) job to cut the carpets properly to size.
and they feel *great*, plus for $150? delivered, who can complain? Smile
Re: New carpets Sun, 13 June 2004 14:07 Go to previous messageGo to next message
They are only $130 now! Smile Looks like the normal stuff is the go Smile
Re: New carpets Sun, 13 June 2004 14:24 Go to previous messageGo to next message
just be prepared for a decent bit of cutting - some heavy duty scissors/shears will serve you very well.
easiest way to do the bolt holes for the seat rails is to put the carpets in place, then punch a hole in the place with a screw driver, and use a drill to widen it to fit the bolt through.
Re: New carpets Sun, 13 June 2004 14:27 Go to previous messageGo to next message
Aren't I glad the girlfriend has claimed the interior as her project Wink
Thanks for the tip. I've got heat gun already, these carpets are going to be poifect Very Happy
Re: New carpets Sun, 13 June 2004 14:36 Go to previous messageGo to next message
Smile
just dont be afraid to chop.
for convenience, I chopped the front carpets into 2 halves, passenger and drivers. all the cuts are hidden under the centre console anyway, and this makes fitting a lot easier.
If you need a hand, you know who to pm Smile
Re: New carpets Sun, 13 June 2004 14:38 Go to previous messageGo to next message
Sure do Smile Thanks mate.
Greg.
Re: New carpets Sun, 13 June 2004 23:47 Go to previous message
I got new moulded carpets for my MX32 from these guys
www.protectomat.com.au based in W A ...Have a local set up in NSW(Castle Hill)..really good to deal with..As previously stated be prepared to cut/trim..I used some heavy scissors and a stanley knife..fiddly and time consuming to get the perfect fit..I re used the underlay which was glued to the original carpet but have just left it loose except for a squirt of aerosol glue to keep it stable..looks so good so far but anything would have to be better than the sun effected pus green of the original..did not go for the paint on sound deadening becaue the floor is original unmarked/unrusted factory freash paint..
Previous Topic:Finally pics of my hachi with 17's
Next Topic:Where to get custom centre console ( sydney)
Current Time: Thu Nov 19 10:15:39 UTC 2026
Total time taken to generate the page: 0.0091171264648438 seconds
