Toymods » Tech & Conversions » 4AGE rwd water pump
ae95
4AGE rwd water pump Sun, 13 June 2004 11:53 Go to next message
Hey guys,
Im chasing a part number for a rwd 4age water pump. My water pump just started leaking. need a new one asap.
cheers guys
-ian
ae86drift
sydney.au
Re: 4AGE rwd water pump Sun, 13 June 2004 11:58 Go to previous messageGo to next message
i think repco make these
and they are better than OEM becuase it has an extra blade on the impeller
IRA11Y
Club Member
Re: 4AGE rwd water pump Sun, 13 June 2004 12:03 Go to previous messageGo to next message
just goto any parts supplier and ask for a water pump to suit an AE86 4AC
ae95
Re: 4AGE rwd water pump Sun, 13 June 2004 12:27 Go to previous messageGo to next message
is the 4ac water pump the same?
i was thinking the 4age needed a greater capacity water pump since it can rev much more and therefore gets much hotter.
ae86drift
sydney.au
Re: 4AGE rwd water pump Sun, 13 June 2004 12:47 Go to previous messageGo to next message
doubtful toyota would waste time making a lower capacity pump for the same series engine
SLY16V
camden
Re: 4AGE rwd water pump Sun, 13 June 2004 14:23 Go to previous messageGo to next message
why cant you just goto toyota and get an ae86 4age water paump brand spankin new???
cause i want to get a new one too.
ae95
Re: 4AGE rwd water pump Sun, 13 June 2004 14:39 Go to previous messageGo to next message
theyre about $180 at our good mates at toyota genuine parts Rolling Eyes
AE86slut
Baulko Hillo
Re: 4AGE rwd water pump Mon, 14 June 2004 01:16 Go to previous messageGo to next message
i just bought a new 4AC water pump from repco - $110. Where's it actually leaking from?
45aken
NSW.south coast.Drifting
Re: 4AGE rwd water pump Mon, 14 June 2004 03:30 Go to previous messageGo to next message
pick & payless?
everything is going to be expensive new. my alternator broke reconditioning costs $140 - $180
new one $400 - $500
re-co'ed one from wreckers $50 (with a 6 month warranty aswell!)
toyota aint cheap
MFX_AE86
Liverpool
Re: 4AGE rwd water pump Tue, 15 June 2004 15:13 Go to previous messageGo to next message
I replaced the one on my GZE on the weekend just gone got mine from PEPS for $100 odd... I know the GZE/GE ones are the same(only cause i put the GE one on my GZE, lol) not sure about the 4ac tho ?
Dave
ae95
Re: 4AGE rwd water pump Wed, 16 June 2004 02:15 Go to previous messageGo to next message
im pretty sure its leaking between the engine and the waterpump. could the leak be caused by overtightening the belt?
MFX_AE86
Liverpool
Re: 4AGE rwd water pump Thu, 17 June 2004 13:19 Go to previous messageGo to next message
Just a recheck on the price... I payed $70 at PEPs for my pump...
Also my water pump was leaking cause the bolts were loose, nothing some gasget goo & a hr or 2 couldnt fix.
Dave
feral4mr2
Bundaberg, Qld.
Re: 4AGE rwd water pump Thu, 17 June 2004 21:01 Go to previous messageGo to next message
ae95 wrote on Wed, 16 June 2004 12:15
it might be just leaking from the o-ring then, the pump itself could still be ok.
when you buy the pump you normaly only get the front half. so you wanna make sure you actualy need it.
i only sold one to a friend for hiw aw11 early this week too, damned if i can remember the exact part #.. Sad
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: 4AGE rwd water pump Fri, 18 June 2004 00:40 Go to previous messageGo to next message
The genuine toyota pumps come with both halves, so you're getting more for your money for a start, & the list price from toyota is $144, but you should be able to pick it up for $97 like I did.
P/N. 16100-19095
ae95
Re: 4AGE rwd water pump Fri, 18 June 2004 10:04 Go to previous messageGo to next message
just paid 66.40 for the front half of the water pump.
might return it and get a toyota genuine one. btw how many blades are on the normal water pumps?
ae95
Re: 4AGE rwd water pump Sat, 19 June 2004 19:28 Go to previous messageGo to next message
4ac water pump doesnt fit!
ae82 4age fits but clutch fan doesnt bolt up and belt doesnt line up.
ae92 has same part no. as ae82.
ae95
Re: 4AGE rwd water pump Sat, 19 June 2004 19:29 Go to previous messageGo to next message
BigWorm wrote on Fri, 18 June 2004 08:40
P/N. 16100-19095
How'd u pick it up for 97?
ae95
Re: 4AGE rwd water pump Sat, 19 June 2004 19:30 Go to previous messageGo to next message
Also, its the actual pump thats leaking. Found it out today so i'll definately be needing a new pump and only the front
ae95
Re: 4AGE rwd water pump Tue, 22 June 2004 01:25 Go to previous messageGo to next message
btw have any of you actually fitted a 4ac water pump to the rwd 4age?
Mine doesnt fit
IRA11Y
Club Member
Re: 4AGE rwd water pump Tue, 22 June 2004 06:34 Go to previous message
news to me.. ive fitted at least 20 of them by now "shrugs" are you using the rear section of the 4age pump mated to the new front housing? The front section will fit up to ALL rear sections, the only difference is the front bearing size on the rwd unit is stronger ( and a little longer from memory too ) to cater for the extra weight of the clutch fan.. a fwd front unit will not last long ( trust me ive broken them trying to do it cheaply before Smile ) and they can end up cracking the casings
[Updated on: Tue, 22 June 2004 06:37]
Previous Topic:Handbrake Wont Lock
Next Topic:'77 KE30 Wiring Diagram
Current Time: Wed Oct 28 08:11:47 UTC 2026
Total time taken to generate the page: 0.024420022964478 seconds
